Go Back   HondaSwap Forums > Appearance and Accessories > Car Audio / Security / Electronic Accessories
Need Pro Advice
Old 11-12-2005, 04:02 PM   #1
Rep Power: 10 Joka is off the scale
Ok, I have a 91 Crx Hf, When i bought the car it had no radio and no plugs. All the original shit was ripped out and there are no wires anywhere.
I want to go buy a Cd player today and put it in but after buying the harness and plugging everything back into the headunit where do I plug the extra plugs too? There is none, So how do I run the HEadunit with no factory wires. Clock also doesnt work those wires were pulled too. Can i run all my wires from an amp?
Joka is offline   Reply With Quote
Old 11-12-2005, 07:47 PM   #2
neonmike's Avatar
Rep Power: 65 neonmike has a reputation beyond repute
neonmike has a reputation beyond reputeneonmike has a reputation beyond reputeneonmike has a reputation beyond reputeneonmike has a reputation beyond reputeneonmike has a reputation beyond repute
Send a message via AIM to neonmike
so there are no wires at all in the car ?
neonmike is offline   Reply With Quote
Old 11-13-2005, 02:33 PM   #3
<div class='quotetop'>QUOTE(neonmike @ Nov 12 2005, 07:47 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Correct, Atleast none behind where the headunit should go (usally theres a big plug and antenna) and theres nothing but im tired of driving down the road with no music.
Old 11-13-2005, 06:20 PM   #4
neonmike's Avatar
well if there are no wires at all your best bet would be to run the power wires from the fuse box for the conbstant and the accessory wires, find a good spot to use for a ground and then run speaker wires to the speakers. that is the easiest and only way pretty much to do it.
Old 11-13-2005, 07:09 PM   #5
Rep Power: 59 hcivic.com is on a distinguished road
Are thert cut wires at all ?
if not you need to rerun alkl the wires
hcivic.com is offline   Reply With Quote
Old 11-13-2005, 07:11 PM   #6
No wires at all, Not even cut. I think im going to do what mike said and see how it comes out.
Old 11-17-2005, 11:56 AM   #7
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 338 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
www.installdr.com
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 11-17-2005, 11:45 PM   #8
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
<div class='quotetop'>QUOTE(Joka @ Nov 13 2005, 06:11 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
It's easy. Your red is typically the switched power (accessory power wire), yellow is usually the constant power, black is ground, and blue is amplifier turn on or power antenna activation. Run all your own speaker wires- it'll sound better if you run decent quality large gauge wire. Considering that the car is almost 15 years old, putting in all new wire is generally a good idea anyway.
Old 11-20-2005, 10:26 PM   #9
tab
Ride:  03 Avalanche
Rep Power: 51 tab is on a distinguished road
Send a message via MSN to tab
<div class='quotetop'>QUOTE(Calesta @ Nov 17 2005, 11:45 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
[/b][/quote]
[img]style_emoticons/<#EMO_DIR#>/werd.gif[/img]
2003 Chevy Avalanche
Leather, Moonroof, Z71, tow package, bose+six disc, nice.
1992 Accord EX (sold to good friends)
JDM H22A
H22A Auto Tranny w/LSD
I/H/E -- All stainless w/2.5 inch Catback
1968 Oldsmobile Toronado
Project car, 455 ci front wheel drive, nasty.
Old 11-21-2005, 04:28 PM   #10
neonmike's Avatar
<div class='quotetop'>QUOTE(tab @ Nov 20 2005, 10:26 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
[/b][/quote]
[/b][/quote]
yes those colors are only the colors of the aftermarket headunit. they do not match up color to colr in the car itself
Old 11-21-2005, 05:02 PM   #11
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 413 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
Option 1: Get a new dash harness, swap it, and call it a day
Option 2: Wire everything up manually.
The hard one will be illumination. Other than that, everything is pretty simple. You have to have wires in there somewhere, dig until you find them, or where they were cut. You'll need to tape them off anyway to keep fuses from blowing.
*edit*
Honda's factory stereo wiring is a joke anyway, UBER thin everything. power, ground, speakers, everything is way too damned thin.
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
