Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Andrew's engine swap (pics)
Old 01-30-2007, 12:42 AM   #401
Rep Power: 0 hestman19 is on a distinguished road
I would check all of your grounds. if everything is still hooked up and all you did was take of the intake then maby you accidently bumped somthing. hope ot helps lol
hestman19 is offline   Reply With Quote
Old 01-30-2007, 02:56 AM   #402
vanillakilla's Avatar
Rep Power: 11 vanillakilla is an unknown quantity at this point
I had the same problem in my integra when I rebuilt the motor ended up being a ground that wasn't connected. I started it up took it for a drive I was leaking coolant, fixed the leak and then my car wouldn't start. I found a ground wire by the starter that wasn't hooked up (not the transmission ground) hooked it up ran fine since
vanillakilla is offline   Reply With Quote
Old 01-30-2007, 07:50 AM   #403
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
Aight. I'll check that one today(I actually relocated that ground underthe dash, and it musta just worked it's way loose. I'll go over all of them today.
Thanks bro(s)
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 01-30-2007, 09:30 AM   #404
I trained Trogdor to pWn
mac_24_seven's Avatar
Ride:  94 GSR Sedan
Rep Power: 16 mac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura about
It's suggested to add extra grounds.
Electrical systems aren't my specialty by nomeans, but I do know that having sufficient grounds is VERY important.
And post more video's! Stop bein lazy.
mac_24_seven is offline   Reply With Quote
Old 01-30-2007, 12:15 PM   #405
Andrew's Avatar
Ride:  1991 CRX Si
I'm at school chief.... plug I've got the #4 tonight.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 01-30-2007, 12:39 PM   #406
Beast
Kanned's Avatar
Ride:  Stuff
Rep Power: 72 Kanned has a reputation beyond repute
Kanned has a reputation beyond reputeKanned has a reputation beyond reputeKanned has a reputation beyond reputeKanned has a reputation beyond reputeKanned has a reputation beyond reputeKanned has a reputation beyond repute
Andrew, this has been the most entertaining thread I have ever set my eyes on. Great job on going through all the steps and what not and thanks for sharing. I just spent a lot of time reading this that should have gone towards work, but it was worth it. Very entertaining =D
Insert something clever here.
Originally Posted by boostedf22 View Post
Like I say, it just aint sex with out a little meat to beat
INJEN78: check your vtec juice
Spinal: my vtec juice..?
Kanned is offline   Reply With Quote
Old 01-30-2007, 12:52 PM   #407
Andrew's Avatar
Ride:  1991 CRX Si
Well thanks bro.
What part of Fl are you in?
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 01-30-2007, 02:13 PM   #408
Ride:  94 GSR Sedan
another #4...good job mang!
There is always afterwards though...I shoudl have had you make me a cd and I woudl have had them all uploaded by now..since I have nothing else better to do at work :P
Old 01-30-2007, 04:18 PM   #409
Beast
Kanned's Avatar
Ride:  Stuff
Originally Posted by Andrew View Post
Well thanks bro.
I'm down in Martin County, a 6-ish hour drive from Tally. I used to drive up there all the time, but my friend's sister just graduated from FSU. I still have some friends up there though, so I'll still be up there every once and a while. I wouldn't mind seeing the end result of that in person. I won't be going up there for probably another month or two. Plenty of time to make it more of a beast =P
Edit: I just read that and I know what you're thinking. Yes, I am a stalker =P
Old 01-30-2007, 05:50 PM   #410
Andrew's Avatar
Ride:  1991 CRX Si
Haha..... yeah.....
<shuts down computer and runs away>
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 01-30-2007, 10:19 PM   #411
Andrew's Avatar
Ride:  1991 CRX Si
Video of 1st startup:
And the "First Race":
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 01-30-2007, 10:20 PM   #412
Beast
Kanned's Avatar
Ride:  Stuff
Damn, my pickup lines suck... That's the second time this week! Yeah... that did come out a bit creepy, though. I guess I'm too outgoing for my own good. I'm a fucking social whore =P
Old 01-30-2007, 10:44 PM   #413
Andrew's Avatar
Ride:  1991 CRX Si
Heh, well, when you do come up into T-town, just shoot me a PM and I'm sure we could get a few fellow Ricers together for a little 'meet'.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 01-31-2007, 12:37 AM   #414
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Dude. pwn3d by the golf cart.
Old 01-31-2007, 01:02 AM   #415
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 337 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
score!
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 01-31-2007, 07:49 AM   #416
Andrew's Avatar
Ride:  1991 CRX Si
Oh, and I had a funny little problem today.
I checked the battery and it has a full charge, I didn't do anything under the hood but take off my intake to get a picture of the fuel line. The only thing I did, electronics wise, was unplug the Hazard fuse for a few seconds, and popped it back in to check my codes to make sure I wasnt throwing anything different than code 10.(IAT. I'm changing the plug out in the near future. Will it mess me up running with it not functioning right?)
What do you guys think?
This a pretty important issue fellas... Any ideas?
I'm gonna see if I can't try Abel's ECU and see if thats whats bad.
-But I've checked all my grounds, all my connections, and everything is OK.
-I started it up, let it idle for about 2 minutes, while I figured out which hose was leaking coolant
-shut it off
-pulled the Hazard fuse for a couple seconds
-jumped blue plug to check codes
-turn key and this happens.
To describe it the best I can:
The lights on the dash are 1/2 as bright as normal.
When I jump the blue plug to check codes, nothing changes. CEL does not go away [to blink]
And there is a real quiet buzzing noise under the dash. It sounds about like a quiet fuel pump would.
And my Walboro 255 isnt turning on(and trust me, you can hear it when it comes on. it's about twice as loud as my stock one).
Ideas???
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 01-31-2007, 07:55 AM   #417
Ride:  94 GSR Sedan
<chuckle> The golf cart turned out pretty good
I have to say, props to the camera man... he was incredible
Old 01-31-2007, 02:07 PM   #418
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Rep Power: 382 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
damn, i've missed alot in 3 days...
Andrew.. very nice build up thread, but i'm sure its nowhere even close to ending.. whos ever satisfied, i know i'm not
DO NOT PM ME WITH TECH QUESTIONS!
XGT: cEElint
Originally Posted by 93civicracer View Post
my dad owned a Chevelle with a hemi that he claimed made 600hp.
eg6sir is offline   Reply With Quote
Old 01-31-2007, 02:47 PM   #419
run a few tests on your fuel pump. first check the main relay and make sure it has continuity. If it does then check and see if you have power going to the fuel pump by turning the car to the on position (you don't have to turn it over) and check the harness under the rear seat. your going to need a wire diagram so you Know what wires to test I just used my helms manual. If your fuel pump is getting power but not pumping it is either a bad fuel pump or a bad connection somewhere. If the fuel pump is not getting power replace your main relay. that is everything I did when my fuel pump wasn't pumping I found that I had power going to the fuel pump but it wasn't pumping so I changed the fuel pump and still nothing I later found the ground that wasn't hooked up and she fired right up. hope this helps
-Kenny
Old 01-31-2007, 02:54 PM   #420
Führer Mod
eg6sir's Avatar
Ride:  Le Car
wouldnt your bay look nice w/ this.. hehehehe
XGT: cEElint
Old 01-31-2007, 03:12 PM   #421
Andrew's Avatar
Ride:  1991 CRX Si
Oh my... Now I need a new set of shorts... thanks.
-Kenny
Thanks bro. I just got off the phone with Abel and I'm gonna snag his main relay in a couple hours and try it out.
I've done the fuel-pump continuity check before, so I'll just do it again IF the main relay isn't it.
Thanks again fellas.
Oh, and btw eg6sir, of course it's not over.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 01-31-2007, 04:40 PM   #422
Andrew's Avatar
Ride:  1991 CRX Si
Diagnosed the problem-
Wierd eh? worked one minute, and literally didn't the next... how messed up is that?
Luckily, I've got a friend with an extra one laying around.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 01-31-2007, 05:41 PM   #423
Führer Mod
eg6sir's Avatar
Ride:  Le Car
XGT: cEElint
Old 01-31-2007, 05:59 PM   #424
Rep Power: 43 vtecsir1 will become famous soon enough
cool man looking good. glad its running for you. i always have a soft spot for the the rex since i started my driving with an 89 then a 91 si.
vtecsir1 is offline   Reply With Quote
Old 01-31-2007, 06:00 PM   #425
Andrew's Avatar
Ride:  1991 CRX Si
^ thanks man. I love these cars...
btw, thread update:
18 pages, 14,500 views, and a little over 400 posts...
wowzorz...
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Engine swap: d15b7 to d16y7; transmission? oakley2002@cox.net HYBRID -> EG-EK / DC 7 10-28-2009 07:19 PM
Best Engine Swap For 95 Integra Ls Agt_Orange_GSR HYBRID -> EG-EK / DC 7 09-23-2008 04:16 PM
EE crx engine swap. DAZ81 HYBRID -> ED-EF / DA 6 11-25-2003 10:21 AM
81 Civic Engine Swap Help fjcisco13 HYBRID -> EG-EK / DC 3 04-23-2003 06:16 PM
