#1027 |
Ride: 1991 CRX Si
I just messaged him, so I'll let you know when he's done with the manifold.
What do I offer for a custom built log mani with a 38mm wastegate?? I just threw $150 out there as a starting price, but I have a feeling he'll want around $200/$250/more.. Although he's pretty reasonable.. He said $450 shipped for the Ramhorn w/ wastegate flang and all.... __________________
1991 CRX Si 2007 Civic Si Sedan My Engine Swap Write-ups: HG FPR Wheel Smiley Cluster. Adapters. Last edited by Andrew; 09-05-2007 at 10:05 AM. |
#1029 |
Ride: 1991 CRX Si
I never said I wasn't... I just said maybe I'll save my money for now to get another car.
But, yeah, I'm buying parts. ![]() These girls are getting too close... I'm gonna go ahead and get this car stuff out of my system ![]() __________________
1991 CRX Si 2007 Civic Si Sedan My Engine Swap Write-ups: HG FPR Wheel Smiley Cluster. Adapters. Last edited by Andrew; 09-05-2007 at 12:23 PM. |
#1030 |
Sonnova Bitch!
Ride: 2006 GSX-R 600, 2003 Santa Fe GLS
I love girls
http://davesstainedglass.webs.com/ |
#1031 |
I trained Trogdor to pWn
The urge to pet is strong. Resistance, unfortunately, is futile.
**Edit** Reference avatar.. Thats what I'm doin to page 43 __________________
1994 Acura Integra GS-R Sedan My MAIN DB8 project thread on Honda-Tech: Very detailed of EVERYTHING I've done to my car. Contact me for ITR header skid plates: $40.00 shipped!!! Last edited by mac_24_seven; 09-05-2007 at 01:45 PM. |
#1035 |
Yeah
haha no ill take a honda over a mustang any day lol
and i know what ur saying haha __________________
"It's not what you drive, but how you drive it." XBL Gamertag= W0BBnIT <---- 0 is a Zero |
#1036 | |
If I can't get my car into the 14's or if I'm not CLOSE to 170 hp when I get dyno'd... I don't think I'll put another penny towards performance in my GSR. __________________
1994 Acura Integra GS-R Sedan My MAIN DB8 project thread on Honda-Tech: Very detailed of EVERYTHING I've done to my car. Contact me for ITR header skid plates: $40.00 shipped!!! |
#1038 |
I'm gonna give Max a chance to do his stuff...
If it doesn't work out, I'll paint it and let you and Eli play with Honda's... I'll be out of the import game. It would no longer be my toy. Thats how disappointed and pissed off I am at my car and the build. |
#1039 |
Führer Mod
its a Sedan and heavy as fuck.. what do you expect it to run??
#1040 |
I cannot recount how many slips I've seen over stock GSR's either in the low 15's or high 14's. I'm not asking for 12's or anything unrealistic.. I just want to run what I should run and not be slower than what I was w/only a freaking header and a blown headgasket.
And I don't consider 27xx lbs that heavy, considering it only weighs less than 100lbs more than the coupe. |
#1041 |
Führer Mod
to me thats heavy... my car weighs about 2094 lbs in stock form.. Civic VX FTW!!
#1043 |
Ride: 1991 CRX Si
I believe it was Terrance that told me that 100lbs is about equal to 1/10th of a second.
But all this talk about his car being heavier doesn't explain why his trap speed is the same. |
#1044 |
Running on two cylinders
Ride: 2000 Mitsubishi Lancer RPW E5 Coupe
still heavy :P
Home of the RPW built 2000 Lancer CC Coupe. See what is done to the little Evo5. "If you don't like what I've done with my car, I will gladly refund all the money you put into it." |
#1045 |
Sonnova Bitch!
I could be imagining things, but when I put my subs and passenger seat back in, it seemed like my car had a slight lag, but definitely noticeable, and when I have a passenger, well yeah.
#1046 |
Ride: 1991 CRX Si
Ok, enough weight talk.
I read a neat little article on stealthmodeperformance.com about DIY Alignment. It inspired me to go ahead and make sure my traction bar is set right. that way it eliminates the traction bar being at fault. I've got the drivers side axle out right now. I also pulled the rear mount out completely and am going to grind/cut/beat in the rear crossmember to give the rear mount some more room(it was touching. I didn't do it when I did the swap b/c the Civic I pulled the B16 out of didn't have it done, so i didn't think I needed to, and I just plain forgot. )I haven't worked at all this week, and I still haven't had any time to work on the car very much. I'll take some pics this weekend as I do more work. |
#1047 |
Ride: 1991 CRX Si
Update:
I trimmed the rear crossmember and beat it in for some extra clearance: ![]() ![]() And I now have both axles in(new ones). I guess it just needed time to sit there and think about it's life before it wanted to go in, because it just popped in and I didn't seem to have any trouble. GRR!! ![]() ![]() ![]() Then I gave the car a gooooood cleaning. Eveything but vacuuming: ![]() ![]() ![]() ![]() ![]() This one's for Terrance: Are you happy now? Got the MP3 in and tuned. Sounds good. however I still can't get the rear pre-amps to work. maybe it's something with my amp. idk.![]() |
#1048 |
Sonnova Bitch!
looks sexy. super sexy. I used to have the fatty's on mine, I loved them but they later paid some bills for me lol.
#1049 |
Ride: 1991 CRX Si
Heh, yeah I like 'em. I woldn't mind changing them out for some Rota's again or something, but I like how thy look OEM.
I'm still having the wierd problem, so I'm not driving it now. but I'm going to try that DIY alignment probably today and see if that helps any. Then I'm going to take apart my EX knuckles/DA front brakes and prep them for sand blasting(I'll do it myself at school) and painting, followed by new wheel bearings/ball joints. pics lata! |
#1050 |
Thank you.
And it must be the amp.. We'll check it out next time your down here or I'm up there. Enj0y 160+ songs on one cd now ![]() __________________
| Engine swap: d15b7 to d16y7; transmission? | oakley2002@cox.net | HYBRID -> EG-EK / DC | 7 | 10-28-2009 07:19 PM |
| Best Engine Swap For 95 Integra Ls | Agt_Orange_GSR | HYBRID -> EG-EK / DC | 7 | 09-23-2008 04:16 PM |
| EE crx engine swap. | DAZ81 | HYBRID -> ED-EF / DA | 6 | 11-25-2003 10:21 AM |
| 81 Civic Engine Swap Help | fjcisco13 | HYBRID -> EG-EK / DC | 3 | 04-23-2003 06:16 PM |
