#26 |
I still know everything
Ride: 89 CRX HF, 96 Accord EX, 88 Dodge Daytona Shelbyz T-tops
Considering there really is no topic, it's hard to stay on one.
And we did help him, we told him to fix his ground wire and then to see what happens.
Formerly the.original.kermit Back from the dead... twice I NEED PARTS!!! http://hondaswap.com/parts-sale-trade-wanted/wtb-1989-crx-parts-161172/#post1079066 Check out my progress... http://hondaswap.com/auto-multi-media/my-1989-crx-project-144941/ |
#27 |
the reason he is melting fuses is because his inline fuse is bigger than the fuse in the amp. He has the amp wired down further than it is supposed to be and thus overheating the amp which is not only blowing but melting the fuse. If he had the correct fuse inline it wouldnt be a problem because it would blow that fuse first if he was drawing to much current like he currently is doing.
#28 | |
#29 |
ummmmmm wrong it is supposed to be equal to the rating of all combined fuses in the amps that your running. ie if you have two amps one has a 30 amp fuse and one has a 20 amp fuse you should have a 50 amp fuse inline. if your giving out advice like this i wouldn't let you mow my lawn.
#30 |
My name is Byron.
Ride: `89 DX Hatch w/JDM B16
I havent been driving the car lately, and I havent done anything with it yet, but Im going to go with what people have been saying. Smaller inline fuse, bigger ground wire.
Dont PM me with tech questions. I will not answer them. Looking for a P28 and B-series turbo parts, PM me. |
#31 | |
#32 |
#34 |
Well thought that was kinda self explanitory. The amps required by your system is on the left. You pick your wire gauge based on that. The current (amps) that travels through the wire to the amp must pass through the inline fuse. If you don't run a big enough inline fuse, then you are going to blow the fuse before you reach the maximum current that is allowed through the wire.
I'll take my cookie now bitch.
#35 |
If your amp uses 50a fuses, then put a 55a or 60a inline fuse as close to the battery as possible. I would just use the same size fuse or just slightly bigger.
#36 |
Resident Fat Ass
Ride: 90 Hatch, 91 Rex, 85 Yamaha Virago, 82 CB900F Supersport
He only THINKS he knows everything. Unlike his title, most of us know the difference.
Neonmike, don't you do this stuff for a living, or have done it as a means of livelihood before? |
#38 |
Carless
Ride: Deciding...
Well I hate to burst some bubbles, but the inline fuse doesn't necessarily have to be bigger or equal to the amp's fusing. If you have an amp fused at 50A and put a 100A fuse on it or if you're running an amp fused at 50A and use a 40A fuse, you're not putting your amp in danger. The only consequence of having a fuse too small is that the amp can pull more current than the fuse is designed for, and pop it. It won't harm the amp, but could be annoying.
The purpose of the fuse under the hood is to protect your battery, alternator, and the rest of your electrical system. If your power wire's jacket is worn through, and the wire grounds out, the fuse under the hood protects your electrical system. The fuses on your amp, on the other hand, are to protect your amp from a short. Again, in the event of a short, the fuses will pop. Another reason amp fuses pop is that your amp is pulling more current than it is designed for. This is often caused by wiring the amp to an ohm load lower than what it is designed for, or cranking the gains to the point that the amp is forced into clipping. One other reason amp fuses pop is that an internal component of the amp has burned out and is causing a short circuit.
"It's better to be pissed off than pissed on." Last edited by jmanpc; 08-20-2008 at 04:31 PM. |
#39 | |
#40 | |
Carless
Ride: Deciding...
"It's better to be pissed off than pissed on." |
#41 |
ok so your sayin that i have an amp with a 30 amp fuse in it it is ok to put a 100 amp fuse in the front? If that is the case why do they make all the different size fuses for the inline holders, why don't they just sell a 200 amp fuse for up front for every single amp kit ever produced. thats right cause it is supposed to match with the amperage you have with all the amplifiers you have added up.
#43 | |
#44 | |
Carless
Ride: Deciding...
