Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Andrew's engine swap (pics)
Old 09-30-2008, 09:35 AM   #2376
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
I want to know whats going on first before I order anything.
I know it's 99% likely going to be the headgasket; but who knows man.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-30-2008, 11:32 AM   #2377
I trained Trogdor to pWn
mac_24_seven's Avatar
Ride:  94 GSR Sedan
Rep Power: 16 mac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura about
Originally Posted by Andrew View Post
I know it's 99.99999999999999999999999999999999 99999999999
99999999999999999999999999999999999 9999999999999999999
99999999999999999999999999999999999 99999999999999999999
99999999999999999999999999999999999 999999999999999999999
99999999999999999999999999999999999 9nine999999999999999999
99999999999999999999999999999999999 9999999999999999999999
99999999999 and 9.9% likely going to be the headgasket; but who knows man.
Fixed
Well quite ure lollygaggin' around and get on it son!!!!
mac_24_seven is offline   Reply With Quote
Old 09-30-2008, 01:02 PM   #2378
Andrew's Avatar
Ride:  1991 CRX Si
School and work maine!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-01-2008, 11:25 PM   #2379
Andrew's Avatar
Ride:  1991 CRX Si
Getting a leakdown checker tomorrow. I'm wondering now if it wasn't actually my headgasket afterall... I sure hope it is/was something simple... but - it never is..
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-04-2008, 12:47 PM   #2380
Reverend Awptickes
awptickes's Avatar
Ride:  1999 Civic EJ9, 2009 Fit GE8, 2006 Suzuki SV650s
Rep Power: 184 awptickes has a reputation beyond repute
awptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond repute
 FaceBook
I dunno. With the way you drilled that HG out, it would make sense that 3 and 4 would lose compression, but not #1.
Do you have a pre-cometic HG compression test? Sounds like it could be a valve too....... Did you check the head and block with an engineer's ruler or anything?
Worst case it could be your block-guard causing the sleeve to sink. That'd suck.
☻/ DIY/Howto HID Projector retrofit
awptickes is offline   Reply With Quote
Old 10-04-2008, 09:11 PM   #2381
Andrew's Avatar
Ride:  1991 CRX Si
Compression leakdown shows it blowing by the rings.
I talked to KMS and John is sending me a free set of piston rings this week.
I'm going to order some Vitara's and rod bearings from FJDistributors and do a Vitara setup with more boost(different turbo). Vitara pistons and a Zex 59300 cam. I've already got the valve train to handle it. And my bottom end is pretty solid. Looking to run a 50 trim turbo. something like a .48/.63 size w/ external wastegate obvously.
stay tuned, I guess!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-05-2008, 04:38 AM   #2382
Reverend Awptickes
awptickes's Avatar
 FaceBook
Don't get vitaras. Please.
Vitara pistons are for garage/dyno queens and people who don't like (or know how) to tune. Their biggest strength is that they allow you to boost more, but there's no power before spool. You want a fun, drivable car, right? When will you make boost with a 50 trim? Compression off-boost is what makes a car easy to drive, when you lower your compression to make absolutely no power off-boost it's suddenly not so fun to drive.
If you're serious about this, think about staged turbos to give you at least some dynamic compression before the 50-trim spools.
Old 10-05-2008, 03:31 PM   #2383
Andrew's Avatar
Ride:  1991 CRX Si
I guess I hadn't thought of that. I'm going to run the #'s for compression with my setup and see what I come up with with some different setups.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-05-2008, 03:44 PM   #2384
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
damn..was it faulty rings or just improper breakin?
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 10-05-2008, 03:45 PM   #2385
Reverend Awptickes
awptickes's Avatar
 FaceBook
Good idea. Math will prevail.
Old 10-05-2008, 03:46 PM   #2386
Reverend Awptickes
awptickes's Avatar
 FaceBook
do you remember his 'break-in' ?
I think he took it for a few joy rides before it got tuned. But I don't remember exactly, so lemme look back.
EDIT:
It could have been a bad-break in. Judging from what's in the thread, it just needs a good hone/crosshatch and some new rings. Actually, if you have the stuff to check the round, I'd just crosshatch and put new rings in.
Old 10-05-2008, 04:06 PM   #2387
Andrew's Avatar
Ride:  1991 CRX Si
who knows, maine. I'm not worried about it. This gives me a good excuse to put "turbo savvy" pistons in there to give me a good compression... the RIGHT way. not using a thick headgasket.
Ran some #'s on Zeal...
Z6 pistons and headgasket will give me 9.85:1 compression ratio. Thats about perfect.
Now I need to find some Z6 pistons .020" OS. Honda makes them .025" OS. So... idk. I'll have to look around.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-05-2008, 04:11 PM   #2388
Reverend Awptickes
awptickes's Avatar
 FaceBook
Yeah, 9.8:1 is about perfect for a small turbo engine. It makes me sad every time I see that people go with 9.8:1, because my engine is 9.8 stock.
Might want to look at aftermarket. But if you go that route, go forged with H-beam rods. Rebuilding gives you a good excuse to inspect everything, and spec it all out to check for wear too.
Old 10-05-2008, 04:18 PM   #2389
Conan The Hondarian
wikedeye's Avatar
Ride:  1993 Honda Civic Dx Coupe
Rep Power: 28 wikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to behold
Send a message via AIM to wikedeye
You should get aftermarket pistons, because of the heat. You dont want them to go bad from overheating.
Originally Posted by 99sidude View Post
yes silicone lubricant worked great on my shaft. highly recommend.
XBL: Wikedeye
wikedeye is offline   Reply With Quote
Old 10-05-2008, 04:45 PM   #2390
Andrew's Avatar
Ride:  1991 CRX Si
I dont know how I feel about forged pistons anymore. I don't think they are necessary. I do not want to hear them slapping around left and right like this motor does. I think a regular set of pistons will do just fine since I don't forsee this engine seeing more than 300whp.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-05-2008, 08:34 PM   #2391
Conan The Hondarian
wikedeye's Avatar
what do you mean slapping around. As in they dont fit properly. Plus I think it has a lot to do with the amount of boost (psi) as much as it does the amount of whp. Here is an excerpt from a book that I have that talks about it.
XBL: Wikedeye
Old 10-05-2008, 09:25 PM   #2392
Andrew's Avatar
Ride:  1991 CRX Si
Yeah. forged pistons make 4cyl's sound like diesels. unless it's bored correctly... Mine had .011" of piston/wall clearance, to account for the "growth" of the piston as it warms up. but thats a little excessive.
I'm thinking I might need to step up to a .040" OS bore (76mm) due to that reason. Only time will tell when I tear it down...
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-06-2008, 08:49 AM   #2393
Ride:  94 GSR Sedan
I don't think it was the break in at all. I think KMS did a pathetic job on the build and should have sent some KY Jelly with the engine and the bill.
It's alright.. I'm sure Andrew will come up with an excellent idea that will get his car up N running in no time.
Old 10-06-2008, 09:52 AM   #2394
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
ky to make getting fucked a little easier eh
but yea hes a wiz he'll figure sumthing otu
GOOD FAST CHEAP,
Old 10-06-2008, 09:58 AM   #2395
Reverend Awptickes
awptickes's Avatar
 FaceBook
True. True.
After the way they shipped his engine I'd never trust any of their work...
Old 10-06-2008, 10:53 AM   #2396
Andrew's Avatar
Ride:  1991 CRX Si
^ no joke man. I cringe everytime I think of it. But, in their defense (omg what am I saying?) the headwork is great. port n polish is spot on, very professionally done. but thats about the only good thing I'm pulling away from this situation. all the way around for them.
However they get a from me right now for sending me a full set of rings just because I called and complained about the engine to 'em! woot...
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-06-2008, 12:42 PM   #2397
Ride:  94 GSR Sedan
I wish there was something more that could be done. This is absolutely so pathetic. Man, imagine the B series that could have been built ( I knwo thats yoru dads fault).
<sighs>
What are you ever going to do?
On a side note, Andrew, I just got off the phone with my painter. I'm meeting him tonight to drop my car off!!!!! I'm so excited!!!!!!!!!!!!!!!!!!!!!!!!! We gotta get the "upgrades" to the D done so we can cruise!!
Old 10-06-2008, 07:04 PM   #2398
Andrew's Avatar
Ride:  1991 CRX Si
You guys are so upset about this whole thing. I don't have any bad feelings about it. Actually, I feel GREAT about it! I wasn't very comfortable running the setup I had. Cheap BOV, WG was a little too high PSI for what I wanted, charge piping was iffy (cold side)
This gives me time to make it right.
I hope to have the CRX running asap, Terrance. But with rebuilding the D16 and all, idk how long that will be
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-07-2008, 07:51 AM   #2399
Ride:  94 GSR Sedan
True... But we were SOOOOOO close to gettin your Rex goin man! It's NEVER gonan run! Should have just stuck with the B series in it.
**Edit** I won't bump your thread with my stuff... But you know I gots ta stick my freshly painted baby in here!
And this covers the overspray in the front
Now, you guys talk Andrew into getting his car sprayed! Cost $250.00
Old 10-09-2008, 06:20 PM   #2400
F.I. Junkie
Ride:  1996 Civic, 1992 Accord
Rep Power: 101 Matts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Send a message via MSN to Matts96HB
I would look into CP pistons for your rebuild.
From what I have heard, they swell far less. Maybe that would help to eliminate the problem you are talking about?
Unless of course you already had them, then I would be wrong again :P
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6-
Matts96HB is offline   Reply With Quote
Engine swap: d15b7 to d16y7; transmission? oakley2002@cox.net HYBRID -> EG-EK / DC 7 10-28-2009 07:19 PM
Best Engine Swap For 95 Integra Ls Agt_Orange_GSR HYBRID -> EG-EK / DC 7 09-23-2008 04:16 PM
EE crx engine swap. DAZ81 HYBRID -> ED-EF / DA 6 11-25-2003 10:21 AM
81 Civic Engine Swap Help fjcisco13 HYBRID -> EG-EK / DC 3 04-23-2003 06:16 PM
