Go Back   HondaSwap Forums > Appearance and Accessories > Body / Exterior / Interior / Cosmetics
88-91' Civic Hatchback EF Wire Tuck Suggestions Needed
Old 07-06-2009, 02:10 AM   #1
d16a6/d16y8 "mini-me"
89' Project Civic's Avatar
Ride:  1990 Honda Civic Si
Rep Power: 22 89' Project Civic is a glorious beacon of light89' Project Civic is a glorious beacon of light89' Project Civic is a glorious beacon of light89' Project Civic is a glorious beacon of light
Send a message via MSN to 89' Project Civic
Default 88-91' Civic Hatchback EF Wire Tuck Suggestions Needed
Ok guys, so I have started a wire tuck on my EF and it is definately a work in progress. So far I have tucked the; headlights, horn, washer fluid resevoir tank connector, markers, indicators, wiper motor, engine bay fuse box (now on the inside of the cabin), and obviously the multi-ground behind the fender with a nice, clean connection; with di-electric grease. I am now done both sides. I have; soldered, heat-shrunk, and electrical taped all connections. I am now wondering what I should do with the engine harness connectors, do you guys have any bright ideas to help me out? I was also thinking of tucking my engine ground on the valve cover by drilling and tapping a hole in the valve cover and connecting the ground wire to the rear of the engine compartment chassis, is this an ok idea as long as I use silicone to secure the hole? If it matters I have the world famous D16a6/D16y8 "mini-me" combo (lmao, just kidding on the world famous part). Any help is GREATLY appreciated, thanks!
If any pictures are wanted or needed, please let me know. I have decided against a wire tuck write-up because I felt it was more than covered and the other people could probably do a better job explaining it. As well, I did not really follow a tuck write-up, rather I decided to look at a few pictures and start pulling out the solder iron, solder, heat shrink and electrical tape; it seemed pretty straight forward.
Last edited by 89' Project Civic; 07-06-2009 at 02:14 AM. Reason: grammatical error
89' Project Civic is offline   Reply With Quote
Old 07-06-2009, 02:20 PM   #2
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
there should be a threaded hole on the back of the valvecover to run a ground from..if not try taking the ground off and starting the car(i ran my d16z6 with no ground on the vc)
also as for engine bay tucking..just put the fuse box in the cabin and extend the wires for the starter and wiper motor..its not that ard..i did it on my old crx
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 07-06-2009, 03:56 PM   #3
Thank you, I will check the VC for that mounting hole. I tucked the headlights ect behine the fender, but is there any possible way that I could tuck the engine harness side so noone can see it? I am trying to be really creative.
Old 07-06-2009, 06:24 PM   #4
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
yea where it comes through the firewall on the passengers side just push it all back through there
GOOD FAST CHEAP,
Old 07-12-2009, 10:11 PM   #5
Hey guys, great news!, the wire tuck was successful for the lights and whatever else I could test worked. So far so good. I am enjoying this progress. I have decided that I would just leave the engine harness wires the way they are.
Old 07-13-2009, 05:29 PM   #6
SOHC VTEC at its best
95EGCoupeVtec's Avatar
Ride:  95 Civic EX Coupe
Rep Power: 6 95EGCoupeVtec will become famous soon enough
myspace
upload some pics so we can see them.
95 Civic EX Coupe:
GSR suspension
rear LCAs & tie bar
no PS or A/C
Turbonetics t3/t4B (ceramic ball bearing) Super V Trim, Stg 2 .48 A/R
Xenocron chipped ecu
Greddy Type RS bov
Tial 38mm WG
GOAUTOWORKS cast mani, 3" DP, WG dump, & oil lines
Spearco Intercooler
450cc DSM blue tops
walbro 255
HG and ARP studs
Aluminum rad/fan combo from GoAutoworks
Competition Clutch Stg5 w/4puck disk
BF Goodrich Drag Radials
Soon to have:
15" Rota Slipstreams
tune by Darren in Baton Rouge, LA
95EGCoupeVtec is offline   Reply With Quote
Old 07-13-2009, 06:25 PM   #7
Neon Owner
cjvictoria's Avatar
Ride:  '04 NEON
Rep Power: 89 cjvictoria has a reputation beyond repute
cjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond reputecjvictoria has a reputation beyond repute
Send a message via Yahoo to cjvictoria
yes ^^^ PICS
XBOX LIVE - jdmJO3
>>>Click ME<<<
I have D16Y7 injectors and fuel rail fo sale. pm me if interested.
cjvictoria is offline   Reply With Quote
Old 07-14-2009, 01:38 AM   #8
Alright sounds good, I will take many tomorrow and they will be posted ASAP. Thanks for the interest in this.
Old 07-14-2009, 09:05 AM   #9
yep....mmhhm.......yep...
DESPAIN's Avatar
Ride:  92 PRELUDE SI
Rep Power: 83 DESPAIN has a reputation beyond repute
DESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond repute
Send a message via Yahoo to DESPAIN myspace
i would love to do a wire tuck on my 92 prelude. i wonder how hard and time consuming that will be?
Hugh.......I like money.......
"idiocracey"
Originally Posted by DarkHand View Post
Strippers eh? That'll get you a good view of the elusive pink snapper, but don't try to catch the ones around there, they usually have parasites.
Originally Posted by phyregod View Post
Probably waiting on an equipment upgrade.
"This tower runs hondaswap, Those 14 racks over there run the GF pic threads"
DESPAIN is offline   Reply With Quote
Old 07-14-2009, 10:47 AM   #10
From what I hear, there are all different types of doing a wire tuck. The very first step to starting this project it to mark ALL wires. This one in particular took me 2-3days of solid work to get it done right. I just tucked the headlight, horn, multi-ground, radiator fan relay and wires, and side markers. Just as a suggestion though, this wiring tuck required about 5-6 feet of heat shrink and with my calculation it would have cost me $14.06 at 2.49(plus tax) per package (at 5 feet); $16.95(incl. tax), at 6 feet of heat shrink from my local Canadian Tire store. I bought 2x(5 foot) pieces of heat shrink tube for $5 from an electrical store, that I just cut to size. As well, on a side note, but very important, as a suggestion do not cut all wires from the passenger side grommet then re-solder them; rather, just cut the wires to be tucked. I did this because I was going to try to hide the engine harness connectors as well, but decided against that idea so now I am stuck with re-soldering the joints for absolutely no reason. Here is a list of supplies and tools needed:
-Soldering Iron
-Soldering wire and Flux
-5-6 feet of 1/8" heatshrink (for both the 18 and 20 guage wire) *it will only work on 18 guage if you slide the wires together rather than "pigtailing" them together*
-1 foot of 3/8 heatshrink (for thicker 20 guage wire)
-scissors (for cutting the heat shrink into the size you need)
-wire strippers
-electrical tape
-wire loom (for protection), and
-16 guage, thickest wire used, (it is used on 1 wire to extend the heater wire); 18 guage ,just a bit larger, than 20 guage, (it is used for the headlights, horn, rad fan relay wires, multi-ground, and extension); and 20 guage wire (this is thinner wire for your multi-ground wire, side markers, and extension pieces)
Last edited by 89' Project Civic; 07-14-2009 at 11:06 AM. Reason: forgot some information
Old 07-17-2009, 11:18 AM   #11
Sorry boys, I have not got around to taking pictures. I will TRY to get some tonight and post ASAP.
Old 09-02-2009, 12:10 PM   #12
Rep Power: 1 95integra123 is on a distinguished road
how was taking the ground off? did it act different?
95integra123 is offline   Reply With Quote
Old 09-02-2009, 11:25 PM   #13
Actually my car is in complete pieces, it looks like a bomb hit it and blew it to smitherines. I am working on getting it all back together with clean or new OEM parts. I have officially stopped buying performance parts for right now. I have overdone the performance part sector of this car and I need to reverse back to OEM a.s.a.p. Thanks for asking though, but if I did not have the ground on the valve cover to the chassis I know 100% it would not run at all. I believe it is the most important ground on the car!
Wire tuck went to H very quickly, please help! wagovanb16man Civic and CRX - EF 6 09-10-2007 11:17 PM
Wire Tuck Just2Much19 HYBRID -> EG-EK / DC 6 04-15-2007 09:41 PM
Wire tuck progress EK 97CTR Auto Multi-Media 10 03-17-2007 06:59 PM
Wire Tuck TheDarkpickle ECU's, Electronics, and Tuning 1 08-07-2006 07:09 PM
anyone have any dyi wire tuck o0ohferrealz HYBRID -> ED-EF / DA 10 04-16-2006 10:04 PM
