#51 |
I still know everything
Ride: 89 CRX HF, 96 Accord EX, 88 Dodge Daytona Shelbyz T-tops
at home on my memory card
Formerly the.original.kermit Back from the dead... twice I NEED PARTS!!! http://hondaswap.com/parts-sale-trade-wanted/wtb-1989-crx-parts-161172/#post1079066 Check out my progress... http://hondaswap.com/auto-multi-media/my-1989-crx-project-144941/ |
#52 |
Fa-Q
If you have a repair manual they usually have pics in em of belts that need replaced, thatd be a good place to start. Otherwise, look for things like cracks, torn edges, or fraying edges. If non of that is goin on, just rub it down with some wax and youll be good to go.
#53 | |
Unless the belt is loose, just replace it, it's only like $8-12 bucks.
#54 |
Is Girl Aggressive
You don't know my car very well then lol. Everything should be replaced cuz as soon as you even think of a part, it breaks.
#55 | |
Fa-Q
#56 |
Is Girl Aggressive
You can also use bar soap, or so I've been told.
Yeah, I just checked and it actually doesn't look all that bad.
#57 |
Fa-Q
Ooo, good call. I've heard the same, but never think of it. If youve got a bar of soap handy try it out. Not like its gunna hurt anything.
#58 |
Is Girl Aggressive
Well, it doesn't squeak constantly. Only every so often. Fuck if I know why though. Anyway, since it doesn't look so bad, I wonder what could be causing the weird electrical things. I haven't checked yet, but I'm pretty sure my voltage is probably off too.
#59 |
Fa-Q
Your alternator should put out a constant flow of 13.7-14.7 volts before the voltage regulator.
Personally Id start with grounds, thats what the problems sound like to me, having experienced similar thigns myself (and fixed them myself as well). But, if thats not the problem, and the alternator passes, Id go on to the voltage regulator. If none of that is the problem, you might check for worn wires. I just look for wires that visually dont look good, or wires that feel hot. When your feeling the wires its very easy to tell rather the wire is absorbing ambient heat or generating its own. Wires creating heat deffinitly need replaced quickly. The easiest thing to do is go to Auto Zone or Schucks and have em run their free charging system check. Thatll at least give you a good starting point. Also, improper power levels will make electronics do weird things some times. This may be all thats goin on with your CD player.
Locate approximately as shown "I'm a bad man." -Cassius Clay Last edited by newb; 08-14-2008 at 03:06 PM. |
#60 |
Is Girl Aggressive
Yeah, that's what I thought. Well, I have one day off this week, guess I'll be checking wires and voltage levels.....any more ideas, just in case?
#63 |
Yes my wife is Hotttttt
Ride: chevy s-10
whining/ Buzzing is caused by a bad ground in the audio ground. Its rarely present when only a cd player is installed. Its common when amplifing to the highs and mids. The noise you hear is the alternator/ engine noise.
take the deck out. remove the ground and clean it up. If its hooked up to the harness, it prolly is. Disconnect and ground it directly to the chassis by securing it with a o ring.
yo, yo ,yo wuz up! |
#64 |
Is Girl Aggressive
Too late now, my old CRX is gone lol. I just posted a thread tonight on the new one I got. Thanks though!
(It's someone else's problem now.... )
#65 |
Ride: chevy s-10
what brand cd player is it? ohh and cd cleaners dont do shit, waste of money.
cheap cd players do funny things you know............
