Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Andrew's engine swap (pics)
Old 11-01-2007, 02:17 PM   #1326
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
All you need to paint is the hood and gas door cap.
Paint 'em gloss black and wax the entire car. Get the body lines straight and that thing will look pretty sexy.
BTW guys. Tell me what you think of this side-skirt/front lip combo. It's the Password front lip and Xenon sides:
I think it looks HOT.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-01-2007, 03:24 PM   #1327
Honda Master Technician
norcalgsr's Avatar
Ride:  88 Prelude Si and a CBR 600 Hurricane
Rep Power: 21 norcalgsr is a jewel in the roughnorcalgsr is a jewel in the roughnorcalgsr is a jewel in the rough
myspace
That's a really nice look I like it
Do not PM with tech questions without providing a link to your topic on the forums. This way everyone has access to the information..
norcalgsr is offline   Reply With Quote
Old 11-01-2007, 03:29 PM   #1328
I trained Trogdor to pWn
mac_24_seven's Avatar
Ride:  94 GSR Sedan
Rep Power: 16 mac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura about
CRX's are such sexy lil beast machines.. The one above is no exception either. And I like the paint scheme too.
Question is... Will t3h m3gg13 like it?
Other than that, it's tits<---------------First time I've used that phrase. Just trying it out for size
mac_24_seven is offline   Reply With Quote
Old 11-01-2007, 09:42 PM   #1329
Andrew's Avatar
Ride:  1991 CRX Si
Update on today's progress. I've got a bunch of little things I've been working on... painting the valve cover, swapping out the front crossmembers, finishing the wire tuck, axle binding-troubleshooting/repair... etc etc.
Here's the latest:
Valve cover:
Looking good! I'll wetsand it and hit it with a final coat and that'll be it. The color is kind of "boring", but I think it'll look alright. I can always change it. If I do, I'll probably powdercoat it instead of painting.
Front crossmember: Got the stock one back on. (sucks don't it?)
And you can see here where I had to cut up and beat in the radiator supports.
Firewall plugs. For those that are too cheap to get the Honda block-off grommets. lol.
First off get some sheetmetal:
Paint it black on one side:
And install.
Wire Tuck : Made LOTS of progress today. Got the harness finished and installed! That means the engine bay wiring is DONE except for blocking off the heater core coolant lines. I sent all of the wiring through the heater hoses grommet. Much cleaner and Much more professional looking than my original. (Almost no electrical tape except for every 6" or so on the wire-tubing.
Interior shot. Got a bit more stuff to do, but this is the easy part.
E-Bay. You can see it coming out of the heater hole...
I know, I know... get rid of the nasty stock fuel filter... Well it's got to stay for a little while longer... I think I'm waiting on getting another fuel rail with a -6an opening so I can install my stock one back in. The problem is, I don't wanna spend $100 on a freakin fuel rail.
All put back together! (minus a valve cover... )
Axles.
I've determined I need to run the 86-89 axles. At least on the drivers side, since it's the one that seems to be binding(just turning by hand). My question:
Will an '86-'89 Integra LS axle fit into a '90-93 midshaft?
Thanks guys.
-Andrew
BTW Terrance, who cares what your wife thinks?!?!?
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-01-2007, 10:25 PM   #1330
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 189 BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
myspace
Actually, it looks like the valve cover will be a pretty close match to the intake.
PSN Network ID: BrutalB83
Old 11-02-2007, 03:00 AM   #1331
Mid-life Crisis Swap
Ride:  92 Hatch w/GSR swap
Rep Power: 10 d.b.cooper is an unknown quantity at this point
Default Wow..lot of progress..
looking good...I remember this thread from a long time ago because of smiling about mom helping out. It looks darn near done. Liked the attention to detail, like painting that block-off plate before you (JB Welded?) it in so the inside looked good.
d.b.cooper is offline   Reply With Quote
Old 11-02-2007, 07:59 AM   #1332
Andrew's Avatar
Ride:  1991 CRX Si
It'll be a little darker than the Intake, but maybe I'll paint it to match the valve cover
Originally Posted by d.b.cooper View Post
(JB Welded?).
Anything will work. I just threw some adhesive on it to hold it in place, then today I'm going to take some Liquid Nails or something and put it on the inside. I don't want it too permanent because I'd like to get the HF grommet to block it off. I just wanna get it done asap.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-02-2007, 10:03 AM   #1333
Rep Power: 13 crnsx1988 is off the scale
Here is something to give you more inspiration.
crnsx1988 is offline   Reply With Quote
Old 11-02-2007, 12:22 PM   #1334
Andrew's Avatar
Ride:  1991 CRX Si
^ cool man.
Thanks for sharing
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-02-2007, 04:41 PM   #1335
Rep Power: 14 91_civic_si has a spectacular aura about91_civic_si has a spectacular aura about
Originally Posted by Andrew View Post
Axles.
Thanks guys.
-Andrew
It would work but you will still get some binding. What intermediate shaft do you have?
91_civic_si is offline   Reply With Quote
Old 11-05-2007, 07:46 PM   #1336
Andrew's Avatar
Ride:  1991 CRX Si
^ I think it's the stock B16 one. idk.
I'm going to stop by Pick N Pull this week and pull off an '86-89 ls axle and have the outer joint installed on my 90-93 ls axle. (BTW, anyone know of a cool DIY on this sort of thing?)
As far as progress goes, I got the dash almost back in. I've got most of the wiring taken care of and secured. The dash is "in" but not bolted down and stuff. Won't take but a minute, though.
And helped my buddy swap out to some new wheels on his EG8, otherwise I would've had the dash thing done and most of the int. put together, but w/e. :
He's still looking around for a new hood so he can delete the hood pins.
And he just just ordered a complete H-duece-duece swap that should be installed this or next week!
Updates soon. I'm ordering a few little things from Honda/Acura tonight, so I should be driving next week if All goes well!
ninja edit:
The sealing bolt is to block off the heater hose on the head, instead of just using a rubber cap (which would eventually fail...)
Like So:
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-05-2007, 07:49 PM   #1337
Dismember
Ride:  Whatever i can get behind the wheel of
Rep Power: 242 klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
Looking good, I wish I could remember how my dash goes back together
klyph is offline   Reply With Quote
Old 11-06-2007, 06:41 AM   #1338
Andrew's Avatar
Ride:  1991 CRX Si
Haha... Yours will look a LOT better than mine hopefully when your done!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-06-2007, 08:13 AM   #1339
Ride:  94 GSR Sedan
Devins civic is gonna be sick man...
How long till he totals it? 3 months? :P
1994 Acura Integra GS-R Sedan
My MAIN DB8 project thread on Honda-Tech: Very detailed of EVERYTHING I've done to my car.
Contact me for ITR header skid plates: $40.00 shipped!!!
Old 11-06-2007, 12:14 PM   #1340
Andrew's Avatar
Ride:  1991 CRX Si
Probably. If he can't handle a stock altima.... OMG.
BTW guys during lunch break I bolted down the dash and plugged in some connectors.
I'll install my gauge pod bezel onto the center console and finish the interior completely!.
Sometime this week I'll make my way to Pick N Pull. Oh!! Btw I just remembered I have $52 credit there... sweeeeet. I think this axle will be free and I'll still have plenty of cash left.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-06-2007, 01:00 PM   #1341
Ride:  94 GSR Sedan
HEY HEY.. If all goes OK, I"ll be there Friday.
We can make it a date Instead of buying me dinner, you can buy me a part
jk
Old 11-06-2007, 02:42 PM   #1342
Andrew's Avatar
Ride:  1991 CRX Si
Well how about this. Since I have to work Friday 'till 5:30, and will probably be going to PnP thursday, I'll just give you the receipt of whats leftover.
Gravy?
Updates in a bit guys. I'll be heading home to do some more work in a few minutes.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-06-2007, 06:14 PM   #1343
Andrew's Avatar
Ride:  1991 CRX Si
Progress today;
Installed my boost gauge line. Instead of installing the vacuum manifold I just tapped my intake nipple. worked like a charm!
Edit: Speaking of which, I applied some "special adhesive". AKA Liquid Nails to the Gauge Bezel I made:
I'll let it cure overnight and then I'll install it and be done with the interior
I finished he VC:
And I finished installing the dash:
I'm almost there!
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-06-2007, 10:33 PM   #1344
I like the valve cover color. Note: I installed the traction bars on my 88 CRX. I installed them last Friday. I've been driving since without any problems. you're very welcome for a test drive. I'd like to sell the traction bar to you. since you had to cut the rad supports. Full-Race traction bar are being used on lots of K20 CRX's. Let me know.
This 88 CRX hF is for sale. I wish I had the cash. *testing waters*clean clean k20 crx.built right - K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum
Old 11-06-2007, 10:43 PM   #1345
Andrew's Avatar
Ride:  1991 CRX Si
Hey Jose, that last picture isn't even a honda... the transmission is on the wrong side!!!
I can't afford the TB right now, man. I've got too many other things to buy. Sorry!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-07-2007, 03:09 AM   #1346
Dismember
I hope you're joking. K-series?
Old 11-07-2007, 07:04 AM   #1347
Ride:  94 GSR Sedan
Wow Andrew... Thats something like I would say.....n00b
Old 11-07-2007, 07:35 AM   #1348
Andrew's Avatar
Ride:  1991 CRX Si
God dang you interweb. Do I really need to install the latest "[/sarcasm]" tags?!?
C'mon guys... lol.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-07-2007, 10:30 AM   #1349
Ride:  94 GSR Sedan
Get your car ready man! Lets go!
Club 1320 Test & Tune
Saturday, November 10, 2007
Gates Open at 3:00 PM
Racing Begins at 4:00 PM
Racing from 4:00 to 9:00PM
Testing, Fun Runs and Grudge Racing
Feature this weekend:
Domestic vs Import ShootOut
Who's the fastest
$10 Admission
$10 Tech Card
Dusty's got a couple races set up already
Old 11-07-2007, 12:10 PM   #1350
Andrew's Avatar
Ride:  1991 CRX Si
I can't man... got to work. I'm going to try and not ask for any more time off. This month I've kinda pushed it a little...
Sucks, but we'll see.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Engine swap: d15b7 to d16y7; transmission? oakley2002@cox.net HYBRID -> EG-EK / DC 7 10-28-2009 07:19 PM
Best Engine Swap For 95 Integra Ls Agt_Orange_GSR HYBRID -> EG-EK / DC 7 09-23-2008 04:16 PM
EE crx engine swap. DAZ81 HYBRID -> ED-EF / DA 6 11-25-2003 10:21 AM
81 Civic Engine Swap Help fjcisco13 HYBRID -> EG-EK / DC 3 04-23-2003 06:16 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
