Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Mac's 94 DB8 project thread AKA: Project Aeris.. ITR stuff, body work.. ect
Closed Thread
Old 05-03-2007, 04:47 PM   #151
Dismember
Ride:  Whatever i can get behind the wheel of
Rep Power: 263 klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
O, you didnt show the drain line in your sketch. It will be fine that way.
Go to work, Act normal, Believe the News, Save for your old age, Obey the Law
Repeat after Me: I am Free
klyph is offline
Old 05-03-2007, 06:39 PM   #152
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
The valve cover should go to a vented can. All by itself, 1 or two lines(depending on how many VC vents you have).
The crank case has 1 line factory(black box), and 1 line they added the Prelude nipple to. (the "Passenger Side Crankcase Adapter" in your pic) going to a non-vented can.
Thats pretty much all I know about it. I don't know'havent heard anything about a tube going down into it, but w/e. it all works.
Theres so many ways to connect it, it probably doesnt even matter. I'm just going by what I've seen in Endyne's engine dyno pics.
Original page
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Andrew is offline
Old 05-03-2007, 07:16 PM   #153
Hon-daaaa
hazzardboy95's Avatar
Ride:  95 TEGGY
Rep Power: 13 hazzardboy95 is on a distinguished road
That i/m is huge, and carbon fiber. WOW.
When my parents asked me what i wanted to be when i grew up you know what I said
The garage....
2005 bmw x5
2007 ford roush mustang
1987 jeep wrangler
1993 honda civic hatch
1998 isuzu amigo
1995 ACURA INTEGRA
(\_ /)
( 0.o)
( > <)World domination will be ours....
hazzardboy95 is offline
Old 05-09-2007, 08:07 AM   #154
I trained Trogdor to pWn
mac_24_seven's Avatar
Ride:  94 GSR Sedan
Rep Power: 16 mac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura aboutmac_24_seven has a spectacular aura about
My catch can is 99% complete. I need to drill one more fitting in the bottom for a drain and I'm good to go =)
In the meantime, I bought some gasket maker and sealed the hose barbs so they won't leak. Here are a couple of pictarZ.
Enj0y!
mac_24_seven is offline
Old 05-09-2007, 10:16 AM   #155
Andrew's Avatar
Ride:  1991 CRX Si
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Andrew is offline
Old 06-07-2007, 07:33 AM   #156
Ride:  94 GSR Sedan
DIY: Custom Catch Can install
Tools needed:
Your custom catch can
An assortment of hose barbs
several feet of hose
pliers
3/8 Brass hose barb, male on both end.
***Note: You don't have to go in this order.. It's just how I did it.
Step 1: Open da hood
Step 2: Remove your strut bar/Intake piping. Pretty simple.
Step 3: Remove the PCV valve so you can remove the hose connecting it to the IM. Took me a good 20 mins to get it. Hardest part of the whole damn thing. It's the lil brown things near the bottom that is sticking up and has the hose connected to it.
Step 4: Connect the hose running from the IM to the hose thats going to be running to the catch can, via the brass hose barb. Leave the hose long so you can cut it to the correct length later on. Also, add hose from the PCV valve so it will run to the catch can.
Step 5: Move out from the hood and get your can.
Step 6: Stuff the can with your filter material... In this case, panty hose :P I think Eli's imagining him wearing them. So you know, they are NEW.
Step 7: Make sure they are breatheable......... No comment...
Step 8: Install the can where you want it and cut the hose to length. Using the clear hose, as I did, I found out some scissors are the best way to cut it.
Step 9: Install the can and hook up your hoses! This is the simplest catch can design.. Simply a hose running from the PCV to the can, then one running OUT of the can into the IM.
Danger!!!! Where I was going to originally mount my can, I neded to remove some hoses from the charcoal canister.. Unfortunately, the nipples on it break pretty easily =(
I simply put a screw in the hose and the broken nipple and smeared some gasket maker around it. Good as new =)
And there you have it. My installed catch can. Notice I ditched my previous can, since this one was much more compact and will function the same.
1994 Acura Integra GS-R Sedan
My MAIN DB8 project thread on Honda-Tech: Very detailed of EVERYTHING I've done to my car.
Contact me for ITR header skid plates: $40.00 shipped!!!
Old 06-07-2007, 07:35 AM   #157
Ride:  94 GSR Sedan
DIY: City lights
Tools needed:
File
(2) 194 sockets and bulbs
Extra wire
Connectors/black tape
** Note** I used these in replacement of my high beams. I had a bulb out and was too cheap to buy another high beam bulb, so instead of drilling a hole I just replaced the highbeams with the 194 socket/bulb.
Step 1: Pop your hood and ready yourself to being one step closer to ultimate JDM :P
Step 2: Remove your high beam bulb and get your socket/file and file it down. The socket has lil ears on it so when you turn it, it locks into place. Obviously the high beams are different, so you can't do that. BUT, you CAN file the ears down so when you stick the socket in the housing, it fits snug. After you've done this, get ready for some wiring.
Step 3: Remove your turn signals/bulb sockets. It's just one screw really easy.
Step 4: Extend the wires/wire the plug into the turn signals. Extend the wire from the new 194 sockets. Then wire the POSITIVE wire coming from the 194 socket to the GREEN/BLACK wire coming from the194 turn signal. Obviously, wire the negative to the black wire (ground). I used the lil thingy's (don't know the name) to put all 3 wires in, then crimp them together.
***Warning*** Don't do what I did. See anything wrong with the below picture?
When I extended the wire, I was using terminals. I used 2 female terminals instead of a male/female :P What a n00b.
Step 5: Test to see if everything is wires correctly (turn on ligths/turn signals) run your new socket to the headlight housing and stick it in there. Re-install the sockets into your turn signals and enjoy your new city lights.
A pic of how thw wiring should end up.
Finished product.
Old 06-07-2007, 07:38 AM   #158
Ride:  94 GSR Sedan
And I havn't updated in a while.. so here's what happening.
I"ve bought a new house and have moved in (still unpacking). And my GT3s will be here Saturday (unless fedez tracking is lieing to me)
I bought a skunk 2 front camber and a rear camber kit, which will be going on this weekend.
A new DIY for them will be coming.
Check the link in my sig to the mainproject thread on Honda-Tech.
Old 06-11-2007, 08:43 AM   #159
Ride:  94 GSR Sedan
Finally... It's time!!!
Yess...
Yessssss... Yesss.....
OHhh yeahhhhhhhh!!!!!!!!
Look at those white legs!!
I'm a smartE white boy.. I learned from my 6 hour wheel swapping fiasco: Always check the tires to make sure which direction they rotate!!!
A lil tip to keep from scratching your wheels.. Wrap tape around the socket.
All done!!
Now for the pics... I tried to be artsy in some of em.. But I suck =(
I'll take a couple for comparison at lunch today in my normal lil spot =)
You like?
Old 06-11-2007, 09:32 AM   #160
Andrew's Avatar
Ride:  1991 CRX Si
Looks dope mang
xInfinity
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Andrew is offline
Old 06-11-2007, 04:13 PM   #161
Ride:  94 GSR Sedan
You've gotta come down this weekend so we can roll around and make fun of rednecks. Maybe even smoke a couple domestic lovin' inbreds
Old 06-15-2007, 02:24 PM   #162
I provide inspiration!
89crxzc's Avatar
Ride:  crx si w/zc swap, 96 slammed accord, 06 toaster
Rep Power: 28 89crxzc is a name known to all89crxzc is a name known to all89crxzc is a name known to all89crxzc is a name known to all89crxzc is a name known to all
Send a message via Yahoo to 89crxzc myspace
dr-16's ftw, nice build. love slammed 4 door tegs
http://hondaswap.com/civic-crx-ef/crx-build-89168/
MY BUILD ^^^^^^^ updated 11/09/2007 new pics!
89% finished...........maybe.
89crxzc is offline
Old 06-20-2007, 04:47 PM   #163
Ride:  94 GSR Sedan
Note: If there are any changes that need to be made to this DIY, please let me know. Also, if there is any extra information that need to be added, I'll add it.
DIY: Manual oil pressure gauge install
Tools needed:
Any manual oil pressure gauge
Crescent wrench
3/8 wrench
1/8 BSP TO 1/8 NPT fitting
Teflon tape
22 mm deep well socket for the plug in the block.
Note: I deleted the factory oil pressure fitting in this for lack of fittings. This means the oil pressure light will not work.
Also, I did this during my IM swap. I can't imagine how hard it would be without the IM off. This thread is written assuming the IM is indeed off.
Step 1: Pop your hood and get ready
Step 2: Teflon tape the threads and assemble the oil line into the fitting. Here's what you want to end up with:
Note: The assembly pictures are obviously of me hooking the line into the gauge, but the procedure is the same for the fitting into the block. I also didn't use teflon tape on this because I forgot :P I'ma n00b.
Here's what your working with:
Assemble like so:
And then screw em together nice and snug! Note: PUsh the oil line as far as it will go into the gauge and hold pressure on it while you tighten the nut down.
Step 3: Remove the oil fitting from the block/screw the BSP fitting into the block. This was a pain in the A$$, big time.. But you can do it =) Have faith Be sure to snug it up nicely. Leaks are t3h bad.. Mhhhhnnnnmmmmm kaaayyy?
Here is the plug you want to remove. It's black with the lil white nipple on it:
And here it is with the oil line installed.
Step 4: Run your oil line through the firewall into the cabin to wherever your going to mount it. There should be plenty of line to snake it around things to hide it. Reference Step 2 for the procedure on hooking the gauge to the line
Step 5: Double check to make evrything is nice and snug and fire her up! Check for leaks, please.... In case you don't know, oil leaks are bad for your engine :S
I have 70-80 lbs lbs of pressure on start up and cruise over 40 lbs once she's warm =)
And there you have it. You have your very own oil pressure gauge. ANd, so you know, my dads been building cars since he was a teenage and has never had a line break on him.. Nor have I known one to break nor have I ever had one break. If you don't pinch the line, you'll be fine.
Old 07-30-2007, 12:24 PM   #164
Eager Student
Rep Power: 8 SunShine00 will become famous soon enough
Tight build , props for that, but have you had it on the dyno yet, or have you run the 1/4 mile with it ?
SunShine00 is offline
Old 07-30-2007, 01:15 PM   #165
Ride:  94 GSR Sedan
Well, at the moment it's torn down... ITR cams and tuning will be happening this weekend.
Prior to the blox IM and cams.. I made 146/114 and ran a traction limited 15.5 @ 91.6 mph.
The above #'s are with a blown headgasket.
I'm shooting for 170's/mid to high 120's and w/drag radials... 14.5-14.8. I think w/radials I could have knocked on 14's with the HG blown... But we'll see.
If money goes ok, I'll have it dynoe'd by the first of next week and get her to the track sometime next month
My thread on Honda-Tech is the one I update.. Check it out for details and whatnot.
Old 07-30-2007, 01:42 PM   #166
Eager Student
sounds good, look forward to hearing about it
Closed Thread
WTS: 1999 Honda Civic EX (Project) / Rims / Body Kit / Paint Bri Parts: For Sale/Trade/Wanted 4 02-19-2007 07:39 AM
An offer. Airjockie Vehicles: For Sale/Trade/Wanted 3 07-18-2006 10:05 PM
Something To Think On lsvtec Members' Lounge 9 03-19-2003 01:38 AM
Auto Body Work JrSiRb16A Members' Lounge 6 02-16-2003 05:35 PM
