Go Back   HondaSwap Forums > Appearance and Accessories > Body / Exterior / Interior / Cosmetics
how to paint a valve cover????
Old 12-21-2007, 03:39 PM   #1
roman_pushkin's Avatar
Rep Power: 0 roman_pushkin is on a distinguished road
Default how to paint a valve cover????
have a valve cover and been wanting to repaint it, but dont have a sand blaster so what kind of sand paper should i use??? Any color suggestions its a 90 white accord with a stock engine
roman_pushkin is offline   Reply With Quote
Old 12-21-2007, 03:46 PM   #2
HS TECH
AHHVTEC's Avatar
Ride:  dc5,mk4 gti,2nd gen civic,
Rep Power: 181 AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
i would just take it some where and have it blasted,but if your vc is stock you can just use engine paint without primer or anything as long as its good and clean, and when it heat cures it will have that wrinkled look,
Old 12-21-2007, 10:46 PM   #3
universal logic protocol
whiterabbit06's Avatar
Ride:  99 VW GTI 90 Civic Hatch 07 Jeep Compass
Rep Power: 69 whiterabbit06 has a reputation beyond repute
whiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond reputewhiterabbit06 has a reputation beyond repute
Send a message via AIM to whiterabbit06 Send a message via MSN to whiterabbit06 Send a message via Yahoo to whiterabbit06
When I did mine I used a sand blaster. If I was in your position I would try to use some paint thinner or paint remover. If not use some 120 grit sand paper. as long as you put a few coats of primer on it and take your time it should come out nice smooth and shiny. Remember when painting to let the coats dry before applying another and not to overspray. Here are some pics of mine.
Before
After
90 Civic Hatch
99 VW GTI <= BIG F'IN POS
07 Jeep Compass
If you ever find anything I write usefull please leave rep.
Rebuilding a Transmission
http://www.the-whiterabbit.com
whiterabbit06 is offline   Reply With Quote
Old 12-22-2007, 01:20 AM   #4
Crusher of Noob Ambitions
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
Rep Power: 160 BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
BrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond reputeBrutalB83 has a reputation beyond repute
myspace
I would prefer to not sandblast a valve cover actually. Yeah, it will give you a nice surface to paint, but it can also leave junk inside the valve cover that will eventually end up inside the motor.
Here's how I did mine:
First, I stripped the paint off with aircraft stripper. It works great; just spray the valve cover down with it and then wait 10 mins or so. The paint should start to bubble and then you can just take a hose and wash it off. You might have to repeat this a couple times to get all the factory paint off. Also, be careful with the stripper, because it will burn your skin.
After that, I bought a little sanding kit from Wal-Mart that has discs you can put on a drill. It came with 3 discs, a course sandpaper, a lighter sandpaper, and a Scotch Brite one. I just went over the whole valve cover with each of those, ending with the Scotch Brite. I would also recommend buying a few sheets of sandpaper and a Scotch Brite pad to get in the little areas where the sanding discs won't fit.
After that, wipe it down with a tack cloth to get any sanding dust off (or just wash the whole thing with soap and water. Now you're ready to paint...
You don't really need to use a primer, but it doesn't hurt. I used Duplicoler engine enamel. I sprayed about 3 coats of primer, followed by 4 coats of color, and then about 3 coats of clear. I did all of that in succession (like don't wait for the primer to dry completely before you spray the color), waiting about 15-20 mins in between coats. Just take your time, hold the can about 8-10 inches away from the valve cover, and spray light coats. 3-5 light coats is better than 1-2 heavy coats; you won't get runs if you do light coats.
After that, I'd let it sit somewhere for a good 48 hours if you can. If you only have one valve cover and you need to drive the car, then you can try baking it in the oven to cure the paint, or just install it back on the car and let the heat from the motor bake it.
If you have any other questions let me know. Here's a picture of how mine turned out:
If you find something I say helpful, please rep it up!
97 Integra LS Coupe:
*AEM Intake/Megan Header/Magnaflow Exhaust
*Tokico Shocks & Springs
*Megan Strut Braces & H-Brace
*98-01 Conversion (Front/Rear Bumpers & "Mesh" Alloys)
Old 02-04-2008, 08:59 PM   #5
here it is how my valve cover turned out!!
Old 02-04-2008, 10:03 PM   #6
BrutalB83's Avatar
myspace
Looks pretty good man! Good work!
Old 02-04-2008, 11:13 PM   #7
The name's Sam
philyphreak2127's Avatar
Ride:  98 civic dx sedan, 80 trans am
Rep Power: 18 philyphreak2127 will become famous soon enough
brutal you should do a write up in the tech section...I know there is already one but do a revision for people that don't have a sandblaster.
philyphreak2127 is offline   Reply With Quote
Old 02-04-2008, 11:20 PM   #8
Nice work.
90 Civic Hatch
07 Jeep Compass
Old 02-05-2008, 12:11 AM   #9
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 243 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the Little EVO5
Old 02-05-2008, 02:01 AM   #10
BrutalB83's Avatar
myspace
I have one on a different site actually. Maybe I'll ask B or some of the other staff if they'd be interested in having it on HondaSwap.
Old 02-05-2008, 03:11 AM   #11
The name's Sam
for sure. It's worth it. I didn't even use paint stripper when I painted mine. I went over it with an air powered sander, and then by hand, I am in the process of wet sanding it now. Just to get some of the deep scratches semi out of it before I paint it.
Old 02-05-2008, 01:01 PM   #12
BrutalB83's Avatar
myspace
I bet that thing will look real nice when you're done...
Old 02-05-2008, 02:25 PM   #13
The name's Sam
thats the plan. there are actually 2 in the works, and one already painted on my car. I have a couple spare motors.
Forum Jump
gsr valve cover ripperbone Parts: For Sale/Trade/Wanted 0 10-11-2007 05:22 PM
Polishing Valve Cover! Suggestions...??? bigballsmagerki Civic and del Sol - EG and EK 7 01-09-2007 04:38 PM
F/SorF/T: TypeR OEM red valve cover Brand New projectxspeed Parts: For Sale/Trade/Wanted 3 04-15-2005 01:43 PM
BRAND NEW Integra Type R valve cover 110 shipped david_jones001 Parts: For Sale/Trade/Wanted 7 03-12-2005 08:43 PM
B18C valve cover. Circuit General Tech and Maintenance 5 11-03-2003 06:03 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
