Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Brad's Build
Old 11-29-2008, 03:24 PM   #51
SOHC on this!!
GlassHeadlights's Avatar
Rep Power: 66 GlassHeadlights has a brilliant future
I also have code 2. Oxygen sensor.
Originally Posted by A notable gynecologist
The best engine in the world is the vagina. It can be started with one finger, it is self-lubricating, it takes any size piston and it changes its own oil every four weeks. It is only a pity that the management system is so fucking temperamental.
GlassHeadlights is offline   Reply With Quote
Old 11-29-2008, 03:38 PM   #52
SOHC on this!!
Also when the ignition is "on" the fan comes on and stays on.
Old 11-29-2008, 04:49 PM   #53
SOHC on this!!
Ok we got it running on the OBD0 dizzy and the OBD1 ECU.
I think the dizzy is bad.
I'll update with pics, ect. later.
Old 11-29-2008, 06:14 PM   #54
SOHC on this!!
I also have code 4.
It ran terrable at first but gradually it got better. Its pretty smooth now at about 190 PSI per cylinder.
I had to retard the OBD0 dizzy a lot to get it to run.
Does anyone know the main weak point of a dizzy?
Old 11-29-2008, 06:33 PM   #55
SOHC on this!!
The old head being removed:
ECU hooked in:
Head off:
New head on:
All bolted in:
Old 11-29-2008, 08:39 PM   #56
SOHC on this!!
I got it to run really well with the PM6 ECU and dizzy.
I guess I'll have to get a new dizzy. Or does anyone know how to fix one? Or to troubleshoot one?
Everything else is holding up very nicely though.
Here is a video:
100_2251.flv - Video - Photobucket - Video and Image Hosting
Old 11-30-2008, 07:56 PM   #57
SOHC on this!!
Sorry for posting every five minutes, I just wanted it to run.
So first we bolted everything up and tried to start it and it didn't even attempt to run. So we pulled a plug and it had no spark.
Then I put the OBD0 dizzy back on with the OBD1 ECU and it ran but like shit. It sounded like a Subaru.
Then I put the PM6 OBD0 ECU back in and it fired and ran perfectly.
Then I put the OBD1 ECU and dizzy back on and "borrowed" the coil out of my moms Accord. Then it ran even better.
My dad and I took the car to the auto parts store and bought a new coil. When we got outside of the store I noticed a pool of coolant. It was leaking out of the top radiator mount on the head. It didn't overheat and we were able to limp it home.
I sealed the leak and we did our fourth compression test of the day and we ended up with about 190-200 PSI in each cylinder.
The headgasket sealed fine but only time will tell.
VTEC works completly fine. The only complaint I have is I expected more power but keep in mind it isn't tuned yet, its on a DX tranny now but not for long and its only been run for two days. It also has stock I/H/E.
We haven't hit the rev limiter yet but we're taking it easy for awhile.
While we were running it the oil light in the dash burnt out. Hmmmmmm.
I don't have any CELs but when I activated the ummm, two wires? I got code 2.
I'm very very happy anyway.
Old 11-30-2008, 08:50 PM   #58
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
Rep Power: 221 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
Nice, should be sweet once you get all the bugs worked out.
^ (dont listen)
There is a hidden message here.
"Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details."
"In the dice game of life who gets the last roll?"
Old 11-30-2008, 09:27 PM   #59
SOHC on this!!
Well right now its running on a old tired motor and a one month old used headgasket. It is running very well so far but I only expect it to run for a week or so.
I just wanted to see how everything would go. Next weekend we're swapping out my Mini-Me and putting the D16A6 out of my car into my dads car. Then I'll rebuild the whole Mini-Me.
I know its kinda confusing.
Old 12-01-2008, 06:30 PM   #60
SOHC on this!!
I went to Zensport Ltd.::High performance tuning specialists::. today and they will tune my car but for $350.
I heard I can tune it myself using this thing: Ostrich 2.0 : The New Breed [OSTRICH_2] - $175.00 : Moates.Net and its only $175.
My motor isn't too complicated and its not too far from stock so I don't see why I cant tune it myself.
I'll do more research and see what I can do.
Old 12-03-2008, 06:46 PM   #61
SOHC on this!!
Old 12-03-2008, 07:08 PM   #62
SOHC on this!!
Old 12-19-2008, 11:52 AM   #63
B ( . )( . )B's
Rep Power: 73 Ethan has a reputation beyond repute
Ethan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond reputeEthan has a reputation beyond repute
Send a message via AIM to Ethan Send a message via MSN to Ethan myspace
Originally Posted by Ethan View Post
Looking great man!! I wanna get another 89-91 hatch sooo bad.
Well its still looking great man. Plus i just picked up a 91 DX Hatch. Maybe youll be able to help me with a couple things.
Keep up the good work!
My 91 Civic HB Project
add me on ps3.... my account is "SOHCivic"
Ethan is offline   Reply With Quote
Old 12-19-2008, 08:22 PM   #64
SOHC on this!!
Nice! Got any plans for it yet?
I would be doing much more but since it -8 and snowing every two days its hard to work.
Old 12-21-2008, 07:09 PM   #65
B ( . )( . )B's
Im not sure yet. sometimes i just wanna restore it to MINT condition and keep it all stock and sometimes i wanna put a fuckin fearri engine in it. lol
decisions are so hard with new toys....
Here is how two of the plugs looked like after we pulled em tho..
Old 12-21-2008, 07:23 PM   #66
old sckool enthusiast
OGMatt's Avatar
Ride:  89' CRX Si
Rep Power: 47 OGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant future
hey brad when do we get are short shifters?
shaved sig
OGMatt is offline   Reply With Quote
Old 12-24-2008, 11:04 PM   #67
SOHC on this!!
30th it says on the tracking, I think on the 28 though, they're already in Washington.
Old 12-24-2008, 11:17 PM   #68
SOHC on this!!
Well here we are 1000 miles later and doing completly fine.
The used headgasket sealed, lol.
Whenever I have time I'll take the motor out of my dads car and figure out what to do.
Before the head swap my dads car burned oil. Now it doesn't, it must have been the valve seals.
I've been monitoring the oil and coolant and nothing is being lost. The compression is balanced and fairly high so whats the point of tearing apart the block.
I was going to tear apart the block and do rings and bearings but I think all I'll do now is main seals and an oil pan gasket. Get some degreaser and a tooth brush and make it look like new.
Then I think I'll get a Z6 headgasket, clean up the head aswell, and then a stage 2 cam.
Get a header and exhaust, get it tuned and call it a day.
All of this will be spread out over the next year because of my part-time job.
Old 12-28-2008, 11:43 AM   #69
B ( . )( . )B's
keep it up dude. Finally got mine 100% back together and it runs Faukin BEAUTIFUL!
Old 01-09-2009, 11:29 PM   #70
Hands Off my Balls
NWDRVRBWE's Avatar
Rep Power: 16 NWDRVRBWE is a glorious beacon of lightNWDRVRBWE is a glorious beacon of lightNWDRVRBWE is a glorious beacon of lightNWDRVRBWE is a glorious beacon of lightNWDRVRBWE is a glorious beacon of light
Send a message via AIM to NWDRVRBWE myspace
going to get a new manifold on it?
Rep's a B****, Why have any?
NWDRVR
NWDRVRBWE is offline   Reply With Quote
Old 01-09-2009, 11:44 PM   #71
SOHC on this!!
Intake manifold? No probably not, should I?
Old 01-09-2009, 11:45 PM   #72
SOHC on this!!
Good for you!
Old 01-10-2009, 09:02 AM   #73
Hands Off my Balls
NWDRVRBWE's Avatar
your intake allready looks legit and exhaust allways helps, especially on older models.
EDIT: but it really has to do with what ever you want. some manifolds are just designed with the slightest differences.
NWDRVR
Old 01-16-2009, 11:23 PM   #74
B ( . )( . )B's
Edit: Anything new goin on with your hatch 90civicboy?
Old 01-17-2009, 12:55 AM   #75
OGMatt's Avatar
Ride:  89' CRX Si
Anything new goin on with you baby 90civicboy?
I heard that his exaust fell off and needs a new one and then he will sell his old one to me, isn't that right brad.
shaved sig
High Compression Build vs. Low Compression Build? Trying to clear something up.. oneofakinduserid Engine Building 14 10-08-2009 04:02 PM
Official Accord Build Thread *hybrid* Time Attack Build boostedf22 Auto Multi-Media 14 06-04-2008 08:36 PM
H23 build badasscrx ECU's, Electronics, and Tuning 7 01-02-2008 02:13 PM
A few pic's of my build Blanco Auto Multi-Media 76 11-29-2007 11:23 AM
B!6A Build Up B16a_Beast Engine Building 1 09-05-2003 06:15 AM
