Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Andrew's engine swap (pics)
Old 08-17-2008, 04:11 PM   #2176
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
Update-
Got the bumper mounted-
Threw some fittings on there. I should just leave them like so:
See what I mean about doing the "visible" side last? this JB is so much cleaner.
o2 sensor. Anyone think this needs to be post-turbo for any reason? theres one right next to it on my Downpipe, so its a piece of cake to change.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-17-2008, 04:49 PM   #2177
Reverend Awptickes
awptickes's Avatar
Ride:  1999 Civic EJ9, 2009 Fit GE8, 2006 Suzuki SV650s
Rep Power: 184 awptickes has a reputation beyond repute
awptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond repute
 FaceBook
Lookin' good.
I fixed my brakes today. And helped out in a Horse Jumping tournament. I'm dead tired.
☻/ DIY/Howto HID Projector retrofit
awptickes is offline   Reply With Quote
Old 08-17-2008, 04:50 PM   #2178
Yeah
EF9_Hatch's Avatar
Rep Power: 57 EF9_Hatch has a reputation beyond repute
EF9_Hatch has a reputation beyond reputeEF9_Hatch has a reputation beyond reputeEF9_Hatch has a reputation beyond reputeEF9_Hatch has a reputation beyond repute
Send a message via AIM to EF9_Hatch myspace
Looking good man...Now get a vid of it running!
"It's not what you drive, but how you drive it."
XBL Gamertag= W0BBnIT <---- 0 is a Zero
EF9_Hatch is offline   Reply With Quote
Old 08-17-2008, 10:19 PM   #2179
Andrew's Avatar
Ride:  1991 CRX Si
^ X your fingers for tommorrow! My radiator gets in tommorrow, but I might just have to jump the gun and do it first thing in the morning before class (I go it from 12-3 this quarter! last class ftw)
I'm all finished up except for the radiator and tuning!
I welded the oil pan really well and then JBWelded it to seal it all up. Shouldn't have any problems
Moved the vacuum manifold to a more "neutral" location.
Terrance gave me a GSR cluster:
Where is this light coming from?
The source to my Honda's power:
Tommorrow should be startup day!
First off I'm going to need and Retard my cam-gear 3*.
Heres my decision process.
I have 10.5:1 Pistons.
Head is milled .xxx", or .5:1 comp worth.
if .1:1 is changed every .012", that means I'll have to Advance 4* to cover what my head was milled.
but throw my .074" gasket into the mix, (7* retard for that size)
The difference is 3* retarded.
Hopefully someone can understand at least 1 word of that.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-17-2008, 11:05 PM   #2180
haao13's Avatar
Ride:  boosted sir eg, suzuki gsx750f
Rep Power: 11 haao13 will become famous soon enoughhaao13 will become famous soon enough
love the thread bro. im actually running the same set up on my z6 so i cant wait to see that thing run!
haao13 is offline   Reply With Quote
Old 08-17-2008, 11:33 PM   #2181
Conan The Hondarian
wikedeye's Avatar
Ride:  1993 Honda Civic Dx Coupe
Rep Power: 28 wikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to behold
Send a message via AIM to wikedeye
Does the flex pipe hold pressure or will you find out tomorrow? Congrats on the last class.
Originally Posted by 99sidude View Post
yes silicone lubricant worked great on my shaft. highly recommend.
XBL: Wikedeye
wikedeye is offline   Reply With Quote
Old 08-18-2008, 07:20 AM   #2182
I trained Trogdor to pWn
mac_24_seven's Avatar
Ride:  94 GSR Sedan
Rep Power: 16 mac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura about
I think we worked on it abotu 6-7 hours Friday night??? Till like 1:15 in the morning? Still havn't recovered.
Dude, you better call me when before you crank it!!!! I've gotta at least hear it the first time it's fired up w/boost!
mac_24_seven is offline   Reply With Quote
Old 08-18-2008, 07:31 AM   #2183
Reverend Awptickes
awptickes's Avatar
 FaceBook
Boost Compression Ratio Calculator
Remember to take a look at that. You don't want to blow it up on the first crank. (Or shortly after you crank it, because you couldn't help but rev it before tuning it.)
Old 08-18-2008, 07:46 AM   #2184
Ride:  94 GSR Sedan
Max altitude in Tally is 200 feet above sea level...Compression ratio would be like 17.6:1
Whoa.
And Andrew, I freaking forgot the oil thing in the Xb. Sketch out the lil flange you need and I'll get some spacers made for ya that won't be ugly and non-flat. I'm also gonna get you a couple of pieces of Aluminum, 1/8, 3/16 and 1/4 so you can have it if you need it.
Old 08-18-2008, 08:50 AM   #2185
Andrew's Avatar
Ride:  1991 CRX Si
Effective Compression ratio is always going to be higher than Static. A 9:1 comp engine pushing 10 psi is at 15:1 effective.
It doesnt mean you can't run boost just because it's high, you just need to have a rock solid tune.
Lotus is coming out with a turbo engine for one of their new cars w/ 11.5:1 compression boosting 5-6 psi. imagine what the Effective compression ratio is for that! not to mention it's going to be in europe, with mucho hills and higher altitude in general.
What kind of power are you making?
You mean does it leak? If I had to guess, it's going to leak like a sieve at the mating point where it meets my exhaust.
If your talking about my charge piping? idk.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-18-2008, 10:17 AM   #2186
Conan The Hondarian
wikedeye's Avatar
Compression is affected by altitude? Is there an article that you know of that will teach me a little about that?
XBL: Wikedeye
Old 08-18-2008, 10:59 AM   #2187
Reverend Awptickes
awptickes's Avatar
 FaceBook
The altitude wasn't what I was talking about. I was pointing out that you're going to be running pretty high effective compression, so your tune needs to be really good.
I'm in the same boat, just my static compression ratio is 9.8:1.
Old 08-18-2008, 11:09 AM   #2188
Ride:  94 GSR Sedan
We have a good tuner, so I don't think that will be a problem. max will double check to make sure Andrew has everything set up right so when he goes out there, Andrew will be ready to rock.
1994 Acura Integra GS-R Sedan
My MAIN DB8 project thread on Honda-Tech: Very detailed of EVERYTHING I've done to my car.
Contact me for ITR header skid plates: $40.00 shipped!!!
Old 08-18-2008, 11:25 AM   #2189
Andrew's Avatar
Ride:  1991 CRX Si
Yep.
My radiator just showed up. I'm going to have a "fun" time installing this thing.
I really just need to get a freaking traction bar. This stock Crossmember is killing me.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-18-2008, 11:36 AM   #2190
Ride:  94 GSR Sedan
That crossmember does blow, especially now that it's all hacked up and whatnot.
Old 08-18-2008, 11:11 PM   #2191
haao13's Avatar
idk yet. im waiting on my downpipe and ecu. im hoping for around 180. looks like you might be boosting before me so keep us posted on your progress and numbers
Old 08-19-2008, 04:19 PM   #2192
Ride:  94 GSR Sedan
Dude, I made (3) 3/16 spacers for you today. They match nearly perfect to the oil return. MUCH better than what you have now, plus they are flat :P I'll give em to Meglet so you can have em tomorrow
Old 08-19-2008, 04:34 PM   #2193
Andrew's Avatar
Ride:  1991 CRX Si
Great! Thanks man!
I'm getting ready to drop $500... $220 shipped o the WideBand (AEM UEGO) and $284 shipped on the ETD Traction bar. Ugh.
It's necessary, but dang. I hate doing this. especially when I want to buy a new car soon.. geez.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-19-2008, 04:47 PM   #2194
Reverend Awptickes
awptickes's Avatar
 FaceBook
Great! Thanks man!
Try searching the FS forum first on the wideband. There's a few people selling widebands there. That'll save a few bucks.
Old 08-19-2008, 04:47 PM   #2195
Reverend Awptickes
awptickes's Avatar
 FaceBook
What are the 3/16 spacers on the oil return do?
Old 08-19-2008, 04:53 PM   #2196
Ride:  94 GSR Sedan
His oil return was a lil short and it kinked the line if he mated the flange to the turbo, she he needed a couple of spacers to get rid of the kink.
ANd did you talk to Max about the AEM? Is that what he suggested?
Old 08-19-2008, 04:58 PM   #2197
Korax's Avatar
Ride:  1990 ED DX jdm D15B dual carb;x 1991 ED DX B16A OBD0
Rep Power: 21 Korax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of lightKorax is a glorious beacon of light
Send a message via AIM to Korax myspace
Learn something new about Andrew everyday.
PSN: Korax37
Korax is offline   Reply With Quote
Old 08-19-2008, 05:14 PM   #2198
Andrew's Avatar
Ride:  1991 CRX Si
^ hahahaha! "FIFTH!"
I'll look around for a used one.
Dustin (Busted Ej1) recommended it to me. I'll try and remember to to call Max but I can never seem to be able to. I always get distracted by the time he's done with work at 7! =/
I found a good deal on Craigslist for a 'new' D16Z6 head for $200. Should I jump on it? Does anyone on here want the link?
Originally Posted by seller
the actual head casting is new , i reused rocker arms but had them all checked out before i reused them , everything is in good shape , has the stock cam and cam gear included ,
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-19-2008, 05:24 PM   #2199
Ride:  94 GSR Sedan
Negative. If you're jumpin on anything, jump on that B16 for $500.00. Offer him $400.00 for it and sell the tranny for $300.00. Then turbo THAT instead of the D16 <laughs>
Max said AEM was good.. but was gonna get back with me. Just call em and leave a message!
Old 08-19-2008, 07:07 PM   #2200
Andrew's Avatar
Ride:  1991 CRX Si
Working on it. He didn't have any contact info so I can't get in contact with him. I sent a "note" to Craigslist about it. We'll see. I'd LOVE to do a stock B16 turbo. Maybe it will work out.
I've got some stuff to trade him, so I'll see what he says when he gets back to me.
Edit: Great. Now I'm looking at this:
2004 Accord K24A4 2.4 litre with 29k miles and a 2002 RSX type S 6-speed tranny with 42k miles. 1700.00 OBO
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Engine swap: d15b7 to d16y7; transmission? oakley2002@cox.net HYBRID -> EG-EK / DC 7 10-28-2009 07:19 PM
Best Engine Swap For 95 Integra Ls Agt_Orange_GSR HYBRID -> EG-EK / DC 7 09-23-2008 04:16 PM
EE crx engine swap. DAZ81 HYBRID -> ED-EF / DA 6 11-25-2003 10:21 AM
81 Civic Engine Swap Help fjcisco13 HYBRID -> EG-EK / DC 3 04-23-2003 06:16 PM
