Doc Brown says
Ride: 04 Civic LX Coupe...(it's Blue)
I hope I can get some good ideas out of this. I thought it would be totally bithchin if the screen I want to put into my trunk could also have a touch-screen overlay that would control a windows based media center that uses touch icons. There is such a program, that much I know.
The tricky part comes in where I want to use either a Playstation 2 or XBox 360 and have it double as a PC for the purpose of running said application. How do you make a gaming console run a computer program? Someone told me that you can use Linux on a PS2. If anyone has any bright ideas that'd be killer dbadct@hotmail.com ![]() |
#3 | |
...PENDEJO....
Ride: bagged Ford Ranger Splash
id think that the Xbox 360 would be better suited to serve as a pc rather than a PS2. there is a mobile pc system you can get but i dont know the name of it. google up "mobile pc" and see what you can find.
***Please leave this section blank. For office use only.*** -BrianE. 1995 Ford Ranger Splash 2009 Ford Focus http://midwestminis.forumotion.com/forum.htm Quote:
#7 |
Doc Brown says
the problem with doing it that way is that i'm going to be having almost everything "touch-screen". So being able to switch over to games at the touch of a finger on the screen would look pretty slick in actual operation. That's my whole thing about running just a media center off a console, plus i already have a load of console games
#8 |
Ride: The Fit is go! ^^'
This might help somewhat. TechBuilder | How to Turn an Xbox Into a $150 Linux PC
#9 | |
FALCON PUNCH!!!
In all honesty, you'd do best running an actual PC instead of a console. More choices for games plus all the apps will run flawlessly. Linux is an excellent choice, there are plenty of frontends for media centers. If you want to get *REALLY* slick, you can use MythTV. Have a backend at home, then use a mobile carrier for wireless broadband (not wifi) and stream to your car. Digital cable/Satellite in your car = teh sex. Not to mention having all of your DVDs and recorded shows at your fingertips. __________________
lrwxrwxrwx 1 root root 9 2007-09-24 10:32 /dev/thisissparta -> /dev/null |
#10 |
Doc Brown says
I found the solution to all my woes.... after a lot of Gooooooooogling and tired fingers... I found something that I think is the be all and end all of coolhttp://www.infill.co.kr/eng/products/T3.asp Look under Gallery and then after looking under Specs.... I see it has monitor support, S/PDIF PCM, and a whole list of other goodies and i can order it from mp3car.com | your source for mobile computing solutions Mp3Car.com Custom car computers and parts! I MUST HAVE IT!!!!!!!!!!!!!! Plus it looks slick as Eel snot in the dash. Things got brushed aluminum trim... tres sexy. __________________
"CUSTOM" DOES NOT MEAN IT COMES PREPACKAGED
#11 |
Doc Brown says
..... and just in case anyone wondered how you get sound to your amps:
you use a fiber optic cable and run it to a Clarion DVH-940 5.1 Processor Voila! TRUE 5.1 sound. And for added convenience, Clarion also makes a Half-DIN center channel speaker ....Now all I need to do is rob a bank ![]() __________________
| EF Hatch Lower Console/Audio Console | VegasEFHB | Body / Exterior / Interior / Cosmetics | 0 | 06-18-2006 08:29 PM |
| New gaming console? | Wycked Sniper | Members' Lounge | 1 | 01-16-2004 06:22 PM |
| Double Clutching while drag racing? | awitron | Racing and Driving Techniques | 19 | 08-14-2003 07:10 PM |
| Double Clutching - Put To Rest | tdehnel | Racing and Driving Techniques | 25 | 07-01-2003 11:40 PM |
| What is double clutching? | Calesta | General Tech Articles | 0 | 12-27-2002 03:06 PM |
