alright so i have a 93 ex civic. I put in a aftermarket stereo and could not get a constant 12v source so for a while it kept having to reset everything on the stereo everytime i turned the car on. so i ran a wire from the battery to the stereo and now it keeps memory but it blew the fuse to the dash light so i went and bought new fuses and replaced it but everytime i do it just blows. does anyone know why this would be happening and if so please enlighten me and let me know what i need to do.
thanks all. -matt |
#2 | |
I wear stretchy pants
Ride: chevy s-10
looks like your shortening the illumination wire in the headunit. Its the orange and orangle/black.
Do you have a harness or did you just cut the factory harness? __________________
well im sure it would have made my life alot easier to buy the harness but i just cut the factory wires and did it that way. but yeah ill take a look at the orange wires and see if thats the problem. and if anyone else has any suggestions just let me know so i can check that while im at it. thanks guys
#4 | |
Ride: chevy s-10
do this. solder the origional harness back on. and go spend 25 dollars at best buy for the wiring harness. That way you dont get any wires mixed up. I know most of the times you cant tell wich one is positive anr neg. on the speaker wires.
then all you have to do is plug and play. Trust me man it will save you so much time and headaches. Especially when you go to put another cd player in. Do you have a multimeter or regular test light? __________________
#5 |
Honda Master Technician
Ride: 88 Prelude Si and a CBR 600 Hurricane
Either your illumination wire is shorted somewhere or it's hooked up wrong to the head unit. Try unplugging the head unit and see if the fuse still blows. If it doesn't then the problem most likely is in your wiring, and if it does blow still you most likely have a shorted wire somewhere in the illumination circuit.
Do not PM with tech questions without providing a link to your topic on the forums. This way everyone has access to the information.. |
| 2003 Accord Dome Light Fuse | jelecronin@comcast.net | Accord | 1 | 07-24-2006 05:47 PM |
| aftermarket tach. light dims when dash brightens | GSRCRXsi | ECU's, Electronics, and Tuning | 13 | 05-31-2006 10:45 PM |
| CEL and a blown fuse | Delsolcrazy | ECU's, Electronics, and Tuning | 2 | 05-04-2005 01:19 PM |
| Dash light problem | Blanco | ECU's, Electronics, and Tuning | 7 | 08-10-2004 02:03 AM |
| dome light fuse? | WannabeSI | General Tech and Maintenance | 0 | 03-01-2004 01:00 PM |
