| | LinkBack | Thread Tools |
| | #1 |
| 2265787829 Join Date: Aug 2003 Location: NOT in Indianapolis Age: 27
iTrader: 0 / 0% Ride: Refer to my name, dumbass.
Rep Power: 399 | Do I need a safc or hondata to hook this thing up? if not what do i hook the wires to? There's a green, red and black wire. I'm assuming black is for ground. Where would red and green go to? Thanks for any help. ps if this is in the wrong forum, sorry. btw NotUr... I got it like forever ago... I think I sent you a PM but here's a pic. Thanks. |
| | #3 |
Rep Power: 399 | blah... i knew this was in the wrong place. looked right at first...anyway... I found a pdf on autometer.com... should be good to go. |
| | #4 |
| Senior Member | solder all yer connections and red just goes to power, black to neg, and run the green wire directly into your dizzy to your coil. This will g ive you the best reading for true rpms of the motor....(the green wire goes to the neg side of the coil. make sure it is directly to the coil...inside the cap...mkae a notch and you'll be set. nathan |
| | #5 | |
| Super Moderator | Quote:
| | #7 |
| Senior Member | well if it's set for 8, it's going to read double of the true RPMs I believe. This will make the light go off at half of the point you want. Something different has to be done with that green wire, or with something else. The power/ground wires go the same place no matter what. It's impossible to know without seeing the wiring diagram/manual for the certain light. They are all different. |
| | #9 |
| Senior Member | well, an 8cyl distributor has to fire twice as many plugs in one rotation than does a 4cyl. I'm not sure what that means for the voltages. I know for a tach you definitley have to do it differently. Without knowing how that light works in particular, I have no clue. You could be right. |
| | #10 |
| Senior Member | just read the instructions that it has with it as far as setting it up for a 4//6/8. a v8 will show half the rpms and a v6 2/3s of the real rpms. i almost blew up my damn motor the night that i put my tach/shift light in because i had it set at the v6 setting. wire it up according to my other instructions. as far as the 4/6/8 there should either be a thing on the side wehre you can select the # of cylinders or there should be 3 little loops of wires. if yours has the clicker selector thingy, then just set it to the right number of clyinders. if it is the few different loops of wire, then you'll need to i believe it is autometer.com and search for there tachs/ w shift lights and they explian which wires to clip. nahtan
__________________ 1991 CRX SI - Built D16Y8 - The piston melter 1990 CRX SI - B18A1 ... ls/vtec in the process y0 1988 Civic DX 4dr - d15b2 w/ mpfi + flaterate t-25 kit |
| | #11 |
Rep Power: 399 | the 4,6,8 is on the back. There's a howto on autometer.com telling me where everything should go. I just need to get some wiring so i can run it through the grommet I ran my power wire through... then i gotta mount the light someplace you can't see it from the outside. |
| | #12 | |
| Chicks dig the box Join Date: Sep 2002 Location: Tucson, AZ Age: 25
iTrader: 0 / 0% Ride: 2006 Scion xB
Rep Power: 128 | Quote:
a/c vent yO!! | |
| | #13 |
| Senior Member Join Date: Jan 2003 Location: Raleigh, NC Age: 22
iTrader: 2 / 100% Ride: 88 Honda Civic HB
Rep Power: 195 | i thought tachs run off how fast the pulses are coming from the dizzy. ive seen(on horsepower tv) v8s still use a trigger in the dizzy; usually points type(they converted it to a halls i think). |
| | #14 | |
Rep Power: 399 | Quote:
a/c vent yO!! [/b][/quote] I'm not running the wires through the ac vent. I still have a few of the panels left off so it'll be easier to hide them that way. | |
