wek sos
Ride: EG-6 hatch
The Proper way:
Materials Needed: 1. Razor Blade 2. Spray Bottle 3. Scent Free Amonia (this can be picked up at any dollar store) 4. Black Garbage bag (this can be picked up at any dollar store) (MUST be black) 5. Water 6. Sunlight Procedure: 1. Take the razor blade and along the edge of the tint. (only peel back the edges of the tint) 2. Take the trash bag and cut along the edges making it one big sheet. 3. Fill the spray bottle with water and spray the water onto the OUTSIDE of the window. 4. Place the sheet of trash bag across the window. (the water is to help the bag stick to the window) 5. Take the razor blade and cut the trash bag to the size of the window. 6. Empty the spray bottle of water. 7. Take the Scent Free Amonia and put it into the spray bottle. 8. Spray the Amonia on the INSIDE (onto the tint) 9. Immediately after, place the pre-cut trash bag onto the amonia/tint. 10. The ammonia will dry up quick, so if you have to, spray the window again right before you put the bag onto it.. 11. Take a card (credit card, I.D., or if you have one... a squeegie) and go across the trash bag very lightly to get all the wrinkles out (if you press too hard you'll rip it) 12. Let it sit in the sun. 13. Keep putting your hand onto the window to feel how hot it is.... when it gets to the point where you put your hand on the window and it bought burns you then this is when you want to start peeling it off. 14. Grab the edge of the trash bag AND the edge of the tint and start to pull it off.... GO SLOW Back Window Defrosters: DO NOT take the razor blade and start hacking at the tint... you WILL mess up the defrosters. 1. Take the razor blade and go around the edge of the whole window.. pulling up the edge of the window tint... 2. Then go around the edges of the defrosters (yes, it will take some time) 3. Then repeat steps 2-14 above.. Hope this could be of any help!! If you followed the instructions correctly then there will be NO glue residue left on the window... any questions PM me.. -Mike- |
#2 | |
Member of the 20 nut club
good info
better than the method i use of having full glass coverage on the car and using a hammer ![]()
Running on two cylinders
Ride: 2000 Mitsubishi Lancer RPW E5 Coupe
JDM, how would you remove a clear sticker from a car window... I have one put over my defroster lines from the previous owner. i left it there just so i didnt fuck up my defrosters.
would your method work ? |
#6 |
#7 |
Ride: 88 Honda Civic HB
If it's on the outside, just use a razor.
1988 Honda Civic STD-more mods than I want to list Terrorists have successfully attacked our imagination. RIP Jon Eban Nie, August 31, 1991 - May 7, 2006 Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006 |
| gsr engine swap | Skydive2144 | Civic and del Sol - EG and EK | 17 | 02-03-2007 10:13 AM |
| How do you remove tint | RookieBoyCRXSI | Body / Exterior / Interior / Cosmetics | 6 | 07-28-2006 12:12 AM |
| Engine Removal Guide | pissedoffsol | Swap Articles | 0 | 01-12-2004 02:19 AM |
| How To: Remove Transmission | eyesonlybob | General Tech and Maintenance | 1 | 10-23-2003 05:47 PM |
| take my quiz :) | pissedoffsol | Members' Lounge | 43 | 07-24-2003 04:46 PM |
