#1426 |
HS RA
#1427 |
Ride: 1991 CRX Si
Oh I gotcha. See? your just such a big influence on me!! Next I'll be doing Gold with Black lettering
![]() Sorry for not posting up much stuff in here fellas... I'm about to do some photoshoots with my buddy (He just got a new wide-angle that we'll mess around with), so I'll get some visual's up here soon. Plus I think, like Terrance said, we'll be going to the track(drag) this or next weekend. I'll see what I can do on street tires. I think I'm expecting around a 15.0 @ around 94 maybe? we'll see. FYI, This is the track I ran my D16Z6 on.. remember guys? Heres the highlights: 2-17-07 ![]() ![]() ![]() So we'll see... I couldn't trap any 60' lower than 2.4 b/c it was so slick, I would just spin SO bad, but, it was my first time at the track, so IDK what will happen. Of course you guys will find out soon enough... -Andrew |
#1429 |
Ride: 1991 CRX Si
I wonder if I could just mount 'em on the ol' Fat Fives for the weekend? It would be what... $6 per tire, so $12/pair, $24 after I take them off next week. It'd be like a $25 rental... idk.
What do you think about that idea? |
#1430 | |
I trained Trogdor to pWn
1994 Acura Integra GS-R Sedan My MAIN DB8 project thread on Honda-Tech: Very detailed of EVERYTHING I've done to my car. Contact me for ITR header skid plates: $40.00 shipped!!! |
#1431 |
if you boost it..........
Ride: turbo 91 crx si, 95 civic 4dr, 94 4dr gsr
damn bro.... i hate to hear it took u so long to figure out that shit about ur axles..... i havent been on here in months..... also for future refrences..... the auto halfshaft will fit in the manual tranny and bolt up..... but its longer causing a bind.. had that problem with the first b series swap i ever did.... but ur car is looking awsome.
#1432 |
Ride: 1991 CRX Si
Thanks man. BTW did you ever sell your rex?
Terrance, I got a GREAT deal thru my friend. He used to work at Discount (at Kilearn) and is getting them mounted/balanced fo free. Got 'em with me as we speak. |
#1433 |
Man.....I"m so torn.. I want to take my Integra but I've always wanted to rag on a rental....
Oh man.. Decisions decisions........... No, I've got to stay with the rental idea. I di my first roll back last night BWAA HAAHAHAHH!!
#1434 |
Ride: 1991 CRX Si
Hey so I went out to the meet last night... Heres how it went down.
I'd been there about 30 min chillin talkin with Dustin(Fluffer Ej1) and Arty G... Pop my hood & find out my engine is a 1989 model (stamping on the head). Shut hood. 2 seconds later a redneck comes up to me and asks, "whats in the rex?" (this guy has a stock civic with bolt ons) "Single cam", says Dustin "Tyte, What do you run?" "15.6 or so on the D" I said "cool. wanna race?" "sure" ..... Dig- 3 cars 40 roll- 2-2 1/2 cars End of night. ![]() Should've asked to run for $20 or so. |
#1435 |
Sonnova Bitch!
Ride: 2006 GSX-R 600, 2003 Santa Fe GLS
That's classic
#1436 |
Ride: 1991 CRX Si
15.6 @ 89.
On drag radials. I don't know why my engine doesnt make more power than my freaking d16. Compression and Leak down will fill me in a little bit more. Plus it's only on a basemap tune. |
#1437 |
learning in progress
Ride: 00' Montero sport, 99' lsv civic
all that for nothing...
at least you can say you have a b series & there is more potential dont worry you live and learn. get a wet kit and youll see low to mid 14.
#1438 |
Dismember
Ha! the D gods smite you with slow for blaspheming them. Put the d back in, sell the B and use that money to boost it.
My Project 1978 Honda Civic D16A1 swap - IT IS ALIVE! Do not PM me with tech questions. I will NOT know the answer. |
#1439 |
Yes my wife is Hotttttt
Ride: chevy s-10
its either cuz you need to paractice or you need to get the drag radials off. The b16 doesnt make that much power. Alittle spin for RPm is a good thing.
Same with and lsd. If your engine doesnt have the balls its just gonna bog. practice your launches every now and then. You should be in the mid to high 14's
yo, yo ,yo wuz up! |
#1440 |
Ride: 1991 CRX Si
Granted, the tires were big (225/50's), but I don't see how traction made me slower...
Everything felt good. The only thing that was bad was my R/T's, but that doesn't really mean anything, time wise. We'll see |
#1441 |
run 17lbs in the tires, heat them up to 170* and dump the clutch while feathering the throttle around 4k. It'll hook.
Also, something is VERY screwed in that car if it is only trapping 89mph. You should be up in the high 90s with all of the weight you have removed.... unless there is a 400lb sub box in the back. |
#1442 |
Ride: 1991 CRX Si
Stock 1991 CRX Si curb weight: 2174lbs
-A/C components -heater -fan -passenger seat -spare tire/associated tools/jack ...Thats gotta be more than 100lbs right there... Anyway, my buddy came over and took some pics of my car with his new wide-angle lens: ![]() ![]() ![]() DR's? ![]() ![]() Guess who? ![]() ![]() Back OT: I'll be getting a compression tester and differential pressure tester (leak down) from my buddy in the next few days. The only problem with the leak down setup is that it's kinda cheap and only pressurizes the cylinder to 10psi... -Andrew |
#1444 |
Von Europa
Ride: 1999 Civic EJ9, 2003 Civic EX Coupé
What's with taping the lights?
DIY/Howto HID Projector retrofit |
