Update on today's progress. I've got a bunch of little things I've been working on... painting the valve cover, swapping out the front crossmembers, finishing the wire tuck, axle binding-troubleshooting/repair... etc etc.
Here's the latest:
Valve cover:
Looking good! I'll wetsand it and hit it with a final coat and that'll be it. The color is kind of "boring", but I think it'll look alright. I can always change it. If I do, I'll probably powdercoat it instead of painting.
Front crossmember: Got the stock one back on. (sucks don't it?)
And you can see here where I had to cut up and beat in the radiator supports.
Firewall plugs. For those that are too cheap to get the Honda block-off grommets. lol.
First off get some sheetmetal:
Paint it black on one side:
And install.
Wire Tuck : Made LOTS of progress today.
Got the harness finished and installed! That means the engine bay wiring is DONE except for blocking off the heater core coolant lines. I sent all of the wiring through the heater hoses grommet. Much cleaner and Much more professional looking than my original. (Almost no electrical tape except for every 6" or so on the wire-tubing.
Interior shot. Got a bit more stuff to do, but this is the easy part.
E-Bay. You can see it coming out of the heater hole...
I know, I know... get rid of the nasty stock fuel filter... Well it's got to stay for a little while longer... I think I'm waiting on getting another fuel rail with a -6an opening so I can install my stock one back in. The problem is, I don't wanna spend $100 on a freakin fuel rail.
All put back together! (minus a valve cover...
Axles.
I've determined I need to run the 86-89 axles. At least on the drivers side, since it's the one that seems to be binding(just turning by hand). My question:
Will an '86-'89 Integra LS axle fit into a '90-93 midshaft?
Thanks guys.
-Andrew
BTW Terrance, who cares what your wife thinks?!?!?
