Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Andrew's engine swap (pics)
Old 10-08-2007, 12:04 PM   #1226
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
It's just braided hose you buy at Home Depot or Lowes. The only advantage to it is you can see what your blow-by is looking like. BTW try not to use it on coolant lines unless you've got some good hose clamps on it. It can/will slip off if your not careful about installation.
Oh, BTW guys, DYNO Day this Saturday! (10/13)
Gonna see what this stock B16 puts down.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-08-2007, 12:50 PM   #1227
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 189 BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
myspace
Yeah I know what it is, I used to sell it all the time when I worked at True Value. I just couldn't think of what it was called at the moment. And yeah, I was wondering about the lack of hose clamps on Terrance's install...I guess the breather hose and reservoir tank aren't really in danger of blowing off though.
SWEET! Be sure to get some pics or vids if you can. I'm eager to see what kind of numbers you're making with the ITR header on there.
PSN Network ID: BrutalB83
Old 10-08-2007, 12:57 PM   #1228
I trained Trogdor to pWn
mac_24_seven's Avatar
Ride:  94 GSR Sedan
Rep Power: 16 mac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura about
Noe, no danger of them blowing off, thus why there isn't a hose clamp on em. And, FWIW, I hate those hoses and did have one rupture that had coolant going through it They expand and split.
And Andrew, you want one of these too? I forgot to put the dip stick hole in it, but it'll be on the next one.
http://i202.photobucket.com/albums/a...MVC-003S-2.jpg
Just picture it cleaned up and polished or at least much shinier :P
1994 Acura Integra GS-R Sedan
My MAIN DB8 project thread on Honda-Tech: Very detailed of EVERYTHING I've done to my car.
Contact me for ITR header skid plates: $40.00 shipped!!!
mac_24_seven is offline   Reply With Quote
Old 10-08-2007, 02:36 PM   #1229
Andrew's Avatar
Ride:  1991 CRX Si
^^ Thanks man
I'd like to get a DC sports or something(ugh... don't ask... you called it man.. no money left for turbos right now. just wait till I start playing with aircraft lol)
If you can make one out of Diamond Plate...... would look SWEET with the DPlate wire-cover!!!
Do you think the bolt pattern is the same on the ITR as it is the B16 cast one? doubt it.. i can measure the distance between them and stuff... maybe it's the same.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-08-2007, 04:16 PM   #1230
1595cc's of Mad Fury
humblegumbo's Avatar
Ride:  1991 CRX Si (aka Black Betty)
Rep Power: 16 humblegumbo is a jewel in the roughhumblegumbo is a jewel in the roughhumblegumbo is a jewel in the roughhumblegumbo is a jewel in the rough
Andrew, nice nip tuck!
mac_24_seven, brite red VC? LOL, you rice cooker trash you! Although, it does look nice. What kind of paint did you use for that? Rattle can, I assume...is dat sum rustoleum?
Originally Posted by klyph View Post
Looks good, a brushed aluminum oil cap would really set it off.
x3
Originally Posted by Blanco View Post
I used to roll with and around killers. End of argument.
Cubert J. Farnsworth: That's impossible. You cannot travel faster than the speed of light.
Professor Hubert Farnsworth: Exactly. That's why scientists increased the speed of light in 2209.
humblegumbo is offline   Reply With Quote
Old 10-09-2007, 11:24 AM   #1231
Ride:  94 GSR Sedan
mac_24_seven, brite red VC? LOL, you rice cooker trash you! Although, it does look nice. What kind of paint did you use for that? Rattle can, I assume...is dat sum rustoleum?x3
Rice red FTW! :P But my bering uber cool makes its ok And yes, rattle ran red.. not rustoleum but Duplicolor. Great paint.. Used it on many things.
Andrew, what are you doing to prep yoru car for t3h d1n0? You gonna do what I did and run one as is and then remove the PS and filter or what?
Maybe you should just pull the power steering so we can see how much diffrence that makes.
You gonna change the spark plugs and stuff.. a lil tune up before?
Old 10-09-2007, 11:56 AM   #1232
Andrew's Avatar
Ride:  1991 CRX Si
Power steering? newbie...
I'd like to change my oil, sparkplugs and wires, but I just can't afford it ALL right now.
I'll do plugs and oil. I've got the K&N filter from my D thats pretty fresh, so I'll just put that on the B.
And my filter is in my bumper, so I won't take it off.I'll just run it as-is on run #1, and I'll index my plugs on #2. That way we'll see if it makes any difference.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-09-2007, 12:53 PM   #1233
Ride:  94 GSR Sedan
Ahh geez.. I forgot your car sucks and doesnt have PS :P
What a n00b I am.
You're not gonna have time to index the plugs between runs man.. That would take several minutes to do... Tonys not gonna allow that.
**Edit** Here's your cover mang!
You like?
Old 10-09-2007, 03:42 PM   #1234
Sonnova Bitch!
daveholiday's Avatar
Ride:  2006 GSX-R 600, 2003 Santa Fe GLS
Rep Power: 44 daveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud of
Send a message via AIM to daveholiday  FaceBook
that, is sex
daveholiday is offline   Reply With Quote
Old 10-09-2007, 04:02 PM   #1235
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Rep Power: 366 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
meh..
DO NOT PM ME WITH TECH QUESTIONS!
XGT: cEElint
Originally Posted by 93civicracer View Post
my dad owned a Chevelle with a hemi that he claimed made 600hp.
eg6sir is offline   Reply With Quote
Old 10-09-2007, 04:25 PM   #1236
Now, normally I would not knock the diamond plate...it just doesn't feel right there. Like there's no DP anywhere else in the bay & it seems like total overkill just to hide some wires. Mayb I just got used to the plain sheet metal in the other pics.
Is the header shield going DP too?
Also, power steering is for girls.
Old 10-09-2007, 04:35 PM   #1237
Rep Power: 14 91_civic_si has a spectacular aura about91_civic_si has a spectacular aura about
looks good, you just need some contrast with the red. Maybe sand down the tops of the letters on valve cover and just like everyone else says "Get a different color oil cap".
91_civic_si is offline   Reply With Quote
Old 10-09-2007, 04:37 PM   #1238
Sonnova Bitch!
I like the diamond plate, as mentioned before, but I do see where it is kinda overkill..
Old 10-09-2007, 05:24 PM   #1239
Citizen_Insane's Avatar
Rep Power: 51 Citizen_Insane will become famous soon enough
Send a message via AIM to Citizen_Insane
Diamond plate anywhere on a car looks stupid, put a stock wire cover on it.
No tech questions through PM please!
B16 CRX....you will be missed
Citizen_Insane is offline   Reply With Quote
Old 10-09-2007, 05:51 PM   #1240
Andrew's Avatar
Ride:  1991 CRX Si
I love how it looks man!
Diamond plate wire cover and matching heat shield, polished oil cap, and a fresh colored valve cover would look HAWT!!
Thanks T-rex
I'll get it from ya this Saturday I guess! Maybe you'll have some time to whip up that heat shield, too.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-09-2007, 08:27 PM   #1241
Dismember
Ride:  Whatever i can get behind the wheel of
Rep Power: 242 klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
Diamond plate hood or ban.
klyph is offline   Reply With Quote
Old 10-10-2007, 12:38 AM   #1242
^^ x2!
Old 10-10-2007, 07:36 AM   #1243
Andrew's Avatar
Ride:  1991 CRX Si
Hmm..... Terrance! Get me a hood, G!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-10-2007, 08:08 AM   #1244
Ride:  94 GSR Sedan
Ya know....
:P
If I had the equipment, I COULD make a diamond plate hood. It wouldn't be as hard as you think it would be.
I just don't have access to a machine that can roll that big of a piece of metal.
Old 10-10-2007, 08:12 AM   #1245
Andrew's Avatar
Ride:  1991 CRX Si
I would SO sport some DP!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-10-2007, 12:22 PM   #1246
Sonnova Bitch!
I second that. Vented too. If you could, I'd definately buy one.
Old 10-10-2007, 12:57 PM   #1247
Maybe you guess should check out the ford zx2 escort in super street readers rides with diamond plate grille with diamonds cut in it. I bet you would change your minds about diamond plate anywhere on the outside of a car.
Old 10-10-2007, 03:57 PM   #1248
Andrew's Avatar
Ride:  1991 CRX Si
If I could Diamond plate an entire car, I wouldn't!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-10-2007, 10:43 PM   #1249
Sonnova Bitch!
its also on a totally different car on a different part of the car. And who would cut diamonds into diamond plate anyway?
Old 10-11-2007, 12:50 AM   #1250
Your search - "diamond plate honda" - did not match any documents.
Well, at least you'd be the first to do it. Might come in handy if you live in an area prone to natural disasters....
Although, I did find this:
...which may get you more excited than it should.
Engine swap: d15b7 to d16y7; transmission? oakley2002@cox.net HYBRID -> EG-EK / DC 7 10-28-2009 07:19 PM
Best Engine Swap For 95 Integra Ls Agt_Orange_GSR HYBRID -> EG-EK / DC 7 09-23-2008 04:16 PM
EE crx engine swap. DAZ81 HYBRID -> ED-EF / DA 6 11-25-2003 10:21 AM
81 Civic Engine Swap Help fjcisco13 HYBRID -> EG-EK / DC 3 04-23-2003 06:16 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
