Go Back   HondaSwap Forums > Appearance and Accessories > Car Audio / Security / Electronic Accessories
alternator whine
Old 08-12-2009, 08:41 PM   #1
Ride:  92 integra gs, 03 sonoma zr2
Rep Power: 2 monty92 is on a distinguished road
Default alternator whine
i started to get an alternator whine after i got my ls/vtec installed. i have my power wire and rca/speaker wire down different sides of the car. i put my power wire through a different spot and that didnt fix it. any ideas?
monty92 is offline   Reply With Quote
Old 08-12-2009, 09:36 PM   #2
Ride:  1991 civic dx
Rep Power: 9 efalex has a spectacular aura aboutefalex has a spectacular aura aboutefalex has a spectacular aura about
myspace
what kind of alt r u using?
efalex is offline   Reply With Quote
Old 08-12-2009, 10:03 PM   #3
old sckool enthusiast
OGMatt's Avatar
Ride:  89' CRX Si
Rep Power: 47 OGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant future
I had the same issue! I forgot about it and then rememberd it and it was gone. I did get a new fuse and redo my ground wire. Try that.
shaved sig
OGMatt is offline   Reply With Quote
Old 08-13-2009, 12:18 AM   #4
its just the factory alternator. i got a 4 gauge power wire. im going to try re grounding it tom and see if that'll help. thanks
Old 08-13-2009, 03:42 PM   #5
OGMatt's Avatar
Ride:  89' CRX Si
Yups np
shaved sig
Old 08-13-2009, 09:16 PM   #6
tried re grounding it and its still happening. could it possibly be the alternator is just wearing down i dont know if its been replaced.
Old 08-13-2009, 10:59 PM   #7
OGMatt's Avatar
Ride:  89' CRX Si
I really don't think it's your alternator . Try to seperate your system remote wire away from the power wire. Also insted of grounding the wire from the deck to the ground wire on the plug, wire it directly to a peace of shaved metal on the frame or fire wall ect.
shaved sig
Old 08-14-2009, 12:57 AM   #8
i already have the remote wire away from the power i ran it with the rca's. could it possibly be the wiring for the vtec that goes into my ecu cause i got an ls/vtec and this whine started?
Old 08-15-2009, 09:19 PM   #9
...PENDEJO....
BodyDroppedNikes's Avatar
Ride:  bagged Ford Ranger Splash
Rep Power: 202 BodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond repute
BodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond reputeBodyDroppedNikes has a reputation beyond repute
Send a message via AIM to BodyDroppedNikes Send a message via Yahoo to BodyDroppedNikes myspace
where do you have it grounded at?
***Please leave this section blank. For office use only.***
-BrianE.
1995 Ford Ranger Splash
2009 Ford Focus
http://midwestminis.forumotion.com/forum.htm
Originally Posted by MthaFuknGreen
noo... pole like the things strippers are on.
(id say like your mom is on, but i dont wanna get banned.. lol)
BodyDroppedNikes is offline   Reply With Quote
Old 08-16-2009, 12:24 AM   #10
OGMatt's Avatar
Ride:  89' CRX Si
word^^^
shaved sig
Old 08-16-2009, 04:51 AM   #11
i used the bolt for the back seat as the ground.
Old 08-16-2009, 01:38 PM   #12
...PENDEJO....
hrmm u shouldnt have engine noise then. take some sandpaper and sand some of the paint under where the seat bolt is to get a better ground. also, are you running the same gauge wire for the ground as you are for the wire going to your battery (i also hope you have an inline fuse on your battery wire for your amp. if not GET ONE)? if not you need to. also, you dont need to have a long ground wire going from your amp to where you are grounding it at.
-BrianE.
2009 Ford Focus
Old 08-16-2009, 05:05 PM   #13
I wear stretchy pants
Taco15's Avatar
Ride:  chevy s-10
Rep Power: 217 Taco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
Taco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
myspace
if it started after the motor swap then its not your radio. Its definitly a grounding issue so reground the entire motor and battery again.
motor
tranny
battery
did you mess with the radio while power on and accidentally ground it? If so you might need to ground loop the radio.
Its fashion man. The chicks you see walking down the runway dont wear practical clothes, they were something that was designed to make a statement. THat statement in turns influences and shapes other peoples designs and ideas.
Same thing with cars. Except with no attractive women... and a lot more gayness.
Taco15 is offline   Reply With Quote
Old 08-16-2009, 05:10 PM   #14
i didnt do the swap i had a shop do it. and i have a 4 guage power and ground. i think i might need a new power wire cause its got a thin insulator on the wire. its got a fuse block inline. i havent tried regrounding the block yet. im gunna gut the interior and clean up the wiring.
Old 08-17-2009, 04:35 PM   #15
Taco15's Avatar
Ride:  chevy s-10
myspace
ok just to make it clear. your getting alternator whine through your speaker or just a whine from the alternator.
power wires wont do anything. Its a grounding issue if its coming through your speakers.
Old 08-18-2009, 02:18 PM   #16
i sent out my alternator to get checked it might be a diode issue.
high pitch whine in all gears Pvtjoker122 HYBRID -> EG-EK / DC 21 06-25-2009 12:04 AM
d16z6 tranny whine 92CIVIC4DR HYBRID -> EG-EK / DC 1 04-02-2009 10:53 PM
Timing Belt Whine on H22 gofastmobile General Tech and Maintenance 4 07-22-2007 10:10 PM
Engine whine when reving MadMaXXX General Tech and Maintenance 12 01-24-2007 04:18 PM
Power Steering Pump whine Har0ld Civic and del Sol - EG and EK 4 10-24-2006 07:17 PM
