Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Andrew's engine swap (pics)
Old 11-14-2006, 02:50 PM   #151
i <3 braided lines... thats my next project.
90 Integra Sedan
B20V 225 / 153
Old 11-14-2006, 04:51 PM   #152
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
Well, if your looking to do it, scan over This thread's pages.
Some guy posted some pretty nice setups that will work a little better.
My current setup will only leave enough room for about 3" of SS hose, because the filter and stuff is inline. (And hopefully I won't have any problems with my intake pipe clearance)
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-14-2006, 06:14 PM   #153
Andrew's Avatar
Ride:  1991 CRX Si
If your fitting looks like this...
You'll have to cut off the non-threaded part of the fitting.
4. End result:
And your good to go!
I'll be making a write-up on it when I'm finished with it(in the car), so look out for my sig to be updated!
BTW, I talked to KMS, again, and he says he'll be calling my Friday about shipping info... Don't jynx me!
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-15-2006, 05:22 PM   #154
Andrew's Avatar
Ride:  1991 CRX Si
Update 11/15
I've started on the brake booster and master cylinder thing. (DC teg)
I've got the Booster completely bolted in, cotter pin and all, as well as the MC, but I need to go back to the junkyard and pick up that one fitting I'm missing(seen in last pic).
Isn't that stupid? I went to the junkyard a couple days ago, got 3 fittings, and neither of them is the right one!
I'm an idiot.
Well... Thats it for now
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-15-2006, 07:50 PM   #155
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 334 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
lookin good
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 11-15-2006, 10:43 PM   #156
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Rep Power: 288 Calesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud of
Old 11-15-2006, 11:27 PM   #157
i assume thats a 1" master cylinder? fuckin siiick. cuz i got the same one for my integra... just havent installed it yet.
90 Integra Sedan
B20V 225 / 153
Old 11-16-2006, 10:35 AM   #158
Andrew's Avatar
Ride:  1991 CRX Si
Well, I'm not too sure what it is.. haha. It's off an 94+ LS w/ ABS. I'm starting to look around for a GSR MC. Those are 1".(same as ITR, but I think buying an ITR one will be a bit more pricy...)
But even still, it's better than mine.
Next will be some brake upgrades. I think I'm gonna go the simple route-
Originally Posted by Jonathon ED3 on H-T
Parts list:
-'91 Civic EX Brake rotors...same as 92-95 Civic Sedan rotors ($14.99 each at Pep Boys; probably cheaper at AutoZone)
- Accord Wagon Brake Calipers (will be stamped 17CL15VN; ~$50 rebuilt at Pep Boys). These are the exact same calipers as the ITR, Legend, Prelude VTEC etc. Great stopping power!
- Accord Wagon, Prelude VTEC (etc) Brake Caliper mount stamped 25T (a 23T bracket exists, but I can't promise you it will work). This is what came stock on the Accord Wagon.
- 1/8" wheel spacer OR grind ~1/8th" (2.5-3mm) off of the caliper mounting bracket. If you are familiar with the 11" brake upgrade, this is the same modification necessary.
Read about it in THIS thread on H-T.
That way I don't have to go through the hassle of changing my knucles or LCA's.
So... I guess thats next!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-16-2006, 04:08 PM   #159
I trained Trogdor to pWn
mac_24_seven's Avatar
Ride:  94 GSR Sedan
Rep Power: 16 mac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura about
Awesome stuff man.. I"m Andrews Bro-in-law and have helped him along the way with this swap.. I'd liek to say that he basically knew NOTHING about working on cars before this..and look at em go.
Smart lil queer he his. Good job man, I cant wait to rag on it some
mac_24_seven is offline   Reply With Quote
Old 11-16-2006, 07:29 PM   #160
Andrew's Avatar
Ride:  1991 CRX Si
I guess I'll take that as a compliment?
haha...
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-17-2006, 12:00 AM   #161
hey on that master cylinder look at it.. on the side... it should have a 1 casted into it. if it does, its a 1" master cylinder... if not then there should be a 15/16 stamp...
oh and just so you know the accord calipers are cool and all... but the 94-95 legend GS sedan DUAL PISTON caliper is better!!!
good luck on your shit
90 Integra Sedan
B20V 225 / 153
Old 11-17-2006, 10:34 AM   #162
Andrew's Avatar
Ride:  1991 CRX Si
I just went out and checked out the MC out... survey says.....
Yiiipppeeeee
Oh, and I thought it was the same, but I didn't know if the accord caliper was dual or not.
I just called Advanced and they said they have the '95 legend GS calipers for $62/ea. with a lifetime warranty
Do you know of any modification needed to install them? Gotta do some more research I guess...
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-17-2006, 11:06 AM   #163
Andrew's Avatar
Ride:  1991 CRX Si
wow! look at all the views!?
Link's in your sig really work!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-17-2006, 12:04 PM   #164
Calesta's Avatar
Ride:  2003 S2000
Old 11-17-2006, 12:05 PM   #165
Calesta's Avatar
Ride:  2003 S2000
Oh- as for installing the Legend calipers, if you Google up "4G brake upgrade" you'll find some articles on the old crx.honda-perf.whatever.blah.blah.blah site that tell you how to bolt everything up.
Old 11-17-2006, 04:05 PM   #166
Andrew's Avatar
Ride:  1991 CRX Si
Thanks for the tip.
I just read both pages-
4g Civic Brake Swap
4 and 5g brake upgrade
However, I feel like it didn't really answer my questions very much.
That thread on H-T seemed to have more direct info.
So I'll only need '95 Legend GS calipers, '91 civic sedan(ex) rotors, SS lines.....
And I'm thinkin thats it. right?
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-18-2006, 12:37 PM   #167
Calesta's Avatar
Ride:  2003 S2000
I think so... did it say that you needed the 90-91 EX steering knuckles? The caliper mounts are different between the knuckle sets.
Old 11-18-2006, 04:43 PM   #168
Yiiipppeeeee
-Andrew
i know for integras you have to shave like 1/8" off the caliper mounting bracket... the inside portion the part where the rotor passes through...
other than that its pretty much the same.
90 Integra Sedan
B20V 225 / 153
Old 11-20-2006, 08:05 AM   #169
Andrew's Avatar
Ride:  1991 CRX Si
Like so?
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-20-2006, 12:16 PM   #170
Dismember
Ride:  Whatever i can get behind the wheel of
Rep Power: 242 klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
Nice. How'd you plane that down? Did a machine shop do it or did you do it yourself. looks pro
klyph is offline   Reply With Quote
Old 11-20-2006, 04:53 PM   #171
Andrew's Avatar
Ride:  1991 CRX Si
Someone posted it in this thread.. I wanna say Page 12-13 or so.
I haven't bought my stuff quite yet.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-20-2006, 05:54 PM   #172
Like so?
that wasnt the side i was talkin about.
90 Integra Sedan
B20V 225 / 153
Old 11-20-2006, 07:20 PM   #173
Andrew's Avatar
Ride:  1991 CRX Si
Hmm.. well, thats the only mod they said was needed.
What exactly were you talking about?
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-20-2006, 07:34 PM   #174
Read my post. grind it an 1/8th of an inch on the side the rotor passes through... ...
either way will work i suppose. DA guys grind it onthe side im talking about, I guess EF guys do it on that side.
90 Integra Sedan
B20V 225 / 153
Old 11-20-2006, 08:37 PM   #175
Andrew's Avatar
Ride:  1991 CRX Si
Huh.. I guess it doesn't much matter.
thanks brian
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Engine swap: d15b7 to d16y7; transmission? oakley2002@cox.net HYBRID -> EG-EK / DC 7 10-28-2009 07:19 PM
Best Engine Swap For 95 Integra Ls Agt_Orange_GSR HYBRID -> EG-EK / DC 7 09-23-2008 04:16 PM
EE crx engine swap. DAZ81 HYBRID -> ED-EF / DA 6 11-25-2003 10:21 AM
81 Civic Engine Swap Help fjcisco13 HYBRID -> EG-EK / DC 3 04-23-2003 06:16 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
