Go Back   HondaSwap Forums > Members' Corner > Auto Multi-Media
Wikedeye's EJ b16 build thread
Old 08-11-2008, 08:35 AM   #76
Conan The Hondarian
wikedeye's Avatar
Ride:  1993 Honda Civic Dx Coupe
Rep Power: 28 wikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to beholdwikedeye is a splendid one to behold
Send a message via AIM to wikedeye
Originally Posted by brian11to1 View Post
You shouldve painted the hats on the rotors cuz theyre gonna rust.
Thats ok they werent very expensive, so I can just get new ones if they get too bad.
Originally Posted by b16vt3c View Post
ii JUS SOLD MY 94 EG CIVIC HATCHBACK W/ JDM B16A
ii LUV THE CIVIC HATCHBACK BUT ii HAD 2 SELL iiT
BCUS HAD 2 MANY CARS &+_ THE CAR WAS
FAST &+_ NICE BUT iiT HAD 2 GO
94 EG CIVIC HATCHBACK W/JDM B16A
04 S2000 W/TURBO SOLD
Sorry to hear that, they both sound nice. I would be a little sad too.
Originally Posted by 99sidude View Post
yes silicone lubricant worked great on my shaft. highly recommend.
XBL: Wikedeye
wikedeye is offline   Reply With Quote
Old 08-11-2008, 09:19 AM   #77
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
hahaha
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-11-2008, 12:47 PM   #78
Conan The Hondarian
wikedeye's Avatar
I only paid $80 for both rotors, and they wont rust any more then a regular set would. I will just use them until they are bad and then get some blanks.
XBL: Wikedeye
Old 08-11-2008, 02:11 PM   #79
Andrew's Avatar
Ride:  1991 CRX Si
My bad! I posted that first thing this morning.
I read it as, "they were very expensive...." thats why I laughed... D'oh! hahaha
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 08-11-2008, 07:48 PM   #80
Conan The Hondarian
wikedeye's Avatar
Oh ok...I was wondering why it was funny. lol
XBL: Wikedeye
Old 08-22-2008, 10:56 AM   #81
Conan The Hondarian
wikedeye's Avatar
I have been doing some research on turbo lately, and I am starting to think that sticking with the stock b16 cams is a better idea then the ctr cams for a turbo setup. Does anyone have any opinions on this? I know there is more overlap in the ctr cams which would mean more tuning to compensate. Would the extra lift be beneficial at that point or would I be spending more money on tuning then its actually worth?
XBL: Wikedeye
Old 08-22-2008, 01:16 PM   #82
GSR cams are a better choice especially for turbo.
90 Integra Sedan
B20V 225 / 153
Old 08-22-2008, 01:20 PM   #83
Conan The Hondarian
wikedeye's Avatar
Well I have the b16 cams already so if I dont have to spend money there then I dont want to. The gsr's I would still have to buy them.
XBL: Wikedeye
Old 08-22-2008, 10:51 PM   #84
99sidude's Avatar
Ride:  gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
Rep Power: 50 99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of
Send a message via AIM to 99sidude
you're fine with the b16 cams. With the gsr's you may see a couple more whp.
Originally Posted by Celerity View Post
The worst thing that car ever had installed was your lying two-bit fat ass in the left seat.
My Build: http://hondaswap.com/auto-multi-medi...sc-buld-94841/
93' dx hatch
jdm b18c - jrsc 8psi
s300 440cc RC's
99sidude is offline   Reply With Quote
Old 08-23-2008, 05:22 PM   #85
Conan The Hondarian
wikedeye's Avatar
Yea I think maybe the cost outways the benefit. I am just going to change my plans and put that money towards pistons and rods. Honda pistons have to be machined before you can connect them to aftermarket rods correct?
XBL: Wikedeye
Old 08-23-2008, 05:54 PM   #86
You aren't planning on using stock cast pistons in a boosted engine are you?
90 Integra Sedan
B20V 225 / 153
Old 08-24-2008, 05:14 PM   #87
Conan The Hondarian
wikedeye's Avatar
I was until I read some things about how easily they can melt. I bought "how to tune and modify engine management systems" by jeff hartman, and it goes into detail about boost temperatures and why cast pistons are not a great idea. So no I am going to be purchasing a new set of rods and pistons.
XBL: Wikedeye
Old 08-25-2008, 08:38 AM   #88
I would suggest atleast doing a piston/rod engine. Sleeves are great but you can run moderate boost on stock sleeves and be fine. I'd venture to say stock sleeves are safe into the 500 range, with GREAT tuning. If it were me, I'd sleeve if I wanted more than 400. Cuz if you want 400, then you want 500 and so it goes.
90 Integra Sedan
B20V 225 / 153
Old 08-25-2008, 09:35 AM   #89
Conan The Hondarian
wikedeye's Avatar
Well my goal is only about 250 so I think I will pass on the sleeves. I might add a block guard just to be safe, I dont want my cylinders to shift.
XBL: Wikedeye
Old 08-25-2008, 09:41 AM   #90
Conan The Hondarian
wikedeye's Avatar
Is a b16 tranny much better then a GSR tranny. I have this other thread going on another site and these two guys have been arguing for like two pages about what tranny is better. I know the b16 has shorter gear ratios, but would it actually be better in my setup? I trust peoples opinions here and would like to know what yours are.
XBL: Wikedeye
Old 08-25-2008, 02:12 PM   #91
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
Rep Power: 221 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
Its all a matter of opinion as to which one is better. The B16 has the shortest gears, an LS trans has the longest, and the GS-R is right in the middle of the two. It all depends on how you want the car to drive.
^ (dont listen)
There is a hidden message here.
"Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details."
"In the dice game of life who gets the last roll?"
Old 08-25-2008, 02:27 PM   #92
Conan The Hondarian
wikedeye's Avatar
You know I need to thing more about that, I dont really know what I am looking for in that area. I guess since I have the gsr tranny and it is in the middle it will be a good reference once I get the engine built. If I dont like it I can always change it.
XBL: Wikedeye
Old 08-25-2008, 02:35 PM   #93
My name is Byron.
efhondakid's Avatar
Yep, a lotg of people seem to like them because they get the best of both the B16 and the LS, the GSR also has the strongest diff.
^ (dont listen)
Old 08-25-2008, 02:38 PM   #94
Conan The Hondarian
wikedeye's Avatar
Well I guess there is no reason to worry about it now. If I plan to get more serious like start racing it then I can look at changing, but for now I should be happy.
Oh yea I got my crank pulley holder in today...still cant break the bolt so I guess I am just going to have to buy an impact wrench. I am sure it will come in handy for other things.
XBL: Wikedeye
Old 09-03-2008, 05:42 PM   #95
Conan The Hondarian
wikedeye's Avatar
I took off the head today. Everything looks good. There is a shit ton of carbon deposits on the pistons and valves, but I guess that is what happens when you run an engine too rich. I still cant get the crank pulley off, I havent been able to buy an impact wrench yet, hopefully that will work. It looks like the internals are still stock (I was hoping for a few more nice surprises). When my girl gets home with the camera I will get a few pics.
XBL: Wikedeye
Old 09-05-2008, 10:38 AM   #96
Conan The Hondarian
wikedeye's Avatar
I have been looking at sway bar set ups for my car, and I was wondering if anyone knows whether I really need a rear bar. I have a front bar, i just need control arms that will accept it.
XBL: Wikedeye
Old 09-05-2008, 11:15 AM   #97
Andrew's Avatar
Ride:  1991 CRX Si
You'd might as well. Since the eBay kits come with the rear ones anyway...
$100 and you'll definitely feel a difference.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-05-2008, 01:05 PM   #98
Conan The Hondarian
wikedeye's Avatar
I have a front one from the ek thats in my garage so I would only need a rear bar, and a subframe brace.
XBL: Wikedeye
Old 09-27-2008, 12:33 AM   #99
Conan The Hondarian
wikedeye's Avatar
Well I know it has been a while and I dont have anything to update as far as my car, but my girl friends mom just bought her son a fodo 93 that I now have to fix and get safe for daily driving. It has some body damage but for the most part it is in really good shape (engine). The brakes are shot, it needs a new ac condenser, and the timing belt is past due for a changing although it runs really well for having 200k on it. Anyway I like to learn so this will give me something to work on (and make some money).
XBL: Wikedeye
Old 10-16-2008, 10:08 PM   #100
Conan The Hondarian
wikedeye's Avatar
Just a little update bump...I have been broke as shit because I just changed jobs and my new job sux so bad that I am kicking myself really hard. I just turned thirty on the 11th, and I am a little depressed about it. Also since I swapped the rear drums for discs I have had nothing but problems. I scrape the rear fender well anytime I hit a big bump, there is a REALLY annoying squeak somewhere on the rear pass. side suspension (maybe I didnt use enough grease), and my front calipers are sticking. I need to replace the calipers I guess. I had enough money to make some serious progress on my engine, but like I said my new job sux so bad that I have pretty much been living on my savings. The good news is that I am getting a job at a local tv station (which is what I have a degree in) so now that I am 30 I am going to get my career started. I have not smoked any cheeba in 9 days which is a record for me and I think I have kicked the habit. The fodo is coming along nicely. I made my first attempt at body work the other day and it went ok. I reshaped the front fender which was smashed up pretty good, and I fixed the brakes. Its funny my brakes suck, but my gf"s brother can stop on a dime. I am getting rid of the ek shell which means I can have some room in garage. Any way I will be more active in the weeks to come. I have made a few changes in the direction that I am going with the b16, but I will talk more about that later. For now I need to make some money because my baby is feeling a bit neglected.
XBL: Wikedeye
Tags
1993, b16, b16a, coupe, engine build
SE-R Build Thread... EGProject Other Vehicle Discussions 19 09-11-2008 06:23 PM
Official Accord Build Thread *hybrid* Time Attack Build boostedf22 Auto Multi-Media 14 06-04-2008 08:36 PM
Sil-80 Build Thread get_nick Auto Multi-Media 20 05-25-2008 02:11 PM
My 93 Del Sol build thread Eros2180 Civic and del Sol - EG and EK 4 11-17-2007 11:33 PM
crx build thread lil_red_rex Auto Multi-Media 26 09-20-2006 08:52 PM
