#51 |
Got Rice?
Ride: 89' CRX HF and 90' Civic Si
Mad wiring skillz yo!
PROPS Keep up the great work __________________
www.supremacyracing.com |
#52 | |
Im not sure where I ran across it, but I remember reading a thread about a guy who took his stock engine harness and changed the size of the wires (stock 22 gauge to a 18gauge wire) and it netted more power on the dyno... I thought that was pretty cool and worth doing... __________________
90 Integra Sedan B20V 225 / 153 I DO NOT answer tech questions via PM. Use the forums!!! |
#54 | |
universal logic protocol
Ride: 99 VW GTI 07 Jeep Compass
I found one place online a while ago that sold them for like $80. I'm sorry but they start asking questions when we order things like that. I just happened to come across one that was getting thrown out from a peice of equipment that was getting reworked.
99 VW GTI <= BIG F'IN POS <= Finally got it fixed, it's running good now 07 Jeep Compass If you ever find anything I write usefull please leave rep. Rebuilding a Transmission http://www.the-whiterabbit.com |
#55 | |
Not too much to update I'm still waiting until I have the money for major parts. Until then I'm trying to finish the wiring. All that's left is the Fuse Boxes. and the lights I think. I spent like 2 hours lastnight going over my schematics and figuring out how many fuses I needed and when they were supposed to be active and which pins I could get with which fuses. I finally came up with these diagrams. Since I'm doing a custom wiring harness I need a custom Fuse Box.
![]() ![]() __________________
#56 | |
A little vid of how the wiring is going. I finally got a little bit of functionality out of it. It's good to see your hard work finally paying off. I've had to do a lot of researching to wire the ECU. Like mentioned before almost all of the wires were burnt up so I couldn't tell what was what. On top of that the repair manuals I've looked at have schematics but no pin references for the ECU just wire colors. I was fortunate enough to find pinouts for my ECU. Anyways enjoy!
![]() BTW the codes the ECU is giving are 6 (Coolant temp sensor) and 10 (IAT). __________________
#57 | |
Just thought I would give a little update since I haven't updated in a while. The wiring is slow but it's comming along. Mainly because I'm lazy and I get preoccupied by the TV. Anyways wiring is about 90% done. I just have the wipers tail lights rear turn signals emergency brake seatbelts and doors.
![]() ![]() BTW that is the third spool of wire I've gotten. At 500 feet a roll that's a lot of wire. __________________
#58 |
Ride: 1994 Civic Ex Coupe D16z6 5SPD Maunal, '95 Civic Sedan 4dr EX D16z6, Auto
Your wiring is insanely awesome. I love what your doing with this. Your looms are so awesome. and with atleast 1000feet of wiring done already, I am sure you are pumped for your wiring project coming to an end. Cant wait to see this all done
#60 | |
Thanks, I just finished wrapping the Main Harness. Take a look. I still have the Rear Harness to make. It's the wires for Emergency Brake, Seatbelts, Door and Hatch Switch, Fuel Pump, Fuel Sending Unit, Brake Lights, Rear Wiper and Turn Signals. Everything else is done.
Zipped up ![]() After tape ![]() I figured I would put together all the parts I have done. ![]() __________________
#61 |
Brutal Moderator
Ride: 97 Integra LS Coupe
Beautiful work man! That's awesome! Looks professional!
#62 |
Honda Master Technician
Ride: 88 Prelude Si and a CBR 600 Hurricane
Wow that is really coming along great.. I wasn't aware you were basically making an entire body harness before. That is a seriously big job to take on and it looks awesome.
Do not PM with tech questions without providing a link to your topic on the forums. This way everyone has access to the information.. |
#63 | |
I was slowly working on the rear harness this weekend. I found that there were some wires back there that were melted together also. That kinda concerned me a little. I need some input from you guys. I was thinking since I'm using a custom engine harness and it's going to get a wire tuck, should I cover up the holes in the engine bay with like sheet metal then bondo over them and paint them? Or is there something else that would look better or work better?
#65 | |
Here is an update. I've been working kinda slow on this lately. Today I started putting the wiring in the car.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() As you can see I put in the rear harness the dome light and did the wire tuck for the front harness. __________________
#66 | |
A little update. I had to stop because some of the plugs on the main harness were too short so I had to lengthen the wires. That's done but it has been raining here so I haven't had a chance to go out and work on the car. Today is looking promising though.
#67 | |
I decided to do some work on the trans. It's a transmission in a box!
#68 | |
So I thought I'd give an update since I haven't really worked too much on the car what with getting ready for the baby and all. I did however, order new 11:1 Pistons, new Rings, new bearings, a used 14b turbo off of a DSM, I got an Intercooler from the scrap yard and some 390cc injectors from the scrap yards. Hopefully they work. I still have a few other things to get but it's slowly comming along.
#69 |
The Pussi Snatcher
Ride: 90 Ls/Vtec Turbo Da
loving the VC paint job looks fresh man I also like the fact you do your own work..nice bullet connectors as well....
IM LOOKING TO GET A MSD 6AL box for local pickup only Looking FOR LS MESH wheels Pm Me If U GOT THEM IM LOCATED IN ORLANDO..PM ME IF U GOT IT Owning a type-r is just like every other honda that is modded in Orlando,FL you wake up and its Gone....Whammm If you find anything I say helpful, please leave me some rep... |
#70 |
dame that alot of wiring brow. i cant even take of my dame trimsion
Tu Madre |
#71 | ||
What? __________________
#72 | |
So I got my parts in today and started cleaning the block. I had the machine shop at my work do the block work.
Here the block sits in a tub of pure simple green to get all the grease and dirt off of it. After the block is done soaking in goes the head and finally the tranny case. I was wondering if I should paint them and if so what color. ![]() New pistons 11.1:1 compression ![]() New piston rings. ![]() New rod bearings. ![]() New crank bearings and thrust washers. ![]() The turbo I need to clean up. I'll probably end up taking it apart and bringing it in to work to sandblast it and paint it. __________________
#73 | |
Thought I would post an update. Since the baby got here I haven't had much time to work on the car. My being lazy doesn't help either. I started rebuilding the engine the other day and this is what has been done so far:
![]() ![]() ![]() ![]() ![]() ![]() ![]() __________________
#75 | |
I got the transmission put back together today and in the process made a write-up.
Rebuilding a Transmission __________________
| 99-00 civic Si cluster swap into EF How To (pics0) | B18C5James | HYBRID -> ED-EF / DA | 30 | 07-11-2007 06:25 PM |
| 88+ ECU Error Codes | pissedoffsol | Reference Materials | 1 | 05-19-2005 01:03 PM |
| 94 CIVIC COUPE 4 SALE!!! B18 SWAP IN NJ!!! | randxvtec | Vehicles: For Sale/Trade/Wanted | 0 | 02-15-2005 01:26 AM |
| 6th gen Civic Basic swap overview | pissedoffsol | Swap Articles | 0 | 01-12-2004 02:14 AM |
| Chassis Code | VSMB16A2 | General Tech and Maintenance | 10 | 01-22-2003 05:32 PM |
