Go Back   HondaSwap Forums > Appearance and Accessories > Body / Exterior / Interior / Cosmetics
Halo projector headlight help for 97 accord
Old 08-23-2003, 11:35 AM   #1
Rep Power: 0 cstyle is off the scale
Where do the extra wires hook up too. If i hook them to the battery they dont turn off. Where and how do i hook the wires up at.
cstyle is offline   Reply With Quote
Old 08-23-2003, 12:31 PM   #2
Slammed89Integra's Avatar
Ride:  2007 Scion TC, 2005 Suzuki GSX-R 600
Rep Power: 105 Slammed89Integra has much to be proud ofSlammed89Integra has much to be proud ofSlammed89Integra has much to be proud ofSlammed89Integra has much to be proud ofSlammed89Integra has much to be proud ofSlammed89Integra has much to be proud ofSlammed89Integra has much to be proud of
Send a message via AIM to Slammed89Integra myspace
Which wires are you talking about? The wires from the actual halo themself, or the power wires for the actual projector lens.
When this is all over I think we should get an apartment together.
Slammed89Integra is offline   Reply With Quote
Old 08-23-2003, 12:51 PM   #3
There are a set of black and red wires coming from each light. Where do they hook up at?
Old 08-23-2003, 01:12 PM   #4
Did it come with an additional plug in harness for the projector par to plug into your stock plugs?
Old 08-23-2003, 01:30 PM   #5
Yes it came with an extra plug to plug into the other OEM plug. But there are extra wires pos and neg.
Old 08-23-2003, 01:32 PM   #6
I connected both red wires together and another red wire from that connecting to the fuse box. and grounded the other two. The lights come on with having to turn the light switch inside the car. So thats why i am unasure of where to hook them up at to where they work when i turn on my headlights.
Old 08-23-2003, 04:33 PM   #7
Rep Power: 14 hondahauge is off the scale
just hard wire them to a toggle switch in side the car
black-grnd
red- run into inside car get your power from fuse box
Justin
RIP
88 HB
hondahauge is offline   Reply With Quote
Old 08-23-2003, 04:46 PM   #8
how do i get the high beams to light up with the light switch inside my car when i turn it to high beam?
Old 08-23-2003, 05:24 PM   #9
Rep Power: 14 NewAgeCivicz is off the scale
Send a message via AIM to NewAgeCivicz
When I had those indiglo gauge lights I just pulled out my light dimmer, next to the steering wheel, and spliced the power wire off the switch. Worked out pretty good until I got sick of them and trashed them.
D-SERIES INFO - www.honda-tech.com/zerothread?id=335078
D Ser JUNKIE
NewAgeCivicz is offline   Reply With Quote
Forum Jump
88+ ECU Error Codes pissedoffsol Reference Materials 1 05-19-2005 01:03 PM
Decoding VIN Numbers pissedoffsol General Tech Articles 0 01-11-2004 08:48 PM
Need some help with Trim Names YangpaNemsay General Tech and Maintenance 7 08-31-2003 04:43 PM
Halo projector headlights need help for 97 accord cstyle Body / Exterior / Interior / Cosmetics 1 08-24-2003 11:06 PM
All This Reference Material, And No Cel Code Chart Slo86GT Members' Lounge 5 06-13-2003 10:31 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
