Go Back   HondaSwap Forums > Appearance and Accessories > Body / Exterior / Interior / Cosmetics
Headlight question... should be easy
Old 03-11-2005, 01:35 PM   #1
my avatar is better.
Rep Power: 52 YouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to beholdYouKnowWhoIBee is a splendid one to behold
Send a message via AIM to YouKnowWhoIBee
My low beam went out on my headlight... but not my high beam. What could be the problem? Is it wiring or a bad bulb? Thanks in advace
YouKnowWhoIBee is offline   Reply With Quote
Old 03-11-2005, 01:41 PM   #2
Citizen_Insane's Avatar
Rep Power: 51 Citizen_Insane will become famous soon enough
Send a message via AIM to Citizen_Insane
its probably just the bulb. You can pick up a new one @ your local auto-parts store.
No tech questions through PM please!
B16 CRX....you will be missed
Citizen_Insane is offline   Reply With Quote
Old 03-11-2005, 02:22 PM   #3
Well i know that... but living on a budget is hard. And i have the silverstars in right now so i dont wanna out back in a stock bulb and it be 2 different colors. And i dont know if i want to ride around with my highbeams on all night.
Old 03-11-2005, 02:31 PM   #4
TTIWWOP
reckedracing's Avatar
Ride:  90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
Rep Power: 411 reckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
reckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
uhh...
so either buy a new set of silverstars, or get a set of stock and put both back to stock...
I'll blow a hole in your face then go inside and sleep like a baby.
reckedracing is offline   Reply With Quote
Old 03-11-2005, 02:39 PM   #5
Well i was just wondering if it was the wiring or the bulb... So if it is the bulb then when i replace it i know it will work. Or would something have shorted out to make just the low beam go out.
Old 03-11-2005, 02:56 PM   #6
Rep Power: 20 b204dr is an unknown quantity at this point
Send a message via AIM to b204dr
happened to me alot - bulbs - could you have touched the glass putting it in that will shorten the life indeffinatly - dont mind my spelling
friction created heat which creates power=does this apply in the word of automotive
b204dr is offline   Reply With Quote
Old 03-11-2005, 03:12 PM   #7
Ride:  JHMED9 w/ Non-Vtec DOHC 1.6
Rep Power: 13 baker423 is off the scale
Send a message via AIM to baker423
Don't make this out to be harder than it should be...
Check your wiring,i once had a wire disconnect from the light harness which caused the low beam to go out,so check that.
Other than that Go buy a bulb,install it and see if it works.
baker423 is offline   Reply With Quote
Old 03-11-2005, 03:35 PM   #8
TTIWWOP
hmmm...
here's a novel idea
if the other bulb WORKS, and you know it works on both high and low beam, then why don't you just take it out and put it in the other side...
then if the other side works both hi and low with the bulb from the opposite side you know the bulb is shot...
genius ain't i?
