Go Back   HondaSwap Forums > Appearance and Accessories > Body / Exterior / Interior / Cosmetics
EF bodywork thread
Old 06-14-2008, 01:51 PM   #1
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
Default EF bodywork thread
ok so i guess im going to start my body work build..
over the next couple months i will be doing ALL the body work to my 91 civic si..
i will be repairing holes(long story)fixing rust spots,filling dents,and then painting the car...there will be a ton of pix,but this will be hung out for awhile.so all progres will be posted..
first up are the holes i was talking about..the owner before me decided he was going to put a bodykit on the car,i RIPPED off the whole kit,and came to find that the skirts were put on using 4 self tapping screws,and 4 wood screw..so heres the holes and the screws i had to pull out with pliers,because they bondod over them..
as you can see the screws are rusted and so are the holes from them..
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 06-14-2008, 01:55 PM   #2
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
the whole body will be straightened out,filled in,and all that..the original owner also decided to mold the sideskirts and sidemoldings on..very shitty job..he used bondo,fiberglass,and newspaper..yes newspaper,he put it behind the skirt so it wouldnt flex..in the above pix you can see the "ridge" of bondo/fiberglass he used on the moldings...oh yea speaking of moldings.this car once done will not have any on the sides seeing how the holes are all out of shape,,and all the clips were broken anyways..so its easier to shave them rather than track them down and go through the work of putting them on and getting them adjusted to fit right..
GOOD FAST CHEAP,
Old 06-14-2008, 02:55 PM   #3
Got Rice?
801CRX's Avatar
Ride:  89' CRX HF and 90' Civic Si
Rep Power: 27 801CRX is just really nice801CRX is just really nice801CRX is just really nice801CRX is just really nice
Good luck dude!
Save that EF!
I have to do body work like a mo-fo on my 89 CRX HF.
On my 90 Civic Si its just the usual quarter panel rust, around the wheel arch area.
But for the wheel arch area I found these, and it just might help you out to:
http://www.rustrepair.com/repair_pan....htm?r=ru&p=sm
They fit both the CRX and Civic, they sale them for bothe sides also.
Hope this helps.
Keep us posted and again good luck!!!
www.supremacyracing.com
801CRX is offline   Reply With Quote
Old 06-14-2008, 03:45 PM   #4
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
nice..thanx for that link..
surprisingly only my drivers side well has rust and its the surface bubbles,,ive already got them sanded,im about to go bondo the tiny holes after i grind away the rest,then theyre getting filled with bondo..
the car should look pretty good when its done,,and itll def not have any rust after im done,and wont for a very long time
and i took off the emblem they put on the hood(some of you may have seen it,,the red R) so i just got done filling the two holes,now just gotta sand it and prime it..
but im trying to use the least amount of filler as i can..
GOOD FAST CHEAP,
Old 06-15-2008, 10:41 AM   #5
Ride:  i have 14 cars i drive my sohc turbo ef
Rep Power: 34 97hatch is a jewel in the rough97hatch is a jewel in the rough97hatch is a jewel in the rough
good luck i just started a similar project a few weeks ago i got a 91 si hatch that had been molested by many owners it had almost a 1/4 in of material on in after all the primer spray in filler and the paint from moving to garage to garage over the last 3 years i striped the whole car to bare metal with aircraft stripper and 80g now i have etch primed and then shot it with regular primer now im geting ready to guide coat it and block it out and fix what needs fixin good luck with your project.
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
97hatch is offline   Reply With Quote
Old 06-15-2008, 11:37 AM   #6
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
thanx man..yea its not hard its just time consuming..goodluck to u as well..
post some pix of the progress..
GOOD FAST CHEAP,
Old 06-15-2008, 09:37 PM   #7
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
the bondo on the hood..havent had time to sand/prime it
GOOD FAST CHEAP,
Old 06-15-2008, 09:44 PM   #8
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
Rep Power: 227 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
You decide what color your going to paint it yet?
^ (dont listen)
There is a hidden message here.
"Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details."
"In the dice game of life who gets the last roll?"
Old 06-15-2008, 10:06 PM   #9
Got Rice?
801CRX's Avatar
Damn man only surface rust!
You got lucky dude, on both my CRX HF and my Civic Si there rusted all the way through. But what can you expect when you live in Utah. You've got the Great Salt Lake, which carries massive amounts of salt in the air. And did I forget to mention the snowy ass winters we have here, or the salt they use on the roads 24/7 for the ice. I dont drive neither Honda in the winter, but it's obvious the previous owners have.
Keep us posted!
Old 06-15-2008, 10:06 PM   #10
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
championship white
GOOD FAST CHEAP,
Old 06-15-2008, 10:23 PM   #11
My name is Byron.
efhondakid's Avatar
championship white
Should look good.
^ (dont listen)
Old 06-17-2008, 02:36 PM   #12
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
myspace
What do you got going on for rims?
PSN Network ID: BrutalB83
BrutalB83 is online now   Reply With Quote
Old 06-17-2008, 06:46 PM   #13
Got Rice?
801CRX's Avatar
How's it coming?
Just don't give up and lose motivation in the middle of it like I did on the REX.
More pics!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!
Old 06-19-2008, 08:05 PM   #14
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
sorry guys havent been on ina couple days..been real caught up,,with a GIRL
i will have more pix up tomorrow,
i got most of the holes in the side bondo'd just gotta sand them and do some touchups..
as for rims,right now im on the rims that were on my bros bmw.if i keep em,theyre going black with polished lip,
im not too sure what i want to do,theyre 14's but the tire size is waaaaay too tall,im rubbin fenders on a 1.5 inch drop..
if i dont keep them i dont know what i want..but i will only go as high as 15's
GOOD FAST CHEAP,
Old 06-20-2008, 02:18 AM   #15
My name is Byron.
efhondakid's Avatar
Those are good looking wheels, just drop a tire couple sizes.
^ (dont listen)
Old 06-20-2008, 07:09 PM   #16
Got Rice?
801CRX's Avatar
Post pics of the girl then!...lol
Or even better her with the car!
Keep at it man.
Old 06-20-2008, 10:23 PM   #17
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
haha she lives in NH ill try to get some pix though..but heres a couple more of the 1st stage of bondo on the sides..i still have to sand and go over them again..
side-bondod.jpg  rub.jpg  front-wheel.jpg  bondo-side.jpg  nother-bondod-side.jpg
GOOD FAST CHEAP,
Old 06-20-2008, 10:32 PM   #18
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
and a little trick i learned from my boy..ls_ef...some of you may have seen the "duckbill" on the eg hatch..well you can kinda resemble that by just adjusting one little thing,
1. get a wrench and a 10 or 12mm socket(i cant remember which one.i believe its a 10)
2. get a friend or family member to help hold the spoiler.take off the 4 nuts under the hatch that the spoiler on.
3. pull the spoiler off and put the nuts on the holes toward the back(if the hatch is all the way open it will be the 2 top holes)
4. put the spoiler back on( the nuts will be on top of the back holes instead of the bolt going through..now all you have to do is tighten the 2 nuts on the front(the bolts should be through a little bit
basically it angles the spoiler up a little instead of sitting flat off the back of the car..should look like this
GOOD FAST CHEAP,
Old 06-22-2008, 02:53 AM   #19
Got Rice?
801CRX's Avatar
Looks like its moving along!
The angled spoiler isnt really appealing to me. But thats just me, its your car let it resemble you. As long as your happy with it who cares what anyone else thinks.
Pics of the girl FTW...lol
Good luck!
Old 06-29-2008, 08:08 PM   #20
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
ok so update time,,,i havent done anyything to the exterior,still need to sand the bondo and touchup some spots,but ive changed my mind on the color...i think im going to go with silver,,the same color as the 02 celicas,,just because i think itll look sick on my ef..but i dont know if i want to do that shade or a little darker..
i dunno,i have some time to decide,and the car is almost running,just need to find a dizzy...because the guy i got mine from(ctgoldhatch94 or bluehb95) sold me a garbage dizzy
GOOD FAST CHEAP,
Old 07-13-2008, 09:16 PM   #21
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
BUMP!!!
forgot to mention awhile ago its running mint...keot swapping back and forth bewteeen the pm6 and pr4 and the codes just went away/..
now just have to find out why it shaking so bad on the driver side front wheel..but as for bodywork,i started sanding it down,and started applying a second coat...
but the car is slowly coming together...
sorry dont have much to update..vic's got me a little woopty
GOOD FAST CHEAP,
Old 07-13-2008, 09:33 PM   #22
Honda Enthusiast
Luis998's Avatar
Ride:  '94 EG sedan w /Z6, '97 EK hatch
Rep Power: 103 Luis998 has a reputation beyond repute
Luis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond repute
I'm in for the progress on this one. Best of luck man.
Max? There is no max. Max just means you gave up.
This is my thread: http://hondaswap.com/engine-building...g-wind-110848/
http://hondaswap.com/members-lounge/...thread-278554/
Originally Posted by LS_VTEC View Post
lol... you could say that doing it right will "get you bitches". ;x
Originally Posted by efhondakid View Post
"Im so JDM I sleep on the right side of the bed"
Luis998 is offline   Reply With Quote
Old 07-29-2008, 11:41 PM   #23
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
ok so i have been pondering a color for awhile and am still not sure,,but lately ive been looking and i really like the ZEX purple..soo would it look good on an EF???
GOOD FAST CHEAP,
Old 07-30-2008, 10:47 AM   #24
kid that everyone loves!
91accordwithwork's Avatar
Ride:  91 accrod DX with a few extras : )
Rep Power: 0 91accordwithwork is infamous around these parts91accordwithwork is infamous around these parts91accordwithwork is infamous around these parts91accordwithwork is infamous around these parts91accordwithwork is infamous around these parts91accordwithwork is infamous around these parts91accordwithwork is infamous around these parts91accordwithwork is infamous around these parts
nice work
heres my mod. list
-painted valve cover
-new headers
-new high flow obx resonator
-new carbon fiber exaust tip
-new p.s pump
-new radiator
-new belt
-new injen ram intake
-new strut bar
-new deck (installed myself)
-new speakers
-not bad for learning as i went and not having shit for help besides u great guys
i think thats around all i did, tok a few months but im happy with it!
and after all that theres a small puddle of oil under my intake on my engine.....
the fun never ends!
91accordwithwork is offline   Reply With Quote
Old 07-30-2008, 10:54 AM   #25
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
thanx^ the car was reallly hacked
GOOD FAST CHEAP,
major bodywork on 99 sedan ej1-94 Body / Exterior / Interior / Cosmetics 8 11-26-2007 03:45 AM
Bodywork and paint TurboMirage Other Vehicle Discussions 24 08-05-2007 07:43 PM
Got some bodywork done...sort of VTECPOWER Body / Exterior / Interior / Cosmetics 6 03-12-2005 12:51 AM
bodywork bigdaddyIII Members' Lounge 17 02-09-2004 12:34 AM
Anyone need paint or bodywork. brc80 Body / Exterior / Interior / Cosmetics 8 11-17-2003 05:13 PM
