Go Back   HondaSwap Forums > Appearance and Accessories > Body / Exterior / Interior / Cosmetics
CRX Seat Swap
Old 02-07-2006, 05:48 PM   #1
Rep Power: 0 la_hoodlum is off the scale
Hey i got a 92 hatch and was wondering if crx si seats would fit in place of mine, i will be getting the crx seats with brackets, would i need anything else? thanks, peace
la_hoodlum is offline   Reply With Quote
Old 02-07-2006, 06:00 PM   #2
VTECin5th's Avatar
Rep Power: 41 VTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of lightVTECin5th is a glorious beacon of light
Send a message via AIM to VTECin5th
Wrong forum.
After it's moved you should have better luck with it.
I would guess they're not a direct bolt in, but im sure it can be done without too much work.
k20dc5
VTECin5th is offline   Reply With Quote
Old 02-07-2006, 06:28 PM   #3
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 527 E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
[img]style_emoticons/<#EMO_DIR#>/icon_moved.gif[/img]
МОΛΏΝ ΛΑΒΈ
Old 02-07-2006, 06:48 PM   #4
Rep Power: 8 jdmh22hatch is off the scale
I've done this exact swap myself, so it can be done. involves a bit of cutting, drilling, shimming etc to make it work, but it's not very hard. CRX rails will not bolt onto the civic floor though, so you have to adapt the crx seat to the civic rails. Either that or just do some welding. Than you would be able to make the crx rails work, and wouldn't have to hack the stock seats at all. It's not a reversable swap though because you will have cut the stock rails completely apart, so if you want this to be reversable or plan on selling the stock seats, then I would go the welding route, or at least make some sort of adapter to adapt the crx rails to your floor. for example, the crx rails are narrower, not quite as long, and the rear mount tab on the rails is on a different angle than the stock rails.
jdmh22hatch is offline   Reply With Quote
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
