Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Got started on my Wire Tuck! 56k warning(I hope I know what I'm doing...)
Old 09-29-2006, 09:55 PM   #76
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
Well Calesta, unless you've already purchased some stuff online or something, maybe I could save your some trouble... Lowes carries everything you need, except for the box and mounting brackets(although you could probably make something with what they have there...).
I used 4 ga for the starter and 6 ga for the fusebox. After doing it I realized that 8 ga wouldof been maybe better for the fusebox, because I had to trim some wires to fit 1. into the ring connecter, and 2 into the fusebox itself.
The 4 ga wire is $0.25/ft.
The 6 ga wire is $0.19/ft - or something like that.
Bought some connectors for connnecting the 4 ga to the starter and ring terminals(if you don't already have some layin around somewhere), and it was about $5.00 with some heat-shrink tubing and stuff.
So all in all I'm sofar about $20 into it, but I still have yet to buy the box.
Like TurboMirage said, Advanced Auto's Marine battery box's work pretty well, and I know they carry mounting brackets, so I'll probably just buy one of those.
I've seen pretty good kits on Ebay for around $70-80, but then again... you can have that for 1/2 the price by doing it yourself(which I know you can!)
Anyway.. Just tryin to help a 'brotha out.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-30-2006, 01:18 PM   #77
im not a n0ob, trust me
Ride:  93
Rep Power: 11 d112crzy is on a distinguished road
are all boxes NHRA legal tho?
CB7Tuner Wiki
PGMFI.org Wiki
Want to know more about ecu tuning/chipping?
***I now provide ecu chipping services***
PM me for details and prices
d112crzy is offline   Reply With Quote
Old 09-30-2006, 01:46 PM   #78
Andrew's Avatar
Ride:  1991 CRX Si
I'm not sure.
I believe the requirement is it has to be sealed and secured at 6 points, but I'm not positive. thats just something I seem to remember hearing.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-30-2006, 02:08 PM   #79
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
No problem- I know what I need and where to get it- just have to do it.
No.
Old 10-01-2006, 12:38 AM   #80
Rep Power: 43 vtecsir1 will become famous soon enough
i thought that lengthing the wires was not good? i hear about strectching to achieve this look? im not a wiring guru but some componets have a certain resistances based on the original length? or am i a space cadet lol.
vtecsir1 is offline   Reply With Quote
Old 10-01-2006, 07:19 AM   #81
ScrapinSi's Avatar
Rep Power: 48 ScrapinSi will become famous soon enoughScrapinSi will become famous soon enough
FYI, you could have just run a 4ga from back to front, then used a power distribution block in the front of the car somewhere.
this country is turning into a bunch of fucking pussies... if this keeps up, pretty soon we'll be singing the french national anthem. -E_SolSi
ScrapinSi is offline   Reply With Quote
Old 10-01-2006, 08:29 AM   #82
Andrew's Avatar
Ride:  1991 CRX Si
Yeah, I know I could have split it, but I didn't feel like it. I would have taken a couple more dollars and I wanted to keep my cash. Thanks for the idea though.
And vtecsir1, Thanks for the comment, but I'm in college for Aviation Mech, and we've covered everything there is to know about AC and DC circuits. The fact is, yes you cause slightly more resistance by 1. lengthening the wires, and 2. at the solder points(even though soldering is one of the best ways to do it., however, it wouldn't affect such a simple, small circuit as headlight wiring, especially when you only lengthen them less than a foot....
And it's just common sense-
If it did... don't you think more guys who have wiretucks will have problems?
Thanks for the comment, but rest assured there isnt anything wrong with lengthening a couple wires.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-24-2006, 05:42 PM   #83
Andrew's Avatar
Ride:  1991 CRX Si
Painting the bay again... just doing it right this time.
Heres a 'before':
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-25-2006, 01:56 AM   #84
Ride:  93
nice. its gona look dope man.
CB7Tuner Wiki
PGMFI.org Wiki
Old 10-25-2006, 05:16 AM   #85
ScrapinSi's Avatar
Are those rags you are using to mask everythign off!?!?!
And FYI, NHRA States a battery box when located in the trunk must have:
A. Be secured by at least two 3/16" bolts through the floor of the car.
B. Have a battery cutoff switch on the outside
C. If it is a standard battery, must be located inside of an NHRA Approved Sealed Battery Box. (Not required for Optimas and such). And those battery boxes usually have a vent tube that runs outside the car.
Old 10-25-2006, 07:28 PM   #86
Andrew's Avatar
Ride:  1991 CRX Si
Yeah it's a mixture of rags, shopping bags, and tape. Thats how I roll...
Thanks for the battery information, but I'm not done installing it... it's just sitting there right now. I've just been slacking on it.. I've been focusing on the engine bay.
Thanks again though.
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-27-2006, 11:22 AM   #87
Calesta's Avatar
Ride:  2003 S2000
Nice mask job!
Old 10-27-2006, 12:59 PM   #88
Ride:  93
thanks for that info man!
I guess I'll have to buy an optima now theyre expensive as hell.
CB7Tuner Wiki
PGMFI.org Wiki
Old 10-27-2006, 03:32 PM   #89
Andrew's Avatar
Ride:  1991 CRX Si
Originally Posted by Calesta View Post
Nice mask job!
Thanks
I've still got to mask off the Xmember's, but then I'll spray it.
I picked up a couple cans of Acryllic Laquer today(white), and since I went with laquer I won't even bother with clearcoat.... since it's got a semi-clear finish anyway.
I'll be out of town this weekend, but plan on spraying the bay Monday morning.
Till then...
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-27-2006, 03:55 PM   #90
Calesta's Avatar
Ride:  2003 S2000
Cool. I want to change colors on my truck, but it's going to take a bit more work. I'm not planning on plucking the engine to do it.
Old 10-29-2006, 05:18 AM   #91
Your shit is looking betteR...
I did my tuck recently... turnd out pretty good i think.
Both sides
the following are only the passenger side
The fuse panel is mounted behind the evaporator and above the ECU.
I also relocated the batter to the trunk using a rockford fosgate amp wiring kit. I got the kit really cheap, my buddy worked at best buy at the time... so we got the 79 kit for 25... i was happy. I used an Odyssey 545 battery, I think its a little small as i have some problems with it sometimes..
Sorry andrew, didnt mean to thread jack.
90 Integra Sedan
B20V 225 / 153
Old 10-29-2006, 12:27 PM   #92
learning in progress
formby's Avatar
Rep Power: 93 formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
andrew i have a moroso nhra blue box...pm me if you are interested
http://pandora.com/
Old 10-29-2006, 06:11 PM   #93
I wear stretchy pants
Taco15's Avatar
Ride:  chevy s-10
Rep Power: 217 Taco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
Taco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
myspace
seen it in person. i can vouch that its in good cndition.
Its fashion man. The chicks you see walking down the runway dont wear practical clothes, they were something that was designed to make a statement. THat statement in turns influences and shapes other peoples designs and ideas.
Same thing with cars. Except with no attractive women... and a lot more gayness.
Taco15 is offline   Reply With Quote
Old 10-29-2006, 08:00 PM   #94
Andrew's Avatar
Ride:  1991 CRX Si
PM me a price Mr. Formby. Thx.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-29-2006, 08:18 PM   #95
formby's Avatar
ok
http://pandora.com/
Old 10-29-2006, 09:58 PM   #96
Taco15's Avatar
Ride:  chevy s-10
myspace
1 million dollarrrrssss
Old 10-30-2006, 11:27 AM   #97
Andrew's Avatar
Ride:  1991 CRX Si
Lookin good brian!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-02-2006, 03:18 PM   #98
I'll be back...
B16RacerN2NR's Avatar
Ride:  06 Mazda 5, 91 Civic DX
Rep Power: 156 B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
Looks good Andrew.
When I did the Battery Relocation in my 89 4 door, I just put the fuse panel wire to the starter and ran 2g wire from the starter to the trunk. I used one of the Marine box's they have at autozone. The box cam with 2 brackets that bolt to the car and you run a strap (comes with the bax also) through the brackets and up over the box. Worked great, strapped down nice and tight, no play in it at all.
Anyway, down side to that was the first time I went to the track (1/4 mile) and the guys saw it, he said the way the box was tied down (with the strap) it wasn't in spec's for me to race because it needs to be bolted down with at least 3/4 inch bolts and on any car that you relocate the battery in needs to have an outside switch that cuts ALL power when switched off. He also told me that if you relocate the battery and are using a gel type battery, i.e. an Optima, you don't need to have it in a box.
Real Eyes Realize Real Lies
B16RacerN2NR is offline   Reply With Quote
Old 11-02-2006, 10:11 PM   #99
Andrew's Avatar
Ride:  1991 CRX Si
Well thats good to know. I'll be sure to secure it with some heavy-duty bolts(like I would anyway). Thanks for the info.
Update 11/2:
Painted the engine bay with white Acrylic Laquer, so it's got a nice, semi-glossy finish. It turned out great!
And I also painted my valve cover with the same stuff:
(primered it, wet sand, then paint.)
It looks a little better in person. Maybe when it's on the motor, in the car will you be able to tell it looks so good.
Oh, and I have yet to grind off the lettering. I'll post up another pic once i do.
And I talked to KMS. They're hoping to have the motor done and ready to ship back to me late this coming week. I'm starting to get kindof irritated, but, I'll just be glad when it gets here so I can roll my rex out and roll the El Camino in and work on it's swap..
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 11-02-2006, 10:18 PM   #100
formby's Avatar
"heavy duty bolts" come in different sizes... thought you knew
http://pandora.com/
How to wire vtec 92b16vx General Tech Articles 3 06-17-2005 06:13 PM
How to wire the horn for a Non-SRS steering wheel civicious General Tech and Maintenance 0 05-12-2005 07:32 PM
questions rushcrx HYBRID -> ED-EF / DA 6 06-29-2004 11:54 PM
good sites for stereo installs WetWilly Car Audio / Security / Electronic Accessories 4 08-26-2003 12:28 PM
How To Make Physical Wire Connections dkasakitis ECU's, Electronics, and Tuning 3 01-27-2003 02:01 AM
