Go Back   HondaSwap Forums > Appearance and Accessories > Car Audio / Security / Electronic Accessories
harness problem
Old 09-20-2009, 06:58 PM   #1
Ride:  95 civic dx f22b
Rep Power: 5 zap45 is on a distinguished road
Default harness problem
i have 3 cd players that if you tested them to a 12v battery they would work fine. But if you wired them to my car thru a aftermarket civic harness they do come on at all.
I test the aftermarket harness with a test light only the red wire get power the ground and yellow connector of the harness does not. but when i coonect my stock civic radio directly to my stock harness it works fine. btw the i have two aftermarket harness that have the same problem. Any help?
zap45 is offline   Reply With Quote
Old 09-20-2009, 09:02 PM   #2
any suggestions
Old 09-22-2009, 10:48 PM   #3
I wear stretchy pants
Taco15's Avatar
Ride:  chevy s-10
Rep Power: 217 Taco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
Taco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
myspace
what year civic and what model?
It seems you have the wrong harness. It obvious the factory harness it doing the job right if it powers up the factory radio.
go get the right harness and plug it in. If the supplier insists it the right harness either have them install it or ask for the instructions. Many times like the newer GM models you need to run a seperate constant + volt supply for a some harnesses.
keep us updated
Its fashion man. The chicks you see walking down the runway dont wear practical clothes, they were something that was designed to make a statement. THat statement in turns influences and shapes other peoples designs and ideas.
Same thing with cars. Except with no attractive women... and a lot more gayness.
Taco15 is offline   Reply With Quote
Old 09-23-2009, 04:33 AM   #4
dateg513's Avatar
Ride:  dc integra rs black and dc ls integra white
Rep Power: 1 dateg513 is on a distinguished road
dudes right i had a crx i used a teg harness on and had same prob then my 01 impala i had to do same thing
dateg513 is offline   Reply With Quote
Old 09-24-2009, 12:35 AM   #5
well i got the harness that plug 86 thru 95 civic plug right in to the factory harness.
it use to work perfect before i install a dvd player. maybe a broke a ground. how would i fix this problem
Old 09-24-2009, 09:32 AM   #6
Taco15's Avatar
Ride:  chevy s-10
myspace
take the wire from the cd player and ground it directly to the chassis. thats if you didnt damage the pin inside the radio harness.
Old 09-24-2009, 09:33 AM   #7
Taco15's Avatar
Ride:  chevy s-10
myspace
you really need to take a volt meter and test your yellow/red/black to see if its working right.
Old 09-24-2009, 01:32 PM   #8
i took a test light and turnt the key only the red light up but yellow and black(ground) dont through the aftermarket harness
Old 09-24-2009, 05:08 PM   #9
Taco15's Avatar
Ride:  chevy s-10
myspace
did you have the red grounded with the dround from the harness?
looks like you might have a fuse out. If not just run a constant wire from the fuse box to the radio and have it fused with a 10amp.
Old 09-25-2009, 12:21 AM   #10
no. im not getting a power from the yellow wire through the harness or no power from the ground either. just from the red. what fuse do i check for under the dash under the hood
Old 09-25-2009, 09:49 AM   #11
Taco15's Avatar
Ride:  chevy s-10
myspace
the fuses are marked on the removal panel. It going to be a 10am fuse.
just to be clear. When you touch the ground wire and the yellow wire with your meter AT THE SAME TIME you get nothing right?
And when you touched the ground wire and red AT THE SAME TIME with your meter you get nothing also?
BUT If you touch A ground source with your meter and the other to the red you get voltage. the yellow doesnt.
its your fuse.
however i find it strange your ground got yanked out somewhere. Thats the easiest one. just drive a self tapper into the chassis for a new ground wire.
Old 09-27-2009, 05:01 PM   #12
ok i will try all of your suggestions thanks for the hints
Old 10-05-2009, 12:24 PM   #13
ok found the prob blown fuse under the hood thanks for your help
wiring harness problem kambosoup HYBRID -> ED-EF / DA 44 11-09-2008 11:49 PM
2000 LS with gsr engine - harness problem bigg86 Integra 3 01-02-2008 11:35 PM
OBD1 harness problem silverboost HYBRID -> EG-EK / DC 0 01-16-2006 08:51 PM
Wiring Harness Problem with Swap delMar HYBRID -> EG-EK / DC 3 08-17-2004 12:58 PM
Wire Harness Problem SIR-T ECU's, Electronics, and Tuning 1 01-24-2003 11:16 AM
