Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Andrew's engine swap (pics)
Old 09-14-2008, 12:50 PM   #2301
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
very good logic..hope it works.
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 09-14-2008, 01:20 PM   #2302
Reverend Awptickes
awptickes's Avatar
Ride:  1999 Civic EJ9, 2009 Fit GE8, 2006 Suzuki SV650s
Rep Power: 184 awptickes has a reputation beyond repute
awptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond repute
 FaceBook
Originally Posted by Andrew View Post
Very simply put(and pretty common I suppose):
I'm going to run smaller piping on the hot side. Say 2". And larger piping on the cold side, say 2.5" like it is now. This will let the air expand even more post-intercooler and let it cool my IAT's down a little bit.
Ok, keep in mind that while this will give you cooler IATs, it will decrease velocity.
It will also decrease pressure while, but that's a moot point since you'll have lower temperatures.
Many professionally designed kits, and even factory turbo implementations have a smaller high-temp charge pipe, and a larger low-temp charge pipe. So I'd say you're on the right track. Just run the numbers and ensure the velocity is correct for your engine.
☻/ DIY/Howto HID Projector retrofit
awptickes is offline   Reply With Quote
Old 09-15-2008, 08:45 AM   #2303
I trained Trogdor to pWn
mac_24_seven's Avatar
Ride:  94 GSR Sedan
Rep Power: 16 mac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura about
Andrews polished wheels..
before:
After:
Before:
After:
Before:
After:
Hope ya like em mang! Free polishing FTW (for you :P). I think I hurt my knuckle pretty good whenever I was hand polishing the one wheel (before I bought the lil powerball thingy). :S
Its all good though
mac_24_seven is offline   Reply With Quote
Old 09-15-2008, 08:47 AM   #2304
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
You da best man! I'm sure those pics don't do much justice, but it does look awesome!
I'm starting to wonder if they would look better with the inerds painted grey?
BTW guys I'm getting some piping from Terrance tommorrow to make some crazy bends on the hot side
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-15-2008, 01:25 PM   #2305
Ride:  94 GSR Sedan
No, they don't. I think they look great, considering how little work was put into em.
BTW, I have ure pipe.. 2" Sch 80 @ 2' long. Should be enough to play with I think. Also.... I may be getting my car painted soon, by a shop My turbo stuff may be going on hold.....
1994 Acura Integra GS-R Sedan
My MAIN DB8 project thread on Honda-Tech: Very detailed of EVERYTHING I've done to my car.
Contact me for ITR header skid plates: $40.00 shipped!!!
Old 09-15-2008, 02:34 PM   #2306
haao13's Avatar
Ride:  boosted sir eg, suzuki gsx750f
Rep Power: 11 haao13 will become famous soon enoughhaao13 will become famous soon enough
sorry for the thread jack andrew but wat did you use on your feed line? is it just a compression fitting with a an fitting?
haao13 is offline   Reply With Quote
Old 09-15-2008, 02:43 PM   #2307
Andrew's Avatar
Ride:  1991 CRX Si
Yep. I don't have any closeups, but yeah. the previous owner of the snail put a brass compression fitting on the stock line. It's actually just a simple 1/8npt compression fitting (really cheap from lowes etc) and I used a 1/8npt/-3an union I got from a local shop called Capital Rubber. They do all sorts of hydraulic lines and fittings, And the a -3an line. I used the same type of union on my sandwich adapter.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-15-2008, 03:33 PM   #2308
Andrew's Avatar
Ride:  1991 CRX Si
Ok well I just did the calculations for my pie-cut PER this forumula. More easily- this spreadsheet calculator
So I'll begin construction on it this week!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-17-2008, 02:45 PM   #2309
Ride:  94 GSR Sedan
OH man, I've got a suprise for you Its simple, but VERY, VERY cool. Something that nobody else will have but you buddy.
Should be done today. It's so nifty and cool, I'm excited about it!! And are you gonna have that pipe cut so I can weld it tomorrow?
**Edit** Here it is!
Thats right... 1 piece aluminum fool! Had it machined with a CNC machine It's 5/8" thick and sexy You may have to tap the holes slightly bigger, but that won't be a problem w/your drill press.
Welding the 3 pieces together woudl have been uber hard if not impossible to do and it not leak. This was the only other option!
You like?
Old 09-17-2008, 05:08 PM   #2310
Andrew's Avatar
Ride:  1991 CRX Si
Awesome!!!
Heres a teaser for the rest of yous guys too!
Got my argon tank filled so I can tack this aluminum
Then me and dad whipped up a wooden mockup of the loop.
It sits about like this.
Kind of held in place. kinda difficult to do 1 handed. but you get the idea
So after we got the angles right we started chopping up the 2" alum. tubing I got from Terrance. (sched. 80)
And started to champfer (sp?) the edges so his guys can TIG them together.
(I'll be tacking them with my MIG)
I've got to finish up with those and start mocking up!! Should be done early next week with it all...
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-17-2008, 06:00 PM   #2311
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
damn..cant wait for more pix..
GOOD FAST CHEAP,
Old 09-17-2008, 09:44 PM   #2312
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
Rep Power: 222 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
I like the "ahh that one is no good" pile in the background of the wooden mock up pic lol.
^ (dont listen)
There is a hidden message here.
"Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details."
"In the dice game of life who gets the last roll?"
Old 09-17-2008, 09:58 PM   #2313
Andrew's Avatar
Ride:  1991 CRX Si
Ha yeah, but thats why we did it with wood!! unlimited cuts can be made. metal was limited to 2'.
The first time around, we did as my calculations specified, at 11*. We decided it needed to be a tighter bend, so we stepped it up to 13* and it did the job!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-18-2008, 08:41 AM   #2314
Ride:  94 GSR Sedan
Dude, I bought my zex kit for $50.00 and sold it for $80.00
So, when you I get ure stuff welded and you get it back on Tuesday.... What do you have left? I mean, as far as I know, this along with the radiator have been your problem areas.
Pending your car actually has compression from the drilling of the headgasket, all you'll need to do it take it to Max.. or have Max come to you I guess.
Possibly running next weekend??!!
And ure using your old intercooler.. So I can has my intercooler cheezeburger back?
Old 09-18-2008, 08:48 AM   #2315
Andrew's Avatar
Ride:  1991 CRX Si
yep yep yep! It's all yours!
I should get my hands on Devin's "AEM NOT" intake and see about getting that on there. I think as my setup is now, boost leaks will be the death of me. which is fine, because I'd rather leak out pressure than hit my motor with 10lbs right off the bat lol.
Seriously. if this motor doesn't like this boost stuff, and lets go. I'm dropping in a bome-stock Z6 in decent condition and letting it RIP.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-18-2008, 08:49 AM   #2316
Reverend Awptickes
awptickes's Avatar
 FaceBook
You like?
That's not for a wastegate, is it?
Old 09-18-2008, 08:59 AM   #2317
Ride:  94 GSR Sedan
Yay!
And no awptickes, it's for his oil drain.
And Andrew, I assume you have'nt heard anything form the loser in ATL abotu the turbo stuff?
I say it's kneecap breaking time!
Old 09-18-2008, 09:47 AM   #2318
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Yay!
sorry to thread jack but i was reading your build on HT and saw on the first or second page that you did LED's in your cluster..do you possibly have a write-up cuz it came out sick..
i believe nickbeam was gonna do one but i have yet to see it
GOOD FAST CHEAP,
Old 09-18-2008, 10:40 AM   #2319
Ride:  94 GSR Sedan
PM me.
So Andrew, I was going through the for sale threads on H-T, saw a guy selling a ram horn manifold. Here it is.
Sexy, yes, no?
Well it is. As I was looking at that manifold, I noticed something........... There are no more than 6 tubes welded together to make the primaries. 6 on the front, looks like 4 in the back (including collector tubes).
So, that got me thinkin about fabbing up our own manifolds.
I started lookin around the interwebs and found this:
Tech Page
I may be thinkin a lil off, but it looks like what YOUR DOING with the intercooler piping is actually HARDER than making a freaking manifold!!
Thoughts?
here's another one..
building a turbo header w/ sched 40 weld pipe - Page 5 - HybridZ
Moare link:
http://autospeed.com/cms/A_2605/article.html
grat idea for building collectors.
http://www.theturboforums.com/smf/in...&topic=65147.0
Though, here's what ours woudl prob look like :P
http://aaronactive.net/images/photoa.../photo_330.jpg
If we had the materials, tell me why, with a lil planning, we could'nt fab up a manifold in a weekend?
Old 09-18-2008, 12:18 PM   #2320
Andrew's Avatar
Ride:  1991 CRX Si
I've really be thinking about it. weiRtech has the best deals on flanges btw
couple 90's and we're good to go!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-18-2008, 12:33 PM   #2321
Ride:  94 GSR Sedan
Dude, why not?
I decided to go out on lunch and fiddle with some spare pipe for a lil bit.
Dare I say a very crude proof on cencept? Well, not really proof of concept. Just shows how crappy I can make 1/4 of a mini ram horn setup without 90 degree bends and eye balling everything.
If I had a bender that did 90 degree bends, I could have made it look chica-ka-ka-drillion times better
Old 09-18-2008, 01:01 PM   #2322
Andrew's Avatar
Ride:  1991 CRX Si
do it man! get some 304 ss and let'er rip!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-22-2008, 11:06 AM   #2323
Ride:  94 GSR Sedan
Shoulda went buddy. Nice racin goin on that night.
Old 09-22-2008, 11:59 AM   #2324
Andrew's Avatar
Ride:  1991 CRX Si
I know!!! Oh well... I will not miss the Ranger going 9's.
BTW, I'm not going to tack the pipe. I'm just going to tape it, kinda like you posted above, but with smaller tape so that you guys can do the tacks and then pull the tape and weld it. I can't get my aluminum to feed through my machine, it's having a problem gripping it. It grips solid wire just fine, but aluminum is to soft or slippery I guess. the wheels can't get it.
Anyway. I'll have that down to you tomorrow or wednesday.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-22-2008, 12:44 PM   #2325
Ride:  94 GSR Sedan
Best by tomorrow. Might need a day or so to get it all welded.
Engine swap: d15b7 to d16y7; transmission? oakley2002@cox.net HYBRID -> EG-EK / DC 7 10-28-2009 07:19 PM
Best Engine Swap For 95 Integra Ls Agt_Orange_GSR HYBRID -> EG-EK / DC 7 09-23-2008 04:16 PM
EE crx engine swap. DAZ81 HYBRID -> ED-EF / DA 6 11-25-2003 10:21 AM
81 Civic Engine Swap Help fjcisco13 HYBRID -> EG-EK / DC 3 04-23-2003 06:16 PM
