#51 |
Ride: 2007 Scion TC, 2005 Suzuki GSX-R 600
its a common sensor that goes bad on those.
The IAC valce is on the back of the intake mani if I'm correct and is black. I've had at least 3 go bad on me. To check it, unplug it while idling, and if the idle goes up, like immediately, then its good, but if it doesn't do anything, then its still bad. Or atleast that is my experience with them. __________________
When this is all over I think we should get an apartment together. |
#52 |
F.I. Junkie
Ride: 1996 Civic, 1992 Accord
Thanks for the tip, ill try that tomorrow. So im guessing if the idle goes way up then its good and might just need cleaning?
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6- |
#53 |
F.I. Junkie
So I unplugged it today with the car idling, nothing changed. Im wondering if my wiring got messed up somehow. The D-Series plug didn't match up with that one so I had to cut and splice the LS one on there, duno if that works or not tho.
-320 WHP EJ6- |
#54 |
Dismember
Have you scanned the code yet?
If you're sure that you swapped the SAME wires for the SAME sensor, there shouldn't be a problem. Take the IACV off and clean it. If that doesn't work, buy a new one. __________________
Go to work, Act normal, Believe the News, Save for your old age, Obey the Law Repeat after Me: I am Free |
#55 |
F.I. Junkie
Havent scanned the code, checking the wiring today to make sure its still connected and what not, and if thats bad then im getting a new one. Thanks for the help.
-320 WHP EJ6- |
#56 |
Dismember
I'd get that code before I replaced ANY parts. It'll save you time and money.
#58 |
F.I. Junkie
**UPDATE**
Got my first timed passes in on friday! Im fairly happy with the results, the local track hasnt been maintained very well, so the launch is very slick, but anyway here we go! These runs were on "Cooper ZEON ZPT" tires, 50 series at 38 psi. Slipping clutch FTMFL.. should have replaced it during the swap ![]() Best time: R/T - .6899 60 ft- 2.3548 1/8 ET - 9.7620 1/8 MPH - 73.76 1/4 ET - 15.1182 1/4 MPH - 92.95 ![]() Outlined the numbers so it is easier to read.. track printouts suck.. anyway, im fairly happy with the time, I definetely need more practice but its a good start. Boost soon! ![]() __________________
-320 WHP EJ6- |
#59 |
Ride: 96 hatch, 07 zzr 600
Are those Motegis 15s or 16s? Ive been thinkin about buyin that exact set for my hatch lol. Luckily the shop i work for is a motegi retailer
, i get rims dirt cheap. |
#61 |
F.I. Junkie
6/25 UPDATE:
New rotors/pads on the front. Rotors are Brembo (OEM Size) drilled & slotted. Pads are PBR semi metallic. ![]() Easy install. Stops alot better too ![]() Here's an updated pic, all dirty.. but not alot has changed. Painted centercaps, thats all I can think of. ![]() Turbo in the works. Hope to have it done by the end of summer!! __________________
-320 WHP EJ6- |
#62 |
Dismember
Drilled and slotted rotors will do nothing but chew your pads up faster. Which might not be such a bad thing, since it will give you an opportunity to change to Brembo blanks w/ Hawk pads
Good luck with the turbo project, keep us updated. __________________
#63 |
awesome. Never checked this thread out til now. Funny though... i was just pricing out a b18b swap w/gsr trans... along with some other things hehe.
Good stuff, keep us posted with the terrrbooouughhh __________________
My name is Sean.
#65 | |
F.I. Junkie
Was pretty cheap too, I think I spent around 2,500 for everything, including a new front bumper (no paint yet ), intake, exhaust, pulleys, and I replaced a few other misc. parts along the way.__________________
-320 WHP EJ6- |
#66 |
did you get your b18b locally? Im figuring around 3-3.3k when all is said and done. This will be held off til next summer since i just bought a bike, and all i really want is something that will get me around town a little better rather than having to rev over 3.5k to make any power. Maybe later throw a hmt kit or something like a peak boost kit..
b18b swap w/gsr hydro trans (maybe lsd..) and obd1 ecu w/harness (possible future turbooooo?) header intake mani itr oil pump, new belts, new fluids, new plugs, sensors if needed, etc homemade intake w/ k&n filter __________________
My name is Sean.
#67 |
F.I. Junkie
I got my motor from JDM-online.com
JDM B18B G1 '94-'95 INTEGRA [B18BG1C] : JDM-Online.com, JDM Engines & Accessories Told them I needed an OBD2 motor instead of OBD1, they were happy to send me one of those, along with my choice in tranny because they were out of LS tranny's. No extra cost on the transmission either. Shipped to my door, about 2k. Got the intake off ebay. Cost me 50 shipped I think. Pulleys I got from a friend who had a b16 del sol that was stolen. $40 Exhaust is full mandrel bent 3 inch, bent, fitted, and welded everything together at work. 3" pipe cost me $20. The muffler, resonator, and cat cost me 250 from the same guy that had that del sol. Mounts I got from a local scrapyard, someone ordered them and didnt pick them up so i got them fairly cheap i think it was 200 for all of them, drivers side, passenger side, t bracket, and a couple spare ones. I custom made my throttle bracket out of the old one, and the throttle cable i had lying around. So.. total was around $2,560 give or take some. Oh btw. The complete swaps from jdm online really are complete.. mine came with everything. Motor, trans, ecu, downpipe, exahust mani, all the lines and what not , even came with the upper and lower radiator hoses. Sweet deal. __________________
-320 WHP EJ6- |
#68 |
F.I. Junkie
Oh, and definetely get LSD.
and gas mileage is pretty good, mine still isnt running that great but it is around 30mpg city, even with me mashing on it every once in awhile. __________________
-320 WHP EJ6- |
#69 |
Im lookin at torontojdm.com they quoted me an awesome price for a b18c1 and said drop them a line for any future purchases. b18b swap there is 1850, hopefully i can get them to swap the trans with a gsr one with lsd for 2000-2100. But thats not for some time now, so we'll see. Ill probably change my mind in a few weeks lol
My name is Sean.
#70 |
F.I. Junkie
Haha. Yeah thats one thing about swapping motors. I changed my mind a million times before I finally settled on the LS for this car. I started out wanting an H22, but decided against that. Then it was the jdm b18c, then the b16a, then back to the h22, then I decided I wanted to boost so I got the LS. Funny how all that works, so many possibilities.
-320 WHP EJ6- |
#71 |
F.I. Junkie
Alright, just updating this with the parts I have so far.
Front end: 99-00 Replacement Fenders 99-00 Core Support 99-00 CTR Style Headlights 99-00 OEM Grille 99-00 Foglights (black housing w/clear lense) New bolts & plastic screws from Honda 99-00 OEM Civic Si Lip (on the way) Turbo: Garrett t3/t04 .50 hot .63 compressor Equal Length Manifold (made locally) Greddy RS BOV Spearco FMIC TiAL Sport Wastegate (on the way) Glowshift Gauges & Gauge bezel (around cluster) Hondata s300 with boost module, anti lag, launch control, etc. (on the way) OBD1 P28 ECU OBD2a>OBD1 Jumper Harness RC 750cc Injectors (on the way) Exhaust: New flexpipe 3" downpipe standard 5 bolt t3/t4 flange Vibrant Performance Streetpower Flat Black 3" Universal Muffler Paint: Respray in black w/ some sort of pearlescent Wheels: Picked up a set of drag track wheels with MT slicks locally All these parts are going on over winter, tuning in spring hopefully, unless I can get a trailer to get it to the dyno over winter. Let me know what you guys think. __________________
-320 WHP EJ6- |
#72 |
F.I. Junkie
Another update.
TiAL Sport 38mm wastegate is here. ![]() Wiseco Pistons 9.0 c/r Eagle Rods ARP Rod bolts ACL rod bearings ACL Main bearings ACL Thrust bearing all ordered, should be here soon. upping my power goal to 300 whp ish __________________
-320 WHP EJ6- |
#73 |
F.I. Junkie
Update:
Finally got around to buying another car to drive while I work on this beast. Its stripped, the B18B1 is about ready to come out. I'll be posting up pictures of the progress tomorrow. There's a good chance I could be working on rebuilding the block this weekend. __________________
-320 WHP EJ6- |
#74 |
The name's Sam
nice build man. makes me consider wanting to do a swap in my car...I do have an f22b1 laying in my garage everything but the axles....hmmmmmmm...maybe one day. either way good build I will for sure be watching the progress
Parts for sale: http://hondaswap.com/parts-sale-trad...-parts-115446/ Build Threads: Civic: http://hondaswap.com/civic-del-sol-eg-ek/d16y8-n-build-112401/5.html Trans Am: http://hondaswap.com/other-vehicle-discussions/1980-trans-am-build-thread-oh-yeah-its-official-149941/#post1054318 Last edited by philyphreak2127; 03-10-2008 at 01:53 AM. |
#75 |
F.I. Junkie
Alright, finally got out to the shop to take some pics of what I've done so far. Didn't get a chance to work on it today as I've been busy with my senior project for school.
Anyway here we go: JE 8.8:1 forged pistons ![]() ![]() Inside the shop that my dad and I built, its really bright and should be excellent for paint and body work. ![]() A look at the lighting. Pictures don't really do this justice. Its really bright in there. And yes, thats a heating duct above the center row of lights, its heated ![]() ![]() Toolboxes and rolling shelves. ![]() Heres where she sits. Awaiting some TLC. [img=http://img367.imageshack.us/img367/8742/1000108rx3.th.jpg] No radiator, or any body panels. ![]() Interior is all tore apart awaiting gauge install and new ECU. ![]() My temporary workbench ![]() Yes, everything is bagged and labeled. I hate losing nuts and bolts. ![]() Sensors and wiring harness labeled for installation ease. ![]() A look at the lean-to side of the shop. Mostly for storage right now. Thats my dads 1956 Ford F100 project on the left, and the Bayliner Capri in the back. Most of my parts are somewhere in the mix. ![]() ![]() Thats all for now! I'll post up more pictures every time I make major progress, or buy new stuff ![]() The shop is really making things easier. Thanks for looking. -Matts96HB __________________
-320 WHP EJ6- |
| Adult Project Attention Deficit Disorder.... | Airjockie | Members' Lounge | 7 | 12-04-2008 06:12 PM |
| Mac's 94 DB8 project thread AKA: Project Aeris.. ITR stuff, body work.. ect | mac_24_seven | Auto Multi-Media | 165 | 07-30-2007 01:42 PM |
| FS: 1991 PROJECT 240sx Hatch...learn to drift for cheap! Located in Maine | chrisfletcher | Vehicles: For Sale/Trade/Wanted | 0 | 01-11-2007 09:55 PM |
| PROJECT : Not Our Project | Smonkeyboy | Members' Lounge | 21 | 06-01-2004 05:02 AM |
| ls-vtec project in progress | brasilianstreet | Engine Building | 13 | 03-25-2004 01:09 PM |
