Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Andrew's engine swap (pics)
Old 02-06-2007, 10:57 AM   #451
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Rep Power: 382 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
niiiccee.... after its tuned, post some vids of it in action... i wanna hear that single cam scream.. lol
DO NOT PM ME WITH TECH QUESTIONS!
XGT: cEElint
Originally Posted by 93civicracer View Post
my dad owned a Chevelle with a hemi that he claimed made 600hp.
eg6sir is offline   Reply With Quote
Old 02-06-2007, 01:13 PM   #452
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
Speaking of tuning, I just contacted Central Florida Tuning about their dyno tuning services, and got a quote from them($395 for a tune, no matter how long it takes, or how many dyno pulls they make, until it's perfect).
I guess thats what the next paycheck is going towards!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-06-2007, 03:15 PM   #453
I trained Trogdor to pWn
mac_24_seven's Avatar
Ride:  94 GSR Sedan
Rep Power: 16 mac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura about
You should see if you got somebody to go with you (ahem ahem) and they brought their car (caugh, mine) .. If they woudl give a lil bit of a discount...
Thoughm you'd probably go before I got all my stuff together
mac_24_seven is offline   Reply With Quote
Old 02-06-2007, 03:25 PM   #454
Andrew's Avatar
Ride:  1991 CRX Si
I just got off the phone with CFT, and he said that they would indeed give a discount!
Since my ECU is already chipped, it would normally be $395. discount- $350
Since your ECU isn't chipped, it is normally $495. discount- $450
Eddie charged me $80 to chip it, so it's right on the money(especially for a big-name company vs. a friend)
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-06-2007, 03:34 PM   #455
Ride:  94 GSR Sedan
Actually.. I'm working on getting my ECU chipped
And we shoudl see if we can get anybody else to go with us...Shame your not on TI anymore :P n00b
Old 02-06-2007, 03:41 PM   #456
Andrew's Avatar
Ride:  1991 CRX Si
I could probably make another account on there if I wanted. They didn't IP ban me, hence the reason I can log into your account and see everything, and talk s**t...
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-06-2007, 04:05 PM   #457
Chopped N' Screwed.
EGProject's Avatar
Ride:  SE-R Spec V
Rep Power: 47 EGProject is a name known to allEGProject is a name known to allEGProject is a name known to allEGProject is a name known to allEGProject is a name known to all
Send a message via AIM to EGProject
Trick with the valve cover gasket. Use some RTV or Hondabond on the corners where the gasket meets at an angle. It sometimes doesn't seal right, and a little oil leaks out. My VG on my Mini-me leaked for a while until I figured it out.
Originally Posted by E_SolSi View Post
had this happened in the US, our government would have extinguished the burning car by heaving truckloads of money onto the flames...
EGProject is offline   Reply With Quote
Old 02-06-2007, 07:07 PM   #458
Andrew's Avatar
Ride:  1991 CRX Si
Thanks for the tip, but all 4 corners were sealed from the get go!
I've been driving the car all day(about 20-25 miles total), and everything is looking good. No oil leaks, no coolant leaks, no nada!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-06-2007, 07:51 PM   #459
Rep Power: 38 NissanNiNjA2nd is a name known to allNissanNiNjA2nd is a name known to allNissanNiNjA2nd is a name known to allNissanNiNjA2nd is a name known to allNissanNiNjA2nd is a name known to all
PIMP PIMP PIMP PIMP PIIIIIIMP!!!!!
Numbers STAT!!!
NissanNiNjA2nd is offline   Reply With Quote
Old 02-07-2007, 07:39 AM   #460
Andrew's Avatar
Ride:  1991 CRX Si
Heh, soon enough dude, soon enough.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-08-2007, 06:32 PM   #461
Andrew's Avatar
Ride:  1991 CRX Si
Well, I showed up to school a little early and snapped some super-unprofessional photo's.....
... Then found out why my IAT was throwing a code...
...Then fit my 320lb friend into it...
Then pulled the plugs to find out I'm running good! not too lean, not too rich...
+1 on it running, but I need to get exhaust, intake mani, and get it tuned...... BAD
This stock exhaust is KILLING me!!!
Oh, EDIT:
I also scared my buddy with my OOGA horn...
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-08-2007, 06:35 PM   #462
Führer Mod
eg6sir's Avatar
Ride:  Le Car
muffler shop 2 1/4 piping w/ Dynomax muffler..
XGT: cEElint
Old 02-08-2007, 08:03 PM   #463
I wear stretchy pants
Taco15's Avatar
Ride:  chevy s-10
Rep Power: 217 Taco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
Taco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
myspace
thats what i have on my blue crx Andrew. I swear my car is off when i'm in neutral. Its so quiet.
I alsi see your still running the old p28. Good thing its working pretty good for ya
Its fashion man. The chicks you see walking down the runway dont wear practical clothes, they were something that was designed to make a statement. THat statement in turns influences and shapes other peoples designs and ideas.
Same thing with cars. Except with no attractive women... and a lot more gayness.
Taco15 is offline   Reply With Quote
Old 02-08-2007, 08:10 PM   #464
Führer Mod
eg6sir's Avatar
Ride:  Le Car
same here.. it only gets loud when i stomp on the gas..
XGT: cEElint
Old 02-09-2007, 07:47 AM   #465
Andrew's Avatar
Ride:  1991 CRX Si
I'm actually running around on Abel's tuned p28. It's not tuned exactly to my setup, but it's good enough for the girls Abel goes with..
I have a custom mapped p28(mine), but it looses MAD power on anything over 5k.. Plus idles a little rough, so luckily I've got Abels to mess around with 'till I get mine tuned.
I know 2 1/4 piping is usually best for mild NA motors, but was wondering if should actually I should go with a little bigger piping(2 1/2) because it's crush bent, going to a 2 1/4 muffler?
As far as mufflers, yeah, Dynomax, magnaflow, etc. which ones best?
ANYTHING is better than stock exhaust... shoot, I'll just run straight 2 1/4 from the header back!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-09-2007, 10:04 AM   #466
Ride:  94 GSR Sedan
NO!
Stock is the best.. So quiet.. Mnnnnnn. Yummy.
And we've got to go terrorize Tally again w/the OOga.. Except get it all on video
Old 02-09-2007, 11:21 AM   #467
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
2.25 all the way back
use magna flow like these
buy from these guys
eBay Store - Griffin's Mustang Source: Suspension - Shocks Struts, Hawk Brake Pads, Exhaust - Catalytic Converters
1 round muffler
http://store.summitracing.com/partdetail.asp?autofilter=1∂=MPE%2D 14445&N=700+4294922710+4294788249+1 15&autoview=sku
and 1 oval
http://store.summitracing.com/partdetail.asp?autofilter=1∂=MPE%2D 11225&N=700+4294922710+4294788249+1 15&autoview=sku
this is what i used on my lsv just 2.5" and an oval turbo II muffler from autozone [per ables advice]
this is a vid of what it sounded like [the pulsing throttle is mine]
Video - me at bithlo
i also ran the exaust out of the side
http://hondaswap.com/attachments/670...446-ek-013.jpg
http://pandora.com/
Old 02-09-2007, 11:56 AM   #468
Andrew's Avatar
Ride:  1991 CRX Si
So... you ran the round and oval one in series? for a quieter setup or what?
Ground clearance problems on the oval? (not fitting in the 'channel' under the car)
And how did you like the side exhaust(dumping in front of the rear tire I assume)?
Did the car look a little funky with nothing back there?
Originally Posted by mac_24_seven View Post
NO!
Quiet, yes, but NO POWER can me had with it! You can tell by the throttle response that the motor is being choked.
Plus, if I ran two mufflers in series, it would still be really quiet... however, I don't know if thats the best thing to do, flow-wise..
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-09-2007, 12:19 PM   #469
Führer Mod
eg6sir's Avatar
Ride:  Le Car
the Dynomax is a little quieter than the Magnaflow, because its not a straight through design.. i'll take a video clip of mine and post it later..
XGT: cEElint
Old 02-09-2007, 12:38 PM   #470
Andrew's Avatar
Ride:  1991 CRX Si
I'd appreciate it bro. Thanks
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-09-2007, 12:45 PM   #471
Führer Mod
eg6sir's Avatar
Ride:  Le Car
i had a magnaflow w/ 2 1/4 on my 89 SI .. dont get me wrong, it sounded really good.. but i like the dynomax better..
XGT: cEElint
Old 02-09-2007, 12:45 PM   #472
formby's Avatar
it was put in series because i chose to have it out of the side. and there was no other place.
Ground clearance problems on the oval(not fitting in the 'channel' under the car)
the oval muffler will fit if you get the offcenter/center muffler
if i could do it again i would get 2-3 inline round mufflers and just go straight back no bends
it was great, i liked the fact that i had no fart can back there. and it sounded great. no bee sound and little to no drone sound
http://pandora.com/
Old 02-09-2007, 12:53 PM   #473
Andrew's Avatar
Ride:  1991 CRX Si
You mean just straight back, then get a little piping pointing it down? Just before the 'channel' of the car starts to turn toward the L-Rear wheel?(maybe at a 45*)
Sounds like a neat idea...
Thats what I'm looking for.
Hopefully this will do the trick.
So you think if I do 2 Dynomax mufflers(2 1/4") with a little piping, dumping it right where I said up ^ there ^... sound like a good setup?
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 02-09-2007, 12:59 PM   #474
formby's Avatar
i would keep the piping going all the way to the back by the center tow hook.
ive seen that set up on the jun crx. in an old vid.
kinda like this pic just no turn all they way back staright
http://www.invoauto.co.uk/images/Pro...rx-sw3-lrg.jpg
http://pandora.com/
Old 02-09-2007, 01:41 PM   #475
Andrew's Avatar
Ride:  1991 CRX Si
I was thinking of having it dump right where the bend starts.
That way you don't see ANY piping, and you don't have to worry about ground clearance because of the exhaust going right under the fuel tank.
(dang, i just got to thinking about that, I guess I wouldnt want my exhaust popping flames right before my fuel tank either... hmm...)
I think I want to run 2 1/4 piping to a Dynomax muffler, then bend it to dump on the side, just like your setup Formby. If it's not quiet enough, I'll just pick up another dynomax muffler and have it install right behind the 1st one.
Sound like a plan?
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Engine swap: d15b7 to d16y7; transmission? oakley2002@cox.net HYBRID -> EG-EK / DC 7 10-28-2009 07:19 PM
Best Engine Swap For 95 Integra Ls Agt_Orange_GSR HYBRID -> EG-EK / DC 7 09-23-2008 04:16 PM
EE crx engine swap. DAZ81 HYBRID -> ED-EF / DA 6 11-25-2003 10:21 AM
81 Civic Engine Swap Help fjcisco13 HYBRID -> EG-EK / DC 3 04-23-2003 06:16 PM
