Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Andrew's engine swap (pics)
Old 11-04-2006, 08:55 AM   #126
Chopped N' Screwed.
EGProject's Avatar
Ride:  SE-R Spec V
Rep Power: 47 EGProject is a name known to allEGProject is a name known to allEGProject is a name known to allEGProject is a name known to allEGProject is a name known to all
Send a message via AIM to EGProject
Looks awsome man - my personal suggestion would be to spring for some blue Samco radiator hoses - would set off the white and black well.
for the engine bay though.
Originally Posted by E_SolSi View Post
had this happened in the US, our government would have extinguished the burning car by heaving truckloads of money onto the flames...
EGProject is offline   Reply With Quote
Old 11-04-2006, 11:29 AM   #127
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
I think I'm gonna do an SS hose look.
I plan on doing an SS/ fuel line to my fuel rail, like in this thread.
Then I'll do a catchcan install, and will eventually just have everything SS'ed.
This is my inspriation picture:
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-04-2006, 11:33 AM   #128
Andrew's Avatar
Ride:  1991 CRX Si
Originally Posted by TurboMirage
you shouldnt have any tranny fluid on the bellhousing side.
just plug the axle holes.
I though I'd be ok, but I figured I'd ask... Thanks bro
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-05-2006, 09:44 PM   #129
Andrew's Avatar
Ride:  1991 CRX Si
Picked up a cool slim fan today, as well as a BB/MC from a 94-98 teg:
it came stock on a mercedes (pic), but I found one a little bigger one just laying in a different mercedes, and picked it up for $25 for the fan, $25 for the BB/MC!
My bro got full carpet, weather stripping($300 per side from Honda), and matching floormats(oem), for $8.99.
According to this awsome site...
Brake system:
If you have a DX or something similar you have a 13/16 master cylinder. That is small. 15/16" MCs that bolt right up to your stock booster are: 88-91 prelude, 89or so accord LXi, and 90-91 civic EX. You can also use the 90-93 integra 15/16 (non ABS) MC but you NEED to use the booster as well. If you want to use the DA 1" ABS MC and booster you have to put a different fitting (its larger) on one of the lines that goes into the MC.
On top of all that you can use a 1" MC from an ITR or a DC GSR. For that you will need both the MC and the booster, then you need to re-bend one of the lines to get it to bolt up. Fortunately there are no differences in the fitting sizes like with the DA 1" MC.
I personally have the DA 1" MC/booster and it is great. The fitting was kind of a pain but definitely not impossible if you own a flaring tool.
If you have disc brakes all around and they didn't come stock you probably should swap out your stock proportioning valve for one that says "40/40" on the side. This comes in Si and EX 88-91 civics, and DA integras.
It looks like I won't have any issues with my fittings going into the MC. (Am I reading the bold right?)
If so, GREAT! It seems like it's gonna be a drop in thing.
Heres the plan, and what I'll have to do to make it work-
Front
-DC Integra MC/BB. Bending 1 hardline to work. Should be able to use my EF fittings.
-Proportioning valve. I should be fine with mine. It is a 40/40, since it's an SI.
-EX Knuckles. Drop in process. Includes rotors, calipers, LCA's(I could use mine too)
-SS Braided lines. DA, EX, or for my EF. they should all be the same... right?
Rear:
-DA Integra UCA. Will act as cheap camber correction, since it's 1/16" longer.
-DA trailiing arms/brakes.
Should be pretty sweet.
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-05-2006, 10:11 PM   #130
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
youll need si ones
http://pandora.com/
Old 11-05-2006, 10:50 PM   #131
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Rep Power: 288 Calesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud of
Andrew- my lines went straight into the 94-01 15/16 Integra master cylinder when I mounted it up on my EG.
Old 11-06-2006, 07:23 AM   #132
Andrew's Avatar
Ride:  1991 CRX Si
It's a little different on my rex.
It has the two lines on the drivers side of the MC, while the Integra MC has a line on each side.
Formby, I need SI's because of the length right? The fittings are the same, correct?
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-06-2006, 08:53 AM   #133
formby's Avatar
yes...
you could also use DA ones but they might be longer
http://pandora.com/
Old 11-06-2006, 10:47 AM   #134
Andrew's Avatar
Ride:  1991 CRX Si
Ok, sounds fine. Thanks for the help!
I got my slim fan installed! I wired both the A/C fan switch and the engine coolant fan switch to it, so it will be used for both(since its so much bigger I don't see any problem.).
And to show how much slimmer it is... the new fan is 3 1/2", the old fan is 5 1/2"!
And I got the injectors spliced so I can get the wires in between the Intake runners so I can run the harness underneath the IM.
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-06-2006, 02:14 PM   #135
Dismember
Ride:  Whatever i can get behind the wheel of
Rep Power: 242 klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
Andrew, where'd you get that slim fan? I need one for the CVCC project.
klyph is offline   Reply With Quote
Old 11-06-2006, 03:10 PM   #136
Andrew's Avatar
Ride:  1991 CRX Si
I can pick one up for you- $40 shipped.
I got it off an old Mercedes at the junk-yard-
like I said, I'll pick one up for you if you want. It's about $25 at the junkyard, so I figure $15 for shipping and helpin me out in gas(stupid SUV... and the 'yard is way across town).
$40 shipped, and that goes for anyone that wants one.(theres only a couple out there, so if you want one, lmk asap.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-06-2006, 04:16 PM   #137
Andrew's Avatar
Ride:  1991 CRX Si
Just ordered my SS fuel line stuff!
Heres what I got:
BTW, it's all -6 AN stuff...
Originally Posted by AN Plumbing
Part No. 9894DBH
Female saginaw to AN male adapter
Unit price: $5.87
# of units: 1
Total: 5.87
Part No. 800106
Swivel-Seal Straight Hose End
Unit price: $5.59
# of units: 2
Total: 11.18
Part No. 403006
Premium Racing Hose. THE BEST! (Use Swivel Seal or Auto-Fit Hose Ends)
Unit price: $23.29
# of units: 1
Total: 23.29
Part No. 230106
35 Micro sintered bronze element, In-Line Fuel Filter. 4 to 5 GPH flow rate
Unit price: $26.16
# of units: 1
Total: 26.16
Part No. 935106
90Deg. Tube Bent, AN Female to AN Female
Unit price: $10.56
# of units: 1
Total: 10.56
Part No. 991945
Carburetor Adapter Solex, Dellorto, Mikuni
Unit price: $6.59
# of units: 1
Total: 6.59
Part No. 100199
An in-line Adapter for either Direct or Remote Mounted Fuel Pressure Guages with 1/8 NPT in Hex.
Unit price: $13.99
# of units: 1
Total: 13.99
Item total: $ 97.64
UPS Ground $ 9.55
Grand Total: $ 107.19
I'm so excited... I just can't hide it...
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-06-2006, 04:25 PM   #138
formby's Avatar
good job...
so thats how it is to live at home a sling rocks on the side...
lol jk
http://pandora.com/
Old 11-06-2006, 04:36 PM   #139
Chopped N' Screwed.
EGProject's Avatar
Ride:  SE-R Spec V
Originally Posted by Andrew
I think I just came a little in my pants....
Anyways, the SS look is really cool, but I'd still go for the blue Samco hoses. They'd accentuate the SS lines an AN fittings as well.
Old 11-06-2006, 08:12 PM   #140
Andrew's Avatar
Ride:  1991 CRX Si
I might. Let me price them out, and compare it to SS'ing it.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-06-2006, 08:16 PM   #141
Dismember
It'd probly be cheaper if i went to a local yard and did what you did. Thanks for the tip.
Old 11-06-2006, 09:11 PM   #142
Andrew's Avatar
Ride:  1991 CRX Si
If you can't find one, you know just to ask me.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-07-2006, 03:56 AM   #143
Dismember
Thanks man. I appreciate the offer.
Old 11-07-2006, 09:34 PM   #144
Calesta's Avatar
Ride:  2003 S2000
Braid your own. Wait... I have braiding machines at work.
Old 11-08-2006, 08:40 AM   #145
Andrew's Avatar
Ride:  1991 CRX Si
Help a brotha out! haha
AN Plumbing.com has pretty good prices.... and I'll be shoping around town too.
I'll figure something out, but of course it's not nessesary, so it might be a while...
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-14-2006, 10:51 AM   #146
Andrew's Avatar
Ride:  1991 CRX Si
Update 11/14:
Got my Fuel line stuff in from Earl's store
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-14-2006, 11:01 AM   #147
formby's Avatar
isnt that the one that needs to be flared?
could you use a dremel and cut it at the nut?
http://pandora.com/
Old 11-14-2006, 11:19 AM   #148
Andrew's Avatar
Ride:  1991 CRX Si
Nvm. I got it off with a flare wrench.
Your right. My fitting won't work w/o some modification-
http://www.rywire.com/parts/parts%20037.jpg
http://www.rywire.com/parts/parts%20038.jpg
I've got to rip off the unthreaded portion of the fitting with a dremel. see:
I'll probably do that today or tomorrow.
Motor should be done this week!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-14-2006, 01:27 PM   #149
Dismember
I'll believe it when I see it.
Keep up the good work man.
Old 11-14-2006, 02:40 PM   #150
Andrew's Avatar
Ride:  1991 CRX Si
You and me both!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Engine swap: d15b7 to d16y7; transmission? oakley2002@cox.net HYBRID -> EG-EK / DC 7 10-28-2009 07:19 PM
Best Engine Swap For 95 Integra Ls Agt_Orange_GSR HYBRID -> EG-EK / DC 7 09-23-2008 04:16 PM
EE crx engine swap. DAZ81 HYBRID -> ED-EF / DA 6 11-25-2003 10:21 AM
81 Civic Engine Swap Help fjcisco13 HYBRID -> EG-EK / DC 3 04-23-2003 06:16 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
