Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Facebook Twitter
Andrew's engine swap (pics)
This is a discussion on Andrew's engine swap (pics) in the Auto Multi-Media forum
Guys, tell Andrew he would be very sorry if he sold the Rex. He would miss it and end up buying another one. Insurance costs $50.00 a month (which is kinda high, more than what I pay). If nothing else, I'd get my GSR engine ...
Like Tree12Likes
Old 07-21-2010, 02:27 PM   #2601
mac_24_seven's Avatar
If nothing else, I'd get my GSR engine back
mac_24_seven is offline   Reply With Quote
Old 08-03-2010, 10:00 PM   #2602
Andrew's Avatar
Ok, Im not selling the Rex anytime soon...
New plan:
I dyed the carpet today. Black. Looks great!!!
Gotta put that in, finish installing the a/c, so it looks and feels nice and comfy in this heat...
I put the pistons back in the 75.5mm z6 block with new rings, and am curious to see if it works... Lol! Cyl #4 had hit marks from the rod... Just that one cylinder... Weird... Nothing is bent, so we'll see. Bearings looked fine, so I just put some ass. Lube (hehe nice abbreviation) on it and put em in. All except for cyl #2, which needs a replacement rod nut, because I lost it. Huh.
Pics soon! Forgot the camera, just had my phone...
-Andrew
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-04-2010, 01:06 PM   #2603
You wanted to know my turbo set-up, so here it is........
B16a2 block
eagle rods
JE 9;1 pistons
B16a2 head
RC 750 injectors
GS-R camshafts
skunk2 cam sprokets (at zero)
DH-Racing valves, springs, and retainers.
Stock throttle and intake.
Turbo
garrett 57 trim, 63a/r oil cooled turbo
AFI ramhorn manifold,
tial 38 wastegete and blowoff valve
3 inch piping
Not sure on the intercooler size, I do know its a 2 inch inlet and outlet.
HP is 327 and TQ is 252 at 14 pounds, 93 octane
12.8 at the track spinning the whole time.
BigZeke5 is offline   Reply With Quote
Old 08-05-2010, 08:01 PM   #2604
Andrew's Avatar
Default [DIY] seat pan swap
A long while back I purchased this JDM CRX seat (compared with my driver's side that had the 'all too common' rip on the bolster):
I finally got around to installing it, but first the pan needed to be changed, so here's how I did it:
Tools needed:
-Dikes
-Pliers
-Replacement hog rings OR standard heavy duty wire
-14mm socket
-19mm wrench/socket
-Phillips screwdriver
Get your seats-
Flip it over and see the reason for the pan swap. The bolt holes are different, therefore it won't work in our floorpans. or at least mine!
USDM Seat:
JDM seat:
Cut the hog rings-
With your Phillips screwdriver, pull the side cover off.
Use the 14mm socket to pull the 2 bolts off this side of the seat.
There is a 19mm bolt on the opposite side of the seat, remove that too. (no pic, sorry.)
It'll come right out with a little motivation:
Notice how the JDM seat (Left) is square, and the USDM (other left) tapers at the back. Gotta cut the seat foam a little bit to make it work:
Mark it:
Cut it. Carefully...
It ain't pretty, but it works.
USDM pan installed onto JDM seat bottom:
Use new hog-rings or utility wire and slip it through the holes.
Tighten them down:
Trim the excess:
I needed to cut a little bit to make this track mounting bolt:
Finished!
Car is cluttered, moving parts from 1 place to another... but you get the idea:
Not so bad! I've never done it before, and it took about 30 min to do it all.
Also, I recently dyed my carpet. Used DupliColor's Vinyl and Fabric (Gloss Black) and after vacuuming it like 3 times (out of the car, of course...), I went ahead and just sprayed it. It took 1.5 cans to do the job. Great stuff!!
Old pic: (Before)
Dyed:
In car (still installing interior...):
-Andrew
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-06-2010, 10:46 AM   #2605
Korax's Avatar
It's been awhile, good write up as per usual.
Korax is offline   Reply With Quote
Old 08-06-2010, 07:37 PM   #2606
Andrew's Avatar
Ha! thanks. I'm back! lol...
I need a new steering wheel, the foam is coming out in this eBay cheapo. At least it lasted for a couple years... does anyone have a one for sale?? Stock or otherwise... Thanks!
Old 08-07-2010, 09:35 AM   #2607
haao13's Avatar
i have a black eg wheel?
haao13 is offline   Reply With Quote
Old 08-07-2010, 03:10 PM   #2608
Andrew's Avatar
What does it look like?
Old 08-25-2010, 01:03 PM   #2609
Andrew's Avatar
You guys aren't going to like this... but I've decided to sell the CRX!
I know that seems sudden, but here's what's happened. The wife and I are getting a travel trailer and need something to pull it with. Hence, I'm buying a truck. A '96 Dodge 2500 Cummins from a friend of mine. It's got full bolt-ons and a Waste Vegetable Oil auxiliary fuel setup and low miles (130k), at a good price. It kinda sucks to get out of the Honda game, but it's just not practical for me right now in my current life situation. Gotta move on!
I'm going to get some good photos of the CRX before it sells. In fact, it'll be about a month or two before it's ready to put on the market. I need to swap motors (back to D-series) and get the AC back together. Put a new front bumper on, and get it painted. I want to get it as clean as I possibly can in order to get 'top dollar' for it.
Would you guys recommend a cleaned up stock Z6 swap? That was my intention. Unless someone has a better idea...
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-25-2010, 02:00 PM   #2610
Taco15's Avatar
Me personally I would just clean it up. Put the D and sell the B in order to maximize your profit. Obviously put all the interior back. Painting it won't help as much as you think. well, depending on how much you spend
I'll take it with a D series. Let me know so I can save my monies now. You know I've always wanted it.
Taco15 is offline   Reply With Quote
Old 08-25-2010, 03:07 PM   #2611
Andrew's Avatar
Ok, SOLD to Abel, for one hundred million dollars!
Interior is done. well, cept for the climate control unit and trunk 'plate' under the carpet. I'll fab something up soon. The factory piece is just too flimsy to be worth using.
Old 08-25-2010, 04:18 PM   #2612
Taco15's Avatar
sorry folks! I've been waiting for this car for a few years now.
Old 08-25-2010, 04:57 PM   #2613
Calesta's Avatar
Noooooooooo! I wanted a CRX. But you guys are local to each other.
Old 08-25-2010, 05:41 PM   #2614
Taco15's Avatar
yup. I've seen this and droolede over this crx for awhile now.
Old 08-25-2010, 07:41 PM   #2615
Andrew's Avatar
It's true.
Old 08-26-2010, 09:24 AM   #2616
Taco15's Avatar
I just skimmed through this whole thread and WOW.
you and this CRX have gone through alot. I'll make sure to take care of it for you.
by the way, would you mind sending me a small ( or long) list of what you will be coming with the car and what you will take off? suspension, interior, wheels. I just want to know since afterall, this CRX has never looked the same for less than a year at a time.:P
Old 08-30-2010, 09:12 AM   #2617
8-3
-Andrew
8-28
<sighs>
For what it's worth, I'm happy it's going to Abel. I wanted the Rex to have a good home and I think it'll get it.
I'm heartbroken though. It's not even a money issue, my wife won't let me own 3 vehicles or else I'd buy it. But I can't get rid of my Del Sol, it's too comfy of a ride and the Rex is kind harsh.
Sad Terrance.
At least I get my B18C back! Rebuild time!!!
Old 08-30-2010, 01:31 PM   #2618
Taco15's Avatar
thanks. :P
You guys just let me know when you get the motor out. I should have everything settled on my end soon.
I just happend to spring this on Mrs. Taco right when the bills are due.
Subaru pays me at the end of this week so I should be gravy.
My K swap dream may come true afterall!
Old 08-30-2010, 08:34 PM   #2619
Andrew's Avatar
OMG please let me drive a K-RX. Wow. Can't even imagine it!
I'll post pics of my new ride I picked up as soon as I take some!
Old 08-30-2010, 10:10 PM   #2620
Calesta's Avatar
Screw the K. Go J.
Old 08-31-2010, 07:35 AM   #2621
Andrew's Avatar
V6 CRX?
Bring it!
Old 08-31-2010, 09:18 AM   #2622
awptickes's Avatar
I vote for an N22b-swap. That'd be one torquey CRX.
awptickes is offline   Reply With Quote
Old 08-31-2010, 11:44 AM   #2623
Taco15's Avatar
Originally Posted by Calesta View Post
Screw the K. Go J.
not balling like that
It will take some time but in a nutshell the goal is for a full K20A swap including the LSD tranny. for $1,200 more I thinks it's well worth it considering it's a better motor too.
I still have to pay for the CRX first! no use in dreaming just yet.
Old 09-01-2010, 07:55 AM   #2624
A K swap in the Rex huh? I likes it. Andrew thought about doing that for a lil while.
Old 09-01-2010, 09:28 AM   #2625
awptickes's Avatar
I'm telling you, n22b swap.
Engine swap: d15b7 to d16y7; transmission? oakley2002@cox.net HYBRID -> EG-EK / DC 7 10-28-2009 06:19 PM
Best Engine Swap For 95 Integra Ls Agt_Orange_GSR HYBRID -> EG-EK / DC 7 09-23-2008 03:16 PM
Engine Swaps 101 pissedoffsol Swap Articles 0 01-11-2004 06:54 PM
EE crx engine swap. DAZ81 HYBRID -> ED-EF / DA 6 11-25-2003 09:21 AM
81 Civic Engine Swap Help fjcisco13 HYBRID -> EG-EK / DC 3 04-23-2003 05:16 PM
© 2001-2013 HondaSwap.com
