Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Andrew's engine swap (pics)
Old 08-12-2008, 10:32 AM   #2126
I trained Trogdor to pWn
mac_24_seven's Avatar
Ride:  94 GSR Sedan
Rep Power: 16 mac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura about
Yes, Crome, sorry :P We've talked about it a lil before. We each have a spare laptop, both of our ECU's are chipped and socketed already, so were good to go for the most part.
We'll see what qbert says in a lil bit.
mac_24_seven is offline   Reply With Quote
Old 08-12-2008, 12:40 PM   #2127
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 189 BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
myspace
Turbo?
Awesome!
PSN Network ID: BrutalB83
Old 08-12-2008, 02:53 PM   #2128
Reverend Awptickes
awptickes's Avatar
Ride:  1999 Civic EJ9, 2009 Fit GE8, 2006 Suzuki SV650s
Rep Power: 184 awptickes has a reputation beyond repute
awptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond repute
 FaceBook
Andrew:
If you're going to recirculate, here's some food for thought:
☻/ DIY/Howto HID Projector retrofit
awptickes is offline   Reply With Quote
Old 08-12-2008, 05:20 PM   #2129
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
Got my outlet figured out:
Might need to cut this out with the dremel:
Picked up some more stuffs for my oil drain:
(the AN fittings were cheap so I bought some extra)
Added my vacuum manifold:
Got the crazy bends figured out thanks to my box of couplers, sawzall, and other random crap.
Heres how close the piping is to the manifold. I'll probably heat wrap it.
I was going to pull my head off and drop the new gasket in, but I couldn't bring myself to do it. I was running out of juice. Plus I start school Monday so I'm trying to keep the car as close the running as possible.
I'll do the head gasket swap tomorrow. I'm going to reuse my bolts since I haven't ordered them yet. Since I'm only running low boost I think I'll be ok for now. I don't think this little turbo will cause head lifting
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-12-2008, 05:52 PM   #2130
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
Rep Power: 215 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
Hell yeah, heat wrap would make it look better. But who cares about looks, all go no show.
^ (dont listen)
There is a hidden message here.
"Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details."
"In the dice game of life who gets the last roll?"
Old 08-12-2008, 06:17 PM   #2131
Conan The Hondarian
wikedeye's Avatar
Ride:  1993 Honda Civic Dx Coupe
Rep Power: 28 wikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to behold
Send a message via AIM to wikedeye
Now thats ingenuity for ya. Good job making it fit.
Originally Posted by 99sidude View Post
yes silicone lubricant worked great on my shaft. highly recommend.
XBL: Wikedeye
wikedeye is offline   Reply With Quote
Old 08-12-2008, 06:46 PM   #2132
Andrew's Avatar
Ride:  1991 CRX Si
You gotta do what you gotta do!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-12-2008, 08:17 PM   #2133
Conan The Hondarian
wikedeye's Avatar
well keep doing it because it is helping me stay focused.
XBL: Wikedeye
Old 08-13-2008, 12:25 AM   #2134
Reverend Awptickes
awptickes's Avatar
 FaceBook
Yeah, I'm not too worried about my headgasket/head from lift either. I wouldn't worry about it for now, but if you decide to turn up the boost, I'd drop a new gasket in.
Have you done a leakdown?
It's looking good. You'll be boosted before me by the looks of it. I haven't gotten my drain yet.
Old 08-13-2008, 03:05 AM   #2135
Apocalypto's Avatar
Ride:  A small Honda vehicle
Rep Power: 4 Apocalypto will become famous soon enough
Did someone say Turbo? Check out the first 8 seconds of this video...
Apocalypto is offline   Reply With Quote
Old 08-13-2008, 05:12 AM   #2136
My name is Byron.
efhondakid's Avatar
ANd the point of that was?
^ (dont listen)
Old 08-13-2008, 07:09 AM   #2137
Ride:  94 GSR Sedan
n00b.
And Andrew, I'm gonna have to buy another radiator myself... Mine isn't gonna fit with the turbo. Such a bummer :P
Oh and did dude text you back about the injectors and whatnot?
Another thing.... All we need to Datalog in a cable and a laptop w/tuning software. Plug it into the ECU, then to the laptop: BOOM, good to go. **Edit** Well, it's a lil more involved than that, but thast the jest of it.
http://www.moates.net/zips/crome/Tun...ME%20v1.03.pdf
And one more thing... DL the tabs to "Saints of Los Angeles".. Or heck, just get some tabs for some staind or disturbed or any of the crap I listen to so we can jam out some this weekend!
1994 Acura Integra GS-R Sedan
My MAIN DB8 project thread on Honda-Tech: Very detailed of EVERYTHING I've done to my car.
Contact me for ITR header skid plates: $40.00 shipped!!!
Old 08-13-2008, 10:57 AM   #2138
Apocalypto's Avatar
noob?? I post a link to an interesting youtube video of a nasty F1 turbo and you high and mighty goofballs call me a noob?? Idiots. I've been on the "Internets" longer than many of you little punks have been alive.
I guess my intellect and sense of right and wrong is not worthy in this pool of CAR GODS.
Honestly? From what I've seen in the few weeks I've been here, many of you guys are so full of yourselves it's ridiculous. You seriously need to watch your attitudes. Primadonnas on a car internet forum. Now I've seen it all. If this is what HondaSwap is all about, ask the Ops to ban me so you can all sit around and circle jerk your egos together in peace.
Old 08-13-2008, 11:11 AM   #2139
Reverend Awptickes
awptickes's Avatar
 FaceBook
I just think that nobody knew where you were coming from with that video post. Maybe it didn't seem on-topic. Dunno, I can't get to youtube here at work.
Old 08-13-2008, 11:34 AM   #2140
Ride:  94 GSR Sedan
Yep, exactly where I was coming from. I mean, you said watch the first 8 seconds.. and I watched 11 :P 3 more seconds than recommended!!! It was a picture of a turbo.
Ok, great.
You had nothing else to add to that.. I mean, you could have at least said something to the effect of..
"Hey, since you guys are tlakin about turbo's, here's a video of some turbo F1 cars. maybe you guys will be as fast as them one day..."
Or something to that effect. You let us know what the video was and threw a lil humor into it. Not just some random thing. I know YOU knew what you were thinkin, but we didn't. Maybe we aren't on the same level as you
BTW, any primadonna's posting in this thread? BTW, I'll be 27 in a month (terrible) so I doubt you've been on the interweb longer than I've been alive.
Old 08-13-2008, 02:11 PM   #2141
Andrew's Avatar
Ride:  1991 CRX Si
I thought his video was a cool find. I seems like Renault was ahead of their time with that car and setup.
I'd LOVE to drive an open-wheeled car. *drool*
Thanks for posting it. And don't get upset over Terrance. We say "noob" like we eat food. (all the time, for no apparent reason )
Update-
I'm welding some -10 bungs today. 2 on the valve cover for crankcase pressure and 1 on the oil pan for the drain line.
Also, if anyone can find me the part # to the Prelude nipple thing for the back of the engine I'd be much obliged. I need to order that too so I can continue setting up a catch can. Speaking of which, Terrance, we need to talk about welding me up a "box" can like the "big boys" on H-T. I can provide the -10 fittings if you can do the welding
I'm also going to be torching/notching the bumper support and crossmember to clear the radiator and the FMIC. FYI the crossmember will be temporary until I can afford an aftermarket one.
And the bumper support- I want to get my hands on an HF support. I remember seeing them and they were tiny! apparently lots of T-EF owners do it. I wanna join the bandwagon.
edit:
Oh, and hey. I have an opportunity to pick up two (2) 1981/2 Civic Wagons (CVCC) for under $500.
Should I do it? Klyph, I'm probably going to pick your brain about the whole thing later. (like how hard it is to wire in a "modern" engine and such. I'm thinking of doing a stock D16Z6 swap into 1 of them (the 5spd one which happens to be in better shape anyway) and using the other as parts.
If you guys don't know what I'm talking about, it looks like this:
http://hotrod205.files.wordpress.com...icwagon83a.jpg
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-13-2008, 05:20 PM   #2142
Conan The Hondarian
wikedeye's Avatar
More cars for "Andrews Used Car Lot"...you should just start your own shop and specialize in engine swaps, any car any engine could be your slogan.
To the guy above, dont get so angry its just the internet. Most of the people here are cool and dont usually mean any harm.
XBL: Wikedeye
Old 08-13-2008, 07:26 PM   #2143
Korax's Avatar
Ride:  1990 ED DX jdm D15B dual carb;x 1991 ED DX B16A OBD0
Rep Power: 20 Korax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of light
Send a message via AIM to Korax myspace
I would totally do it. I think it would be cool to have something like this one day.
PSN: Korax37
Korax is offline   Reply With Quote
Old 08-13-2008, 07:33 PM   #2144
Conan The Hondarian
wikedeye's Avatar
Thats a pretty mean looking car there korax...
XBL: Wikedeye
Old 08-13-2008, 07:35 PM   #2145
Korax's Avatar
1974 Civic 1200.
PSN: Korax37
Old 08-13-2008, 07:44 PM   #2146
Conan The Hondarian
wikedeye's Avatar
The first honda I ever drove was a late 70's cvcc...My friend had one and he was always too drunk to drive so I usually got to do the driving. Ah the good old days when a 15 year old kid in Oklahoma could drive anywhere he wanted without a license. Sorry didnt mean to thread jack with my memories.
XBL: Wikedeye
Old 08-13-2008, 11:13 PM   #2147
Andrew's Avatar
Ride:  1991 CRX Si
Lots of pics. warning!
I mounted the Intercooler yesterday, but today I held up the Bumper support and mentally noted what needed to be done to make it right.
Next I dropped my oil pan and was thoroughly shocked by how clean it was under there. WOW. Just look! (I didn't clean at ALL before taking this pic.)
... I know right??? 8k miles = like new.
Anyway. Then I pulled the Valve Cover to put the vent fittings on.
Torched and welded a steel plate on the crossmember to clear the DP:
Torched and welded the bumper support. Raised it about 3/4" to give the FMIC some room to breathe.
After some paint:
Test fit:
Then my buddy Ryan stopped by:
Ok. It's about to get ghetto in here. HMT FAUX LIFE!
Custom $8 downpipe from Advanced Auto! woot
After some modification and welding (yes I actually welded it and then put JB weld on it to seal it(cause I was just using my crappy flux cored wire b/c I'm out of Argon))
Then I JBWelded my fittings on:
And a couple for fun
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-13-2008, 11:16 PM   #2148
My name is Byron.
efhondakid's Avatar
Looking good.
^ (dont listen)
Old 08-14-2008, 07:15 AM   #2149
Ride:  94 GSR Sedan
Me likey this pic much!
Old 08-14-2008, 09:39 AM   #2150
Korax's Avatar
It's coming along very nice.
PSN: Korax37
Engine swap: d15b7 to d16y7; transmission? oakley2002@cox.net HYBRID -> EG-EK / DC 7 10-28-2009 07:19 PM
Best Engine Swap For 95 Integra Ls Agt_Orange_GSR HYBRID -> EG-EK / DC 7 09-23-2008 04:16 PM
EE crx engine swap. DAZ81 HYBRID -> ED-EF / DA 6 11-25-2003 10:21 AM
81 Civic Engine Swap Help fjcisco13 HYBRID -> EG-EK / DC 3 04-23-2003 06:16 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
