#754 |
Ride: 1991 CRX Si
Yeah you can definatly see where my car made up for my bad lauch in the top end.
You can see where my "4k launch" one is a little closer to your pass. Thanks for posting up man. GL with your car! |
#756 |
Ride: 1991 CRX Si
I'm running es100's, too. 195/50/15's. They had about 1,500 miles when I ran.
I had some bad wheel hop issues too. especially on the launch, I had to back off a lot, hence my 2.6 60ft's. Sounds like our setups are pretty similar! ![]() |
#759 |
I trained Trogdor to pWn
Just to keep his lil thread goin.. Andrew and I played some this weekend.
First from a dig.. I got the jump on him and it stayed that way untill we stopped. He was about at my door. I wasn't pulling on him nor was he catching me. Second run, from a roll.. Low MPH, around 10-15.. He squirted ahead of me, I was at his door, at the launch. It was identical after that.. Untill I missed 3rd I never miss too Feel pretty stupid ![]() I think I was either spinning on my part( doubt it) or it was the uber awesome d16 torque coupled with being 600 lbs lighter that made the difference from the roll. Lots o' fun Stats are 1-1 for both of us ![]() __________________
1994 Acura Integra GS-R Sedan My MAIN DB8 project thread on Honda-Tech: Very detailed of EVERYTHING I've done to my car. Contact me for ITR header skid plates: $40.00 shipped!!! |
#761 |
Führer Mod
my bone stock 89 SI non-vtec would run even w/ 99-00 SIs..
#762 | |
#763 |
Führer Mod
nope.. d16a6 block w/ z6 head
#765 | |
![]() Frankly, I don't believe you. Why? Because Andrews car BEFORE the engine swap and build would have been raped by his car NOW. Matter of fact, we did race before and I pulled on him and never stopped pulling until we let off. Thats when he was stock. You may have kept up with a n00b who had a lousy car, but you can't say you can hang with low - high 15 second cars.. Not with you being stock. **Edit** Matter of fact... Show us a time slip with you all nice and stock running mid 15's. |
#766 | |
Ride: 1991 CRX Si
Plus he has a blown headgasket. weak GSR > stock D16A6 I think I have some plans up my sleeve that will assist me in killing many GSR's... ![]() Turbo D action anyone??? |
#767 | |
![]() And yes, if you stick to your plan, you will kill many GSR's |
#768 |
92CivicHatchCxBORNINCALI
Mabye you ought to change the head gasket huh. THATS WHAT I WOULD DO!!!
LOL ![]() __________________
If you find my info helpful plz leave rep. (\__/) (O.o ) ( >< ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination! |
#771 | ||
You have a swap, thats different. Compaing yourself to Andrew, thats one thing because yoru cars are similar weights. Comparing your car to mine, thats different.. I dare say I've got over 800 lbs on you. 40 HP more, yes, but ANdrew can attest, since he was in the car, my buddy in a SVT Focus pulled on me with Andrew riding and I pulled on him whenver it was just me. Thats 150 lb difference cost me almost 2 tenths that run. Quote:
I need: $90.00 for new valve springs $95.00 for the head gasket kit $100.00 for cam gears $100.00 for chipping/tuning $100.00 for dyno time. I'll do it next week if you paypal me the money ![]() __________________
#772 |
Ride: 1991 CRX Si
We were saying stock motor/car(like my SI was when the A6 was in it.)
I thought you meant your stock CAR, not a swapped stock motor. my bad Edit: dang you Terrance your too fast. |
#775 | ||
Ride: 1991 CRX Si
Update 6/6/07:
I talked with KMS and got my compression information I was looking for. 10.5:1 pistons, and they took the other .5:1 off of the head. I want to go boost now. ![]() I think it'd be cool to have my compression close 10:1 or a little less. Want to have high(er) compression and low(er) boost. Options: A. Pull the head off and install a thicker cometic head gasket. B. Pull these pistons out and install some lower comp ones. C. Find a different head(not decked as much as mine), and do a butt-load of work porting/polishing/swapping valve train. The head gasket would obviously be my first choice. Need some imput! Heres some info from Cometic's site. Quote:
Stock Z6 is 0.036". Stock B7/A6 is 0.048". But can I use an A6 HG on a vtec head?? I also found this site: Honda Head Gasket | Always In Stock They show their Mr. Gasket HG's to be Quote:
Thoughts? Suggestions? Comments?? Thanks guys -Andrew __________________
1991 CRX Si 2007 Civic Si Sedan My Engine Swap Write-ups: HG FPR Wheel Smiley Cluster. Adapters. Last edited by Andrew; 06-06-2007 at 12:18 PM. |
| Engine swap: d15b7 to d16y7; transmission? | oakley2002@cox.net | HYBRID -> EG-EK / DC | 7 | 10-28-2009 07:19 PM |
| Best Engine Swap For 95 Integra Ls | Agt_Orange_GSR | HYBRID -> EG-EK / DC | 7 | 09-23-2008 04:16 PM |
| EE crx engine swap. | DAZ81 | HYBRID -> ED-EF / DA | 6 | 11-25-2003 10:21 AM |
| 81 Civic Engine Swap Help | fjcisco13 | HYBRID -> EG-EK / DC | 3 | 04-23-2003 06:16 PM |
