Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Andrew's engine swap (pics)
Old 05-12-2008, 11:11 PM   #1851
The Pussi Snatcher
Ride:  90 Ls/Vtec Turbo Da
Rep Power: 5 90DATeggy is an unknown quantity at this point
Send a message via AIM to 90DATeggy Send a message via MSN to 90DATeggy Send a message via Yahoo to 90DATeggy
ill take slips...spoon knock offs flat black ill eat for breakfest anyday...lol
IM LOOKING TO GET A MSD 6AL box for local pickup only
Looking FOR LS MESH wheels Pm Me If U GOT THEM
IM LOCATED IN ORLANDO..PM ME IF U GOT IT
Owning a type-r is just like every other honda that is modded in Orlando,FL you wake up and its Gone....Whammm
If you find anything I say helpful, please leave me some rep...
90DATeggy is offline   Reply With Quote
Old 05-14-2008, 09:52 PM   #1852
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
Got some more work done lately...
-Ordered some gaskets from Majestic. Dizzy oring, throttlebody gasket, valve cover gaskets, etc.
-Installed fender liners and Right fender
-1/2 way installed the radiator (no fluid or upper hose).
I think I'm going to get my hands on a EG radiator.
- was going to install the Axles but finally figured out that Terrance has them so thats put on hold till this weekend...
-Working on re-doing my gauge bezel with some sheetmetal and carbon fiber. Should look a lot better when I'm done.
Right off the bat.... Does anyone know what this little plug is for? (DEAD CENTER of the pic.). Oil? Coolant? I had a thought cross my mind of putting a gauge there.
Radiator- Wanna pick up a 1/2 sized EG rad sooner or later. I think that would look pretty good...
Working on my hoses and cables...
Brake Booster vacuum line- cannot bend the barb in the head, so it's stuck facing up. I think I'll have my Y8 manifold back this weekend so I might install that this weekend and it's barb might not be stuck.
Fuel return line- I'm thinking of a better way to do this. I have a few ideas in my head. So we'll see. It involves a little cutting and flaring of both the pressure and return lines behind the firewall, using bulkhead fittings, and running all SSBraided in the bay. Prolly look hawt.
Fender. I've gotta get my sunroof drain taken care of on the Left side before I can install that fender. Thats the only reason its not on right now!
Few pics for fun...
I like this one... took it last week...
Thats about it.
I've gotta get a few more things out of the way and I'll be ready to start turning key!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 05-14-2008, 10:36 PM   #1853
Sonnova Bitch!
daveholiday's Avatar
Ride:  2006 GSX-R 600, 2003 Santa Fe GLS
Rep Power: 44 daveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud ofdaveholiday has much to be proud of
Send a message via AIM to daveholiday  FaceBook
I love this thread
daveholiday is offline   Reply With Quote
Old 05-14-2008, 11:20 PM   #1854
Dismember
Ride:  Whatever i can get behind the wheel of
Rep Power: 242 klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
I'm fairly sure that's for the oil passageway. Those plugs are removed when the block is hot-tanked, they run brushes through there to make sure all the crud is removed.
You should be able to pull out that whole 90° fitting by twisting on it. Granted, you'll probably have to reef on it pretty hard, and you'll more than likely end up destroying the fitting in the process, but you could put a new one in.
klyph is offline   Reply With Quote
Old 05-15-2008, 08:06 AM   #1855
I trained Trogdor to pWn
mac_24_seven's Avatar
Ride:  94 GSR Sedan
Rep Power: 16 mac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura about
You'll have the rest of yrou stuff this weekend mang.
Make a lil list so I can bring it to ya.. You need:
Axles
Intake Manifold
Fuel rail
What else?
OH, BTW, why don't you go ahead and install your nawzz while your playing in the engine bay. It needs to be installed nice and neat too! I'll letcha borrow my fuel solenoid
mac_24_seven is offline   Reply With Quote
Old 05-15-2008, 08:09 AM   #1856
Andrew's Avatar
Ride:  1991 CRX Si
Originally Posted by daveholiday View Post
I love this thread
Thx gee. I can't wait to get this crap rolling!
Well, See I've tried to just twist it, like I do on ALL my other manifolds (and cars I wiretuck), with some pliers, but it just don't work. It starts to twist the fitting itself and bend the metal, so I don't feel like ripping a hole in it and having a vacuum leak to deal with... so it'll stay for now.
Are those just compression-fit fittings btw? how do you get them out/in? heat the mani/chill the fitting kinda like valve guides?
Axles
Intake Manifold (Y8)
Fuel rail (Y8)
Thats all I need mang.
I've got my bulkhead fittings and such already. And I'm probably set on all the other fittings I need, since I've been collecting them left and right.
We'll see. I'll probably go ahead and at least run my main line.
I'm just going to focus on getting it running, then I'll worry about making it go fast.
Speaking of which!
Your not going to like this....
Devin ran 15.1@91.7 last night. on DR's though, but it's still faster than you. :S
How much lighter are the 2 door DC2's than your DB8?
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 05-15-2008, 09:27 AM   #1857
Ride:  94 GSR Sedan
Speaking of which!
-Andrew
60'? had to be 2.2 or less.
With my current setup I ran 15.6 @91.6 with a 2.53 60'. Thats also shifting into 4th at the end of the 1/4.
Oh, and major props. I'm envious, yes but I"m not a jerk (all the time anyway :P) Good for him! He's been impotent when it comes to cars for a while. Bout time he step up and get something worth modifying :P
HEY, whats he doin with his B18 block?
1994 Acura Integra GS-R Sedan
My MAIN DB8 project thread on Honda-Tech: Very detailed of EVERYTHING I've done to my car.
Contact me for ITR header skid plates: $40.00 shipped!!!
Old 05-15-2008, 09:52 AM   #1858
Andrew's Avatar
Ride:  1991 CRX Si
Thumbs down
He has it sitting in my shop. rotting. I don't know about that motor. He didn't plasti-gauge like I told him to. No assembly lube was used on the bearings; and leaving it uncovered in my shop with dirt-dobers filling every single little hole in it with larvae and dirt..... tisk tisk.
If theres ANYTHING that annoys me, it's when people use my stuff and do not put it away. jackstands, jacks, tools (MY tools), parts, trash, etc. GAWD it pisses me off.
If I'm going to be nice enough to let anyone use my shop to store crap and to wrench on their car, they'd better damn well clean it up better when finished than it was before they got there. ya know?
It just errks me. I could roll his engine out into the yard and turn the shortblock into a birdfeeder if I wanted to. but no.
/rant.
I'm better now.
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 05-15-2008, 10:01 AM   #1859
Ride:  94 GSR Sedan
Hmmnnn..... Perhaps he would part with it?
I know where a good GSR head is to be used for an LS-Vtec....
Old 05-15-2008, 10:09 AM   #1860
Andrew's Avatar
Ride:  1991 CRX Si
He actually has an B16 head that's been hot tanked and I think had a valve job or something done to it.
(he claims is ITR because of some "blue paint" near the distributor that they marked during manufacturing and some port work on the intake side).
-Custom grind cams (aggressive! I'll try and get specs)
-Intake manifold. ITR I think
And a few other things.
It's all just about assembly. Thats also the scary part, because Devin cuts corners when he's pressured to get something done soon. Cutting corners in engine assembly = engine no good.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 05-15-2008, 10:22 AM   #1861
Ride:  94 GSR Sedan
Wow.
Keep an eye out for a B18.. I wouldnt mind having a backup engine.
Old 05-15-2008, 05:58 PM   #1862
Andrew's Avatar
Ride:  1991 CRX Si
Update!
Batta-Bing! Panels are back on and it looks like a real car again!!
Still working on the center console and stuff on the inside-
Money shots!
You can see where I sprayed a little satin black down to freshen things up
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 05-16-2008, 12:11 PM   #1863
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 189 BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
myspace
Lookin' good! Spraying the black was a nice idea...
PSN Network ID: BrutalB83
Old 05-16-2008, 12:48 PM   #1864
Andrew's Avatar
Ride:  1991 CRX Si
I'll probably spray the entire underbody one of these months. Looks real good for when exhaust guys lift it up and get under there
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 05-18-2008, 04:19 AM   #1865
The Pussi Snatcher
yea the black is a good touch we did that on a 87toyota back in the day..and ended up with rust and little holes every where...
Old 05-18-2008, 09:28 AM   #1866
Andrew's Avatar
Ride:  1991 CRX Si
What do you mean you "ended up with rust and little holes every where..."?
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 05-18-2008, 05:58 PM   #1867
Dismember
Yeah, they're just pressed in. I was gonna suggest heating up the area of the mani surrounding it with a torch, but that would definitely fuck up your paint. I'm pretty sure you could get it out by smashing/mangling it into submission, but there's always the risk that it will break off and leave a piece behind.
Old 05-19-2008, 08:39 AM   #1868
Andrew's Avatar
Ride:  1991 CRX Si
If thats the case I can just drill and thread in a hose barb like I have on my B16. Just a 90" brass barb. I guess somewhere around 1/8-1/4npt or somethin. I got my Y8 manifold Friday, but haven't messed with it yet.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 05-19-2008, 01:27 PM   #1869
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
Rep Power: 215 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
What fitting size is the braided fuel hose? -4an? I reallylike thatand want to do it on my hatch. BTW, shes looking good.
^ (dont listen)
There is a hidden message here.
"Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details."
"In the dice game of life who gets the last roll?"
Old 05-19-2008, 01:31 PM   #1870
Andrew's Avatar
Ride:  1991 CRX Si
-6
Heres the pages I have archived on this thread
Ordered the parts (part #'s included for ya)
http://hondaswap.com/auto-multi-medi...s-69736/6.html
Mocked it up:
http://hondaswap.com/auto-multi-medi...s-69736/8.html
EF8Kid's (Chase w/ Chasebays.com) writeup:
Honda-Tech.com: Honda CRX / EF Civic: WRITE UP: How to convert your fuel lines and ugly filter to Stainless -6AN hoses
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 05-19-2008, 01:36 PM   #1871
My name is Byron.
efhondakid's Avatar
Thanks alot.
^ (dont listen)
Old 05-19-2008, 02:20 PM   #1872
Andrew's Avatar
Ride:  1991 CRX Si
Your welcome GL on the project
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 05-19-2008, 07:04 PM   #1873
Dismember
Yeah, drill/tap would be a good idea. Better than stock
Old 05-19-2008, 09:57 PM   #1874
My name is Byron.
efhondakid's Avatar
I go a few pics in the interior picture thread
^ (dont listen)
Old 05-20-2008, 10:16 PM   #1875
Andrew's Avatar
Ride:  1991 CRX Si
Update!
Got my Majestic order in.
Its supposed to be "Marquis"...... but who cares I got my crap! yay
Distributor Orings, Throttle body gaskets, distributor gasket, valve cover gasket kit....
Got the axles in
(I've GOT to get my brake setup taken care of! I've got DA knuckles and calipers AND a 4040 proportioning valve sitting in my shop (remember way back when I sand blasted the parts?)
And now I'm happy it's on the ground!
Heres some shots outside for the FIRST TIME!! w00t!
Looks amazing in the direct light! I'm proud of it!
Can't wait to get some more color in there (valve cover, intake, etc) I'm thinking Yellow for the valve cover
Enjoy!
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Engine swap: d15b7 to d16y7; transmission? oakley2002@cox.net HYBRID -> EG-EK / DC 7 10-28-2009 07:19 PM
Best Engine Swap For 95 Integra Ls Agt_Orange_GSR HYBRID -> EG-EK / DC 7 09-23-2008 04:16 PM
EE crx engine swap. DAZ81 HYBRID -> ED-EF / DA 6 11-25-2003 10:21 AM
81 Civic Engine Swap Help fjcisco13 HYBRID -> EG-EK / DC 3 04-23-2003 06:16 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
