my avatar is better.
Use a plastic primer. And let the peices dry for a while outside because your whole car will smell like paint forever. But dont go over board. One or 2 peices is cool but andmore than that i would just spend the money and get it dyed. It is not worth the trouble
Ride: 06 Chevy Silverado
Krylon fusions for plastics
Ex 89 crx si,91 & 95 Civic owner. 06 Silverado RCSB 20's, 2/4" Belltech lowering kit, waiting for 2 more cylinders, 1.9 more liters, and 208 more hp engine swap. |
#4 | |
Paint sucks get it dyed or find a black interior.
I have painted interior wouldn't do it again. __________________
Hello old Skuul Hatch it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums? ![]() Quote:
#5 |
Go to napa and buy the interior paint called SEM...Its a graet product..All you need to do is clean the panel by via the directions and apply...It will look like an OEM finish.A little pricey but not bad.
"Push the envelope watch it bend".......TOOL <a href=\'http://www.performancefreaks.com\' target=\'_blank\'>www.performancefr eaks.com</a> |
#6 |
Ride: 2007 Camry / 2005 Acura MDX
I used High temp engine paint, very nice & glossy I recommend it, It's at autozone for cheap been about 2 years an no chipping or raring down..
2007 Camry XE 2005 Acura MDX Touring Edition |
#8 |
Clean the peices really well and spray them with adhesion promoter before applying any paint. You don't need primer.
Don't use krylon, it is garbage. Use real paint if you want it to last. __________________
<span style=\'font-family:Arial\'>Drifting is lame</span> <span style=\'font-size:14pt;line-height:100%\'>EK's are JDM. USDM 96-00 Civic Hatches are EJ's.</span> |
#9 |
Actually Krylon fusions is good paint if used properly. I painted the lower plastic piece of my old front bumper on my 04 Silverado with it and it did not chip or peel. I had it on there for about 8 months so it had winter to summer to fall conditions without any problems. At work sometimes I have to push the snow banks in a little because my truck is so long and it did not scatch the fusions at all.
#10 | |
I wear stretchy pants
Ride: chevy s-10
just saw this post. If you havent painted the parts heres some tips.Before you apply ANY paint. Use cleaner to get all the silicone (Armorall or anything that you put on it to make it shine) off. I used to work at a paint shop and theres nothing worse than to see your paint Run. Also use a light coat first. Then come back and finish the job.
#11 | |
#12 | |
Führer Mod
#13 |
The G37....
Ride: Black G37, '07 R6
why are you retards reviving a thread over a year old?
I changed the page layout. let me know what you think. I need feedback. www.obamacies.com |
#14 | |
#16 |
ok i work at a shop so heres what u do scuff them wit a red scuff pad then clean then very good. u must get a adhesion promoter to sray on before hand to allow it to stick. for best results i painted my with ppg paint and it looks like the outside of the car and doesnt peel had it for 3 years now. u can use other paints just make sure u use the promoter first
#17 |
93 Del Sol
Ride: 93' Honda Del Sol
What is promoter and what is ppg. I'm painting my interior and this shit is confusing.
93' Honda Del Sol S If you'd like to talk to me personally you can reach me at www.myspace.com/backboardkilla89 or email me at backboardkilla89@yahoo.com |
#18 |
Running on two cylinders
Ride: 2000 Mitsubishi Lancer RPW E5 Coupe
adhesion promoter helps the paint bond to the plastic easier.
PPG is a paint manufacturer. __________________
Home of the RPW built 2000 Lancer CC Coupe. See what is done to the little Evo5. "If you don't like what I've done with my car, I will gladly refund all the money you put into it." |
