Go Back   HondaSwap Forums > Appearance and Accessories > Car Audio / Security / Electronic Accessories
Capacitors
Closed Thread
Old 10-28-2003, 01:11 AM   #1
Rep Power: 49 Prowler is an unknown quantity at this point
Send a message via AIM to Prowler Send a message via MSN to Prowler
Default Capacitors
i just won a 1 farad lightning audio capacitor off ebay for $23. now I know they're put in line with the cable from the battery, and it'll stop my headlights from dimming when my small system hits and make it sound a little bit better. but how exactly do i hook it up? what type of connectors are used on the capacitor? how much is an "install kit"? how much is a digital voltage reader and are they recommended? should i notice a big difference in the sound? how do i mount this?
this is the pic from the auction.
2002 Audi A4 1.8T quatto
1995 Acura Integra GSR - H23A1
Prowler is offline
Old 10-28-2003, 09:22 AM   #2
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 338 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
oh my god. lightning audio... that is probably the biggest fire hazard ever.
i think they need to be charged before you install them, though.
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
TurboMirage is offline
Old 10-28-2003, 05:13 PM   #3
Rep Power: 47 liquid00meth is off the scale
Send a message via AIM to liquid00meth
Capacitors are wires in series with the regular power input of your amp. You send the power wire from your battery to the capacitor terminal, as well as all the power wires to the amp(s). So they all connect to the same terminal. Connect the ground wire of the capacitor, as well as the ground wire of your amps normally. that's all.
BUT, you MUST CHARGE THE CAPACITOR FIRST with a 12v hookup and a 1k resistor. Any stereo shop would probably be able to do this for you.
"Our enemies are innovative and resourceful, and so are we.
They never stop thinking about new ways to harm our country and our people, and neither do we."
-The thought provoking George W. Bush
liquid00meth is offline
Old 10-30-2003, 02:18 AM   #4
Rep Power: 29 rudeludenotmeanthough is off the scale
Why MUST you charge it? It does charge when you install it. so..
why..??
</div><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE (94RedSiGal @ Dec 2 2003 @ 12:27 AM)</td></tr><tr><td id=\'QUOTE\'>Having a ClubSi, Honda-Tech or HondaSwap sticker on them would just scream &quot;Steal Me Now! I'm a special car!&quot; to thieves.</td></tr></table><div class=\'signature\'>
rudeludenotmeanthough is offline
Old 10-30-2003, 02:28 AM   #5
Originally posted by liquid00meth@Oct 28 2003, 05:13 PM
Capacitors are wires in series with the regular power input of your amp.* You send the power wire from your battery to the capacitor terminal, as well as all the power wires to the amp(s).* So they all connect to the same terminal.* Connect the ground wire of the capacitor, as well as the ground wire of your amps normally.* that's all.
BUT, you MUST CHARGE THE CAPACITOR FIRST with a 12v hookup and a 1k resistor.* Any stereo shop would probably be able to do this for you.
Here this is just to clarify a bit...
Its really simple.
EDIT: oh yea install equipment.
All you need are Wire connectors (eye) and 8 gauge wire.
Use a hammer, and flat tip screw driver, to securely attatch the wire connectors to the wire. Simply trying to squeez teh connector closed is will NOT make it secure enough. And you really dont want the Positive wire to fall off.
as for mounting the CAP itself, you can use some Pipe holder clamps. They fasten down around the cap and attach to a board or seat or metal or whatever.
Install kits usually run about 35 to 40 bucks. All the equipment in the kits (ie connector, wire, etc.) can be bought seperatly for less. Wire from a home imporvment store, and connectors from radiosshak.... whatever.
hope this helps, good luck
Sorry its late, and i cant remeber the name of shit. Im edit this later on.
EDIT 2: i think that paint pic deserves a Sticky.. haha... ummm ok nm
Old 10-30-2003, 12:24 PM   #6
thanks, that helps a lot.
so do i have to charge the cap before hand or not?
Prowler is offline
Old 10-30-2003, 12:30 PM   #7
Rep Power: 19 MaliWho97 is off the scale
Yes, the cap must be charged first to have full potential. I'd recommend going to their website and emailing their tech department before you try anything, some caps charge different than others. Use the recommended wire size that your amp uses, you can tell by the size of the power terminal on it. Run the power to the positive side of the amp, and from the positive to the amp, then run a single ground wire of the same gauge to a clean, bare metal sold chassis location, and try to keep the ground under 18 inches if possible... Keep the cap close to the amp, its more efficient that way. You can get the charge light or resistor, whatever they recommend, at radio shack. Hope this helps.
MaliWho97 is offline
Old 10-31-2003, 03:49 PM   #8
the reason you need to charge it is so that it doesn't charge instantly when you connect it. By charging it with a resistor, you effectively just charge it much more slowly, so that it can reach it's full potential without damaging any of the capacitor internals
&quot;Our enemies are innovative and resourceful, and so are we.
They never stop thinking about new ways to harm our country and our people, and neither do we.&quot;
Old 10-31-2003, 05:24 PM   #9
ok now i understand. SO YES.. charge the beast.
Old 11-19-2003, 11:15 PM   #10
Rep Power: 0 luder22 is off the scale
a capacitor is a short at low or 0 volts so if you connect a dead cap to a battery you might as well throw a crowbar across your battery because electrically its the same. charge the cap first monitor it with a voltmeter
luder22 is offline
Old 12-05-2003, 01:54 AM   #11
ok that makes sense... what should be used to slowly charge it?
Old 12-05-2003, 01:59 AM   #12
Rep Power: 59 hcivic.com is on a distinguished road
a resitor or bulb
hcivic.com is offline
Old 12-05-2003, 10:29 AM   #13
Originally posted by rudeludenotmeanthough+Dec 5 2003, 12:54 AM--><div class='quotetop'>QUOTE(rudeludenotm eanthough @ Dec 5 2003, 12:54 AM)</div><div class='quotemain'> <!--QuoteBegin-luder22@Nov 19 2003, 11:15 PM
ok that makes sense... what should be used to slowly charge it? [/b][/quote]
my local car audio place said it would just arch a little if not priorly charged, but the cap would charge fine anyways. and it did, i can notice quite a difference.
Prowler is offline
Old 12-05-2003, 08:04 PM   #14
nice to hear you got it done... got any pics of the install?
Old 12-05-2003, 08:49 PM   #15
CRX-YEM's Avatar
Ride:  91 CRX
Rep Power: 86 CRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud ofCRX-YEM has much to be proud of
Send a message via ICQ to CRX-YEM Send a message via AIM to CRX-YEM Send a message via Yahoo to CRX-YEM myspace  FaceBook
Um I can see there is a lot of mis information here.
A capacitor is not a dead short when it's not charged I can assure you that.
A capacitor is some material of some unit of area seperated by a dielectric. In theory the cap should have no resistance but in fact they do.
When a capacitor is connected to a voltage source it will charge to the source voltage instantaniously which can draw a lot of current (if it's avaliable). in the case of using a car battery to charge the cap the potential to draw upwards of 50 AMPS Quesent current is possible, which could easily be above the ratting of the wires you might be trying to use and in the end actually melt the wires.
So a safe way to charge the battery and to limit current would be to use a series resistor connected to the voltage source and then to the Cap and then connecting the circuit to slow down the charge cycle and limit the current.
Charge Time
T=R*C
T is in Seconds
R is in Ohms
C is in Farads
Imax=V/R
V is in volts
R is in Ohms
I is in Amps
Power=V^2/R
P is in Watts
V is in Volts
R is in Ohms
So to safely charge your capacitor I'd say no more than 1AMP is a good
rule of thumb as a 12 gauge wire will easily be able to carry an AMP
so if your using a car battery the source voltage is 12V. now lets see what resitor will limit your current draw to one AMP
Imax = 12V / 12 Ohms
the problem here is the power dissipated by the resistor is going to be quite high using P=V^2/R, 144/12= 12 Watts
so you'd need a 12 Ohms 12 Watt resistor to safely charge the cap. which won't be easy to come by.
so we need to be a little more conservative and use a larger resistor to lower the power which will increase charge time.
1/4Watt resistors are really easy to find so lets see what's avaliable.
P=.25, V=12, R=? : R=V^2/P : 144/.25 = 576 ohms so double the value and look for at least a 1Kohms 1/4 watt resistor.
The quiesant current that will be drawn at initial charge up will be
I=V/R , 12/1000 = .012 Amps or 12mA this is a much safer limit.
The total time to charge the cap will be
T=RC for one time constant and it take 5 time constants to charge a capacitor to 95% of the source voltage.
so you're looking at T=RC : 1000Ohms * 1 Farad = 1000 seconds
for one time constant so total charge time will be 5000 seconds or 1.4 hrs.
|-------+Bat -Bat------------|
The capcitors symbol the | side is positve
***** keep in mind do not hook this capacitor up backwards as it had to poles on positive and one negative, if you hook it up backwards you risk the chace of blowing it up *****
reference for symbols
Dennis
Buy my stuff plz...
Mondaswap For Sale - MPFI, 88-91 CRX, 92-95 Civic Parts
Please don't PM/Email/IM me for technical support. Make a Post!!!
91 CRX DX, 03 Civic EX
"There are 10 kinds of people in the world: those who get binary and those who don't."
"Of all my imaginary friends I don't think there was one I didn't end up having to kill"
CRX-YEM is offline
Old 12-06-2003, 10:13 AM   #16
i'll get a picture today or tomorrow. remind me on AIM.
Prowler is offline
Old 12-15-2003, 03:50 PM   #17
seanjuan's Avatar
Ride:  See sig.
Rep Power: 23 seanjuan is off the scale
Charge Time
T=R*C
T is in Seconds
R is in Ohms
C is in Farads
Imax=V/R
V is in volts
R is in Ohms
I is in Amps
Power=V^2/R
P is in Watts
V is in Volts
R is in Ohms
this should be stickied for real
sounds like a damn text book
and i bet no one knows that shit.... I didn't and I've had two years of college phyisics and one year of circuits.... but that was a few years ago so chances are I knew it but just forgot it <_<
'92 Civic LX - for auto-x
'03 Suzuki SV650 - for speed
'02 VW GTI 337 - for fun
seanjuan is offline
Old 12-15-2003, 04:15 PM   #18
CRX-YEM's Avatar
Ride:  91 CRX
thanks for the props, having 4 years of industrial electronics in high school, and studing physics, mechanics, electronics in college kind of helps and imbeds this stuff in your head.
Dennis
Buy my stuff plz...
CRX-YEM is offline
Old 12-15-2003, 08:33 PM   #19
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin  FaceBook
can you name all the numbers each color represents on a capacitor right quick? thank you!
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
K2e2vin is online now
Old 12-15-2003, 08:43 PM   #20
CRX-YEM's Avatar
Ride:  91 CRX
ok that's one color code I'd have to look up because almost all well 80-90% of em are marked like 103K (which would be 10uF) which is the IEC Code
but if I not mistaken capacitors use the same color code as resistors
which would be as follows
Black 0
Brown 1
Red 2
Orange 3
Yellow 4
Girls 5
Blue 6
Violet 7
Grey 8
White 9
an easy way to remember
Bad Boys Rape Our Young Girls But Violet Gives Willingly
Dennis
Buy my stuff plz...
CRX-YEM is offline
Old 12-15-2003, 09:28 PM   #21
Citizen_Insane's Avatar
Rep Power: 51 Citizen_Insane will become famous soon enough
Send a message via AIM to Citizen_Insane
Thumbs down
I learned that last year in AP Physics (in HS)!
No tech questions through PM please!
B16 CRX....you will be missed
Citizen_Insane is offline
Old 01-26-2004, 11:50 PM   #22
Rep Power: 14 SIRH22 is off the scale
Mad props to CRX-YEM.
SIRH22 is offline
Old 01-27-2004, 12:24 AM   #23
Rep Power: 14 Jim Truett is off the scale
Charge Time
T=R*C
T is in Seconds
R is in Ohms
C is in Farads
Imax=V/R
V is in volts
R is in Ohms
I is in Amps
Power=V^2/R
P is in Watts
V is in Volts
R is in Ohms
The quiescent current draw of that capacitor would be when it was fully charged, caused by the ESR (equivalent series resistance) of the capacitor. That term does not apply to a charging or discharging state.
Also a capacitor labeled 103k would be a .01uf 10% tolerance.
The capacitor, if manufactured properly, will have a vent. If it is installed backwards in a circuit at or below it's rated voltage it will not explode, but the boiling electrolyte will come spraying out of the vent.
Resistor color chart
Capacitors
2002 Civic Si
6 Speed RSX Type-S Trans
Lots of Overpriced JDM Crap
'94 LX Sedan
'95 Si Trans
JDM D15B force fed with 8 psi
<a href=\'http://www.ecimulti.org/uberdata/\' target=\'_blank\'>Uberdata</a>
<a href=\'http://www.k-series.com\' target=\'_blank\'>K-Series.com</a>
<a href=\'http://www.ephatch.com\' target=\'_blank\'>ephatch.com</a>
<a href=\'http://www.pgmfi.org\' target=\'_blank\'>pgmfi.org</a>
Jim Truett is offline
Old 01-28-2004, 04:36 AM   #24
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Originally posted by ktanaka+Dec 15 2003, 09:28 PM--><div class='quotetop'>QUOTE(ktanaka @ Dec 15 2003, 09:28 PM)</div><div class='quotemain'> <!--QuoteBegin-seanjuan@Dec 15 2003, 08:50 PM
I learned that last year in AP Physics (in HS)! [/b][/quote]
That was high school for me, along with freshman physics... and that was over 10 years ago (HS physics). I still remember that stuff, you should too!
Calesta is offline
Old 01-28-2004, 06:20 AM   #25
Ride:  1995 Civic EX coupe
Rep Power: 14 bcman is an unknown quantity at this point
QUOTE (liquid00meth @ Oct 28 2003, 05:13 PM)
Its really simple.
in that diagram, the cap is in parallel, not series. typo?
bcman is offline
Closed Thread
10 ohm capacitors p28 chipping??? thegreat1310 ECU's, Electronics, and Tuning 5 12-04-2005 02:11 PM
