#1576 | |
Cogito Ergo Sum Steampunk
Ok, I have a plan that is similar to what you had there: You mentioned some lessons learned, You got anything for me ?
I was going to make my fenders pin-on, so that I could get to the wiring harness under the fender. I was going to divide the harness into two: With lighting and transmission loom on the passenger side fender, intake controls and alternator on the driver's side. What conclusions did you reach ? __________________
#1577 |
Ride: 1991 CRX Si
Celerity, (get ready for broad statements directed mostly towards "new" mechanics) first off, take your time and make sure you feel comfortable with where the wires are routed before you secure it all down tight. Think about what your moving/removing and how it will affect your system (if it will).
Where I ran my wires through (seen below, where they are running through now) is the SunRoof drain escape. Thats why my carpet would get a little wet, because it wasn't draining outside the cabin. I'll figure something out in the next few days on where to get that tube out of the car. Just make sure of stuff like that. Know what your doing before you do it. PM me with questions as you go. I've done this 3 times to my car and I'm sure I can help you with some roadblock you have. Plus I have tons of pics in my Photobucket you can look through that might help. write-up section of my PB Oh, as far as the engine harness goes I did it something like this: ![]() The headlight and AC wiring is the only stuff going through the fenders. I'm not sure what you meant exactly, but hopefully that explains it. BTW. Honda-Tech.com: Appearance / Cosmetic: ♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠ Thats your BEST FRIEND. Read that first page (reference info) MULTIPLE times. It helps. trust me. =================================== ================ On to my car: =================================== ================ I finished the wiring. I'm happy with how it turned out. I did good. Next up will be the Drivers side(gonna re-do it and hide the Resister Box) My mess: ![]() After depinning all the connectors(take notes kids... ) I got it pulled through the fenderwell. ![]() ![]() Then got it all straightened out. ![]() Then stuffed it through the firewall. ![]() ![]() Again strung it out. ![]() Then pulled it through this hole and taped it all up. ![]() ![]() Resister box and common ground mounted. with BLINGIN hardware. ![]() ![]() Heres how she looks: ![]() Starter wire and wiper motor wires. ![]() Theres so much more I could do, but I'm chuggin along getting it Right. It might take me 10 tries, but I'll get it perfect dang it! ![]() -Andrew |
#1578 |
Dismember
Bring Back The D!
Go to work, Act normal, Believe the News, Save for your old age, Obey the Law Repeat after Me: I am Free |
#1580 | ||
I wear stretchy pants
Ride: chevy s-10
![]() with your luck you still wont break 14's ![]() __________________
#1582 |
I trained Trogdor to pWn
Andrew, I'm picking up a bottle warmer next week
1994 Acura Integra GS-R Sedan My MAIN DB8 project thread on Honda-Tech: Very detailed of EVERYTHING I've done to my car. Contact me for ITR header skid plates: $40.00 shipped!!! |
#1584 |
Ride: 1991 CRX Si
Got some more progress done, and some goodies, too.
Test fit my IC just for kicks. I actually think it would work! with only minor modifications to my front end. ![]() Painted the front ![]() Got my sun-roof drain going to the right place( namely OUTSIDE the car) ![]() ![]() Put the fender back on ![]() And did some more touchup paint on the bumper support and stuff. ![]() Then I picked up my Civic and delivered it to my buddy. Traded him the civic shell for a complete Wet Kit (NOS) and $200. Needs a new fuel solenoid. ![]() ![]() ![]() I'm thinking of dropping the D16 in with that new headgasket(making my Compression 10:1) and spraying it. thoughts? |
#1585 | |
Ride: chevy s-10
did i miss something? What the intercooler for?
Ohh and that D should be able to handle some nitrous. Just make sure you get it tuned for maximum HP. i can see it handling a 100 shot. Big chris was running a 75 dry shot on his single cam and it held up for a long time __________________
#1587 |
Ride: 1991 CRX Si
Abel I was just seeing if it would work. I'll hang on to it. Who knows, I might want to try some turbo Action sooner or later.
Terrance, Yeah, i think it is. |
#1588 |
This video will make you happy in t3h pants... Bolt on B16 w/a 75 shot.
.... **eDIT** sTUPID DAMN INTERNETS (OR ME) links up later.. Wife locked keys in car :S Last edited by mac_24_seven; 02-18-2008 at 04:05 PM. |
#1589 | |
If you're having trouble with that IC I Have a johnny racer one that fits REALLY well. IT's not as deep, but it's longer. The mounts truly hide it under the bumper skin.
It's pretty trick. Lemme know if you're interested in a trade or something. __________________
#1590 | |
Brutal Moderator
Ride: 97 Integra LS Coupe
#1591 |
Ride: 1991 CRX Si
Whaaaat ole B16 hangin with an SS... nice...
I'm thinking that when ENDYN starts selling their complete race heads I'll pick one up. Built head on stock rebuilt bottom end with spray. mmm... |
#1595 | ||
Ride: chevy s-10
I like endyn dont get me wrong. If i have another N/A motor i want it built through them. i just think your thinking overkill right now. Once again just spending money without a game plan as to why and what you want to achieve. Damn dreaming youngsters ![]() __________________
#1596 |
Ride: 1991 CRX Si
I always do research before putting something in/on my car.
I do even more so when I'm about to buy something or know what it is I want to do. ENDYN's heads come with completely revamped casting, port n polish, full valvetrain w/ oversized valves, and their version of the ITR cam. All for under $900. A fully built head BRAND new. You can't beat that. I think the head is a good investment. I can always put ANY bottom end on it I want. Like a built LS or a sleeved/bored B20 and make crazy power. Since it's the toy, I don't see why it's a waste. "I have a dream!..." lol |
#1597 | ||
Ride: chevy s-10
YOU try getting that deal with Dart. They charge that much just for the fraking head alone. __________________
#1598 | |
#1599 | |
Ride: chevy s-10
W-T-F
I stand corrected. still that doesnt make sense. Why machine and assemble a head only to sell it the same price as a stock b16 head? You can get a b16 head for around $400 complete. IDK but if this is true i should jump on the deal as well. Even if i dont own a honda ![]() __________________
| Engine swap: d15b7 to d16y7; transmission? | oakley2002@cox.net | HYBRID -> EG-EK / DC | 7 | 10-28-2009 07:19 PM |
| Best Engine Swap For 95 Integra Ls | Agt_Orange_GSR | HYBRID -> EG-EK / DC | 7 | 09-23-2008 04:16 PM |
| EE crx engine swap. | DAZ81 | HYBRID -> ED-EF / DA | 6 | 11-25-2003 10:21 AM |
| 81 Civic Engine Swap Help | fjcisco13 | HYBRID -> EG-EK / DC | 3 | 04-23-2003 06:16 PM |
