Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Andrew's engine swap (pics)
Old 01-31-2007, 08:32 PM   #426
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
Well, I guess I was wrong.
I just plugged a different relay in there and it was doing the same thing.
I checked all the fuses, and the only one that was blown was the radio/cig lighter.
Tomorrow I guess I'll check voltage on the pump.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-01-2007, 04:14 PM   #427
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
did you check the starter fuse....top right in the cabin box
http://pandora.com/
Old 02-01-2007, 08:00 PM   #428
I wear stretchy pants
Taco15's Avatar
Ride:  chevy s-10
Rep Power: 199 Taco15 has a reputation beyond repute
Taco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
myspace
we got it working tonight. Turns out one of his friends grounded the ingine fuse panel box to a stud thatwas surrounded by plastic. The stud alone wasnt enough to juice up the fuel pump.
price we pay for having help.
Its fashion man. The chicks you see walking down the runway dont wear practical clothes, they were something that was designed to make a statement. THat statement in turns influences and shapes other peoples designs and ideas.
Same thing with cars. Except with no attractive women... and a lot more gayness.
Taco15 is offline   Reply With Quote
Old 02-02-2007, 07:56 AM   #429
Andrew's Avatar
Ride:  1991 CRX Si
No joke dude... I've had to fixed a handfull of things because of that.
Shoulda just done it myself
But yeah, we got it going. I'm still gonna have to fix that stupid coolant line(the 3" one on the heater hose valve), but thats it.
I gotta get this thing tuned!! Test 'n Tune at the 'strip is on the 16th!!!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-02-2007, 05:57 PM   #430
Andrew's Avatar
Ride:  1991 CRX Si
Went out there and beat on it some more. feels awsome.
KMS sent me a full spec list of what they did and what everything is(size wise)
Originally Posted by KMS
Stage 2 Head
Ultimate Valve Train
Cam
Head Kit
Pistons 11:1 75.50mm Bore
Lightened Fly Wheel
New Clutch
Crank Work
Oil Pump
Bottom End Kit
Boring
Assembly
Shot Peened Rods & Balance
Went through and rebuilt rocker arm assembly.
VALVE TIMING INFORMATION
Engine: Honda VTEC 1.6 Liter SOHC
Grind #: 498-513-461/13
Intake Exhaust
Valve Lash: .007 .011
Valve Lift: .365 .350
Duration: 271 235
Duration @ .020:
Lobe Center:
Intake Before Exhaust Before
Opens TDC Opens BDC
Intake After Exhaust After
Closes BDC Closes TDC
Valve Timing Is Checked With Zero Valve Lash
@ .020 Inches Of Valve Lift.
This site has a chart of S2 Stage 2 cams.
Says that peak lift is (in).306", (ex).297". That means my cam is more aggressive?
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-02-2007, 06:57 PM   #431
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 334 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
the bigger the numbers, the more aggressive the cam.
believe it or not, the stage 1 cam for my mirage is .350 .350 lol
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 02-04-2007, 12:45 PM   #432
formby's Avatar
it needs all the help it can get....
jk
http://pandora.com/
Old 02-04-2007, 12:48 PM   #433
:P
Old 02-04-2007, 02:45 PM   #434
Andrew's Avatar
Ride:  1991 CRX Si
Well guys, I've got some of the problems fixed, but I'm still leaking oil.
Low, by starter:
VTEC selenoid area:
Axles:
I know it's kinda hard to see the oil, cause it's so clean[i-thank-you], but maybe you guys get the idea...
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-04-2007, 02:52 PM   #435
Rep Power: 6 untitledsince89 is on a distinguished road
damn car looks SICK the wire tuck turned out great!
really clean crx over all nicely done
untitledsince89 is offline   Reply With Quote
Old 02-04-2007, 04:48 PM   #436
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Rep Power: 288 Calesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud of
I can't see the oil.
Old 02-04-2007, 05:09 PM   #437
Andrew's Avatar
Ride:  1991 CRX Si
Yeah, o well.. I'll see whats up sooner or later. maybe some better pics
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-04-2007, 06:17 PM   #438
Rep Power: 9 herminshs is off the scale
make sure that the head was properly toqued on the front side, by the vtec solenoid, have seen this happen to a lot of people.
herminshs is offline   Reply With Quote
Old 02-04-2007, 07:34 PM   #439
Andrew's Avatar
Ride:  1991 CRX Si
Yeah I'm working on getting a solid tune ASAP.
And I tried calling KMS today to make sure he torqued everything down , but he didn't answer.
Anyway, just another one of those things....
Luckily it's not a super bad leak
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-05-2007, 10:01 AM   #440
Andrew's Avatar
Ride:  1991 CRX Si
Yeah I looked at it a little more, and it looks like the back corner(by the vtec noid) is leaking a bit. WHEW!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-05-2007, 10:07 AM   #441
I trained Trogdor to pWn
mac_24_seven's Avatar
Ride:  94 GSR Sedan
Rep Power: 16 mac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura about
You gonna drive it to tifton this weekend?
mac_24_seven is offline   Reply With Quote
Old 02-05-2007, 11:46 AM   #442
Andrew's Avatar
Ride:  1991 CRX Si
No, probably not. It shakes pretty bad at about 70mph, so I'm gonna get the tires balanced again.
If I can fix that and the oil leak, yeah, I might, but it'll be a stretch
Today I'll check my valve cover gasket and see if that'll fix the oil leaking problem.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-05-2007, 03:58 PM   #443
my avatar is better.
Rep Power: 51 YouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to behold
Send a message via AIM to YouKnowWhoIBee
id say headgasket, i had to reseat mine and corrected the same leak. I went through 2 valve cover gaskets before i tried my headgasket. My old dseries was leak free after that.
YouKnowWhoIBee is offline   Reply With Quote
Old 02-05-2007, 04:07 PM   #444
Andrew's Avatar
Ride:  1991 CRX Si
I'll check the torque on them today, as well as clean the valve cover seal.
I'm tired of driving around and people thinking my headgasket it blown!! lol...
I just called KMS and he says, "I'd be very suprised if it is leaking, I use a 3 step torquing process and Hondabond on bottom and top"(of the HG).
So I don't really think it's the headgasket.
This is where I feel some of the oil(most of it is on the back of the block, dripping onto the exhaust..
It really is hard to tell where it's coming from, because where it is, its coming down onto the axle, and it's spinning it all over the block, so damn near everything is wet!
<sigh> time to crawl under there one more time...
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-05-2007, 04:36 PM   #445
Ride:  94 GSR Sedan
Why don;t you get some paper towels and tape it around where you think the leak is..maybe put a lil cover or something over the axle so it's not slinging oil onto the towel.
can you just sit and idle and it'll leak, or is it something that needs vtec engaged to leak?
Thats what I'd do if I were me.. er you.
Old 02-05-2007, 10:04 PM   #446
Andrew's Avatar
Ride:  1991 CRX Si
I'm pretty sure I identified the leaking thing- the VTEC solenoid. It had a crack in it, but I didn't realize it was leaking this bad until I wiped everything down and started up the car, crawled under it(ebrake, jack stands, and jack... ), and found that it was leaking pretty bad!
So I changed that with one from the junkyard, as well as a new IACV from the junker to hopefully take care of my rough idling problems, as well as it nearly stalling when under load(clutch in, off throttle after high RPM)
We'll see tomorrow whether that is the only oil leak. I'm pretty sure it is.
The only reason I kinda ruled out the VC gasket was because I looked all around it, and didn't see ANY dribble spots, no oil-paths, no nothing.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-06-2007, 12:21 AM   #447
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Rep Power: 366 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
goodluck on finding it.. i had one, it was my distributor o-ring
DO NOT PM ME WITH TECH QUESTIONS!
XGT: cEElint
Originally Posted by 93civicracer View Post
my dad owned a Chevelle with a hemi that he claimed made 600hp.
eg6sir is offline   Reply With Quote
Old 02-06-2007, 01:55 AM   #448
ceehris's Avatar
Ride:  1988 Civic LX>> D16Z6
Rep Power: 7 ceehris is on a distinguished road
lol some people are funny... the headgasket would be the last thing I would suspect.
its 3 dollars for a little bottle of engine oil and dye and u can find a highwattage black light bulb and put it in an old school trouble light that takes bulbs.
10-15$ cost to diag, assuming you have a older trouble light, and comes in handy often as oil+seals+time=leaks!
ceehris is offline   Reply With Quote
Old 02-06-2007, 07:39 AM   #449
Andrew's Avatar
Ride:  1991 CRX Si
Bingo!
VTEC solenoid was the ticket!
And I also changed the IACV and that pretty much took care of the low/sparatic idle, and now it doesnt die when I rev it up and then let off.(putting it under load)!
Yet your right bro, I think theres a guy thats gonna tune it pretty soon, and I KNOW I need it... bad!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-06-2007, 08:57 AM   #450
cool andrew. enjoy it
Engine swap: d15b7 to d16y7; transmission? oakley2002@cox.net HYBRID -> EG-EK / DC 7 10-28-2009 07:19 PM
Best Engine Swap For 95 Integra Ls Agt_Orange_GSR HYBRID -> EG-EK / DC 7 09-23-2008 04:16 PM
EE crx engine swap. DAZ81 HYBRID -> ED-EF / DA 6 11-25-2003 10:21 AM
81 Civic Engine Swap Help fjcisco13 HYBRID -> EG-EK / DC 3 04-23-2003 06:16 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
