#1501 |
Sonnova Bitch!
Ride: 2006 GSX-R 600, 2003 Santa Fe GLS
Let us know how that dash fits
http://davesstainedglass.webs.com/ |
#1502 |
Ride: 1991 CRX Si
I've seen it done a few times before, and it seems like it's not TOO bad of a swap. I think more than anything it cramps your knees a little more than any of the other dashes.(except for the DC5 dash)
I'll have pics out the wazoo. Don't worry. |
#1503 |
Sonnova Bitch!
Depending on the trouble it gives you, I may have to do the same. I found a writeup on here I believe, before I came big into honda-swap on putting a 00' gauge cluster in the rex, but I like just swapping the entire dash.
#1505 |
#1506 | |
I trained Trogdor to pWn
------------------------ And Andrew.... Tracy's S-10 went 6.3 @ 108 IN THE 1/8TH mile. Do you know what that translates to in the 1/4? . . . . . . .. . . . . . . . 9.8/9.9 Freaking 9 second 1/4's FTW!OH, and this just came in ![]() ![]() __________________
1994 Acura Integra GS-R Sedan My MAIN DB8 project thread on Honda-Tech: Very detailed of EVERYTHING I've done to my car. Contact me for ITR header skid plates: $40.00 shipped!!! Last edited by mac_24_seven; 01-07-2008 at 11:29 AM. |
#1507 |
Sonnova Bitch!
Andrew.
Ship me your z6 and ecu ![]() __________________
#1508 |
Ride: 1991 CRX Si
Got some work done today.
Looks like my rex is running pretty good. Went and filled it up with some fresh gas and checked for leaks (story of my life... thanks.. EF's.) and I've got a strange coolant leak dripping down my engine stamp. I'm still trying to diagnose it, but it's no big deal. I stripped out the dash harness of the DC dash. I labeled some of the plugs I want, but I think I'll be using my CRX harness and merging some of the wires for simple things like the dimmer, sun-roof, Hazard, and Defrost (which is pretty much the only things I'll need, since I'm ditching the Climate Controls.) Don't worry. I'm doing everything I can to keep the harness', and my car in general, ready to switch back to normal if I ever need/want to. ![]() ![]() Oh, and I redid my engine bay in GOLD bolts! bling bling, homies ![]() ![]() ![]() ![]() ![]() And I gathered some parts in my shop that I'm going to sell. I guess I'll start up a for sale thread, soon. I'll post up a link, soon. I guess I'll see what comes next __________________
1991 CRX Si 2007 Civic Si Sedan My Engine Swap Write-ups: HG FPR Wheel Smiley Cluster. Adapters. Last edited by Andrew; 01-08-2008 at 10:06 PM. |
#1509 |
Sonnova Bitch!
Lookin good bud. I'm excited to see what all it takes for this DC dash, i may have to convert.
But I'm telling you, this whole for sale thread, just ship me your z6 and ecu ![]() __________________
#1510 |
Ride: 1991 CRX Si
^ I'd be more than happy to, my man!
*cough up that dough! ![]() Heres the F/S thread: http://hondaswap.com/parts-sale-trad...24/#post920150 |
#1511 |
i just read through all 62 pages and my god this is cool. it was like i was reading a story and half the time i was wondering "ok whens the b16 coming into play here?" haha. this is great. About the surging idle, take the throttle body off and open up the FITV, usually a surging idle is caused when it backs itself out a little bit, just screw it back in with your finger and you should be good to go. Also check that your IACV is still good. To check for a vac leak, take a can of brake cleaner and spray it on the area that you think is leaking, if you hear the engine rev up a little bit (rpms will go up like 200-400rpm) then you know theres a leak there because its sucking the brake cleaner in and combusting it.
I had an annoying vac leak on my IACV, turns out i tightened it too much. Also for whatever reason my throttlebody was leaking bad on the bottom of it. might have something to do wtih the ITR intake mani and b16 throttlebody but im not sure. (i have an ls/vtec swap in my 00 ex coupe). i jsut put some high temp silicon gasket maker and sealed the bottom of the throttlebody with that, vac leak fixed, no more surging idle :-). Also about the exhaust, is the crush bend worth it? I am currently rolling around on the stock d16y8 piping (like <2" i think?), i rolled around open header with a cat and like 2 feet of pipe bolted on and it pulled like a bitch then compared to when the exhaust was hooked up. Also with it open header my friend driving next to me said when it crossed over into vtec he felt it in his chest lol (ITR cams woot). my setup if your curious is a b18b1 stock block, b16 head with all ITR components (cams and full valvetrain), gsr trans with a quaife lsd. Untuned on a basemap with a hondata s200 chipped p28. The thing pulls like mad and i love it, plus all stock exterior = sleeper. Keep us updated on what happens and check what i told you about the surging idle, i know that feeling like "its working but its still broken", bugs the crap out of me with my car. |
#1512 | |
Sonnova Bitch!
#1513 | |
Ride: 1991 CRX Si
Coutts, Thanks for your imput man. I've got most of the kinks worked out, but theres always something!
Tell me what it's worth to you. I don't know what built D-series are going for nowadays. |
#1515 |
Ride: 1991 CRX Si
I'll cross that bridge when I get to it. ;P I don't really know. I might just do some sheetmetal ones or something. weight reduction = ftw. ugly but great for track use = ftw
Found a few pictures that kinda get me excited about doing it. I don't know. lmk what you think I especially like this part (would be cool to finally have an armrest!) I don't know if I want to do that to my crx yet. we'll see. I might just hang on to it. Or sell it. IDK. |
#1518 | |
Sonnova Bitch!
![]() How built? As for the dash, I saw those pics when someone posted the HT link, I like how it looks. Call it a hybrid, call it rice, whatever, but I really like how it looks. And the bottom pic? Definitely +1 in rep for finding that and making me laugh. I feel like shit today. EDIT: Must spread some rep before giving it to andrew again, who wants rep? I promised him rep and he gets it. __________________
#1519 |
Führer Mod
i think it made just under 130 whp.. basically the power a stock b16 puts out
#1520 |
Yeah
Does anybody realize Decepticons is spelled wrong?
"It's not what you drive, but how you drive it." XBL Gamertag= W0BBnIT <---- 0 is a Zero |
#1521 |
Ride: 1991 CRX Si
128 / 112 to be exact.
On a basic street tune. Theres a few more HP left in it, in tuning. Plus that was with the old header. With this DC sports 4-1 I bet it'll change it a little bit, too. Thing pulled hard. I'm thinking of picking up another car to put it in. Even my crx (for za bewst). I don't really want to sell it. It's MUCH more worth it for me to use than to sell, cause I've got way too much money invested in the stupid thing. ![]() __________________
1991 CRX Si 2007 Civic Si Sedan My Engine Swap Write-ups: HG FPR Wheel Smiley Cluster. Adapters. Last edited by Andrew; 01-09-2008 at 04:07 PM. |
#1522 |
I have seen people use plexiglass for door panels. They just painted the back of it so when you scratch the face it is still colored. Just a suggestion that might not look half bad.
#1524 |
Sonnova Bitch!
Yeah, I feel you on the motor. I guess I'm just getting irritated with mine
![]() As far as the Decepticons thing, I didn't even notice ![]() __________________
#1525 |
Man, I don't think it looks that good. It looks too big. After seeing that pic, I'd stay with your factory dash. You've got a real nice N clean interior. Plz don't put aluminum door panels in!!!!! They can't weigh 5 lbs a piece :S If anything, just hook up the LS cluster. Jose did it in that CRX he has and. while not a perfect fit , it looked good! My .02 |
| Engine swap: d15b7 to d16y7; transmission? | oakley2002@cox.net | HYBRID -> EG-EK / DC | 7 | 10-28-2009 07:19 PM |
| Best Engine Swap For 95 Integra Ls | Agt_Orange_GSR | HYBRID -> EG-EK / DC | 7 | 09-23-2008 04:16 PM |
| EE crx engine swap. | DAZ81 | HYBRID -> ED-EF / DA | 6 | 11-25-2003 10:21 AM |
| 81 Civic Engine Swap Help | fjcisco13 | HYBRID -> EG-EK / DC | 3 | 04-23-2003 06:16 PM |
