Go Back   HondaSwap Forums > Appearance and Accessories > Car Audio / Security / Electronic Accessories
subs cut out at high volume
Old 06-19-2009, 08:33 PM   #1
System Failure Racing
Ride:  91 Accord LX H22A, 94 Silverado C1500 350, 95 Chevy Blazer 4.3 CPI
Rep Power: 7 calmfornow is on a distinguished road
myspace
Default subs cut out at high volume
ok i have 1 12 inch audiopipe competition sub 1000w rms 2000w peak and my amp is a pyle 1200w rms and 2400w peak......it hits really hard but when i crank my volume up pretty high the bass cuts out and comes back on but it is fine if i turn it down...i was told its because the amp is to high on the gain but i did turn it down and it didnt fix the problem it also has a 3 farad cap and my headlight dim still pretty badly.....any real answers would be great thank you
i know its a pyle but it shouldnt freak out like this
Variable valve Timing and lift with Electronic Control
Its VTEC not VTECH, VTECH is a worthless chordless phone
calmfornow is offline   Reply With Quote
Old 06-19-2009, 08:38 PM   #2
Greenhorn
Rep Power: 0 90minime is on a distinguished road
i would say from my experiences with that...alternator, mine did that and it was that the alternator was bad it just couldnt handle that, i bought a bigger alternator and it was fine.
also if you 1200rms on your amp and 1000rms on sub you dont want to turn your gain up all the way anyways....cept since its a lower brand amp the wattage isnt exact
90minime is offline   Reply With Quote
Old 06-19-2009, 08:38 PM   #3
Gonzo Scientist
TommyTheCat's Avatar
Ride:  96 Ford Escort
Rep Power: 36 TommyTheCat is a glorious beacon of lightTommyTheCat is a glorious beacon of lightTommyTheCat is a glorious beacon of lightTommyTheCat is a glorious beacon of lightTommyTheCat is a glorious beacon of light
Any led indicators on the amp so you could know whether its the amp shutting down? It could also be a loose wire in the box - you could check for a solid connection (not super loose, but it could short or something weird).
Tommythecat had many a story to tell, but it was a rare occasion, such as this, that he did.
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
http://www.woostercollective.com/
TommyTheCat is offline   Reply With Quote
Old 06-19-2009, 08:49 PM   #4
Greenhorn
oh yeah and if you have a cheap wiring kit with the big fuses i have had problems with those shorting and just getting loose so i would check that if so
Old 06-19-2009, 09:09 PM   #5
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 413 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
Make sure it is grounded very very well. Make sure the power wire is big enough for the amp, as is the fuse.. Is the amp getting hot and shutting down or is it just cutting instantly when you turn it up? Is the capacitor located near the amp and well connected? Decent capacitor or egay special?
My vote is crappy ground..
Could be a weak battery too, if your headlights are dimming through the capacitor..
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
Old 06-19-2009, 09:20 PM   #6
old sckool enthusiast
OGMatt's Avatar
Ride:  89' CRX Si
Rep Power: 47 OGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant futureOGMatt has a brilliant future
My friends dose this all the time! It's the amps peek protector. It's so your amp dosn't blow up. The amp co. put it there for a reson and I don't think you can take it off.
shaved sig
OGMatt is offline   Reply With Quote
Old 06-23-2009, 04:41 PM   #7
2265787829
2000Si's Avatar
Ride:  Refer to my name, dumbass.
Rep Power: 285 2000Si has a reputation beyond repute2000Si has a reputation beyond repute
2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute
Mine does this a lot especially when its hot outside. The amp is cutting itself off. Time to upgrade it.
XBL: jams 8201 (14,580G)
Lego Sears Tower: 82 stories/75.9% complete
CL2, CL3, CL4, CL5, CL6, Car, Mortgage
Originally Posted by eg6sir View Post
yea.. but aren't you spaghetti noodles covered in skin?
2000Si is offline   Reply With Quote
Old 06-23-2009, 04:49 PM   #8
CAFROG's Avatar
Ride:  '92 Hatch si w/B16 (wannabe EG6)
Rep Power: 26 CAFROG is a splendid one to beholdCAFROG is a splendid one to beholdCAFROG is a splendid one to beholdCAFROG is a splendid one to beholdCAFROG is a splendid one to beholdCAFROG is a splendid one to behold
PYLE of ????? Its shutting down b/c its overloaded (safety switch) Might be a wiring issue but it seems to be the amp is overloaded and you're trying to get too much out of it. Raise your gain on mid's-high's and just sacrifice some lows.
CAFROG is offline   Reply With Quote
Old 06-23-2009, 05:55 PM   #9
yep....mmhhm.......yep...
DESPAIN's Avatar
Ride:  92 PRELUDE SI
Rep Power: 83 DESPAIN has a reputation beyond repute
DESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond repute
Send a message via Yahoo to DESPAIN myspace
Originally Posted by ogmatt View Post
my friends dose this all the time! It's the amps peek protector. It's so your amp dosn't blow up. The amp co. Put it there for a reson and i don't think you can take it off.
yep this is what it is!!!! Mine used to do that all the time
Hugh.......I like money.......
"idiocracey"
Originally Posted by DarkHand View Post
Strippers eh? That'll get you a good view of the elusive pink snapper, but don't try to catch the ones around there, they usually have parasites.
Originally Posted by phyregod View Post
Probably waiting on an equipment upgrade.
"This tower runs hondaswap, Those 14 racks over there run the GF pic threads"
DESPAIN is offline   Reply With Quote
Old 06-24-2009, 01:01 AM   #10
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 546 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
sounds like either clipping protection or thermal protection
heres a few things that might help:
turn your gains down
upgrade your wiring
get a better amp
МОΛΏΝ ΛΑΒΈ
Old 06-24-2009, 04:31 AM   #11
CAFROG's Avatar
probably thermo....I guess its better then when i was in high school and if you didn't pay attention to your stuff....it would just blow....no shut off....just gone forever lol and head units were $500-1200 for something that controlled a changer and had two pre-outs...if you're lucky
"Meow, you know how fast your were going back there?"
http://hondaswap.com/hybrid-eg-ek-dc...si-b16-286581/
Old 06-24-2009, 09:14 AM   #12
I wear stretchy pants
Taco15's Avatar
Ride:  chevy s-10
Rep Power: 217 Taco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
Taco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
myspace
i was going to say clipping but after i read the low voltage im going to have to say you need a better battery. turn the gains down and the bass down to 0 on you head unit. then try it.
when lights dim its time for a stronger battery.
and yes Pyle is the biggest problem you have. Go get a good brand amp man.
Its fashion man. The chicks you see walking down the runway dont wear practical clothes, they were something that was designed to make a statement. THat statement in turns influences and shapes other peoples designs and ideas.
Same thing with cars. Except with no attractive women... and a lot more gayness.
Taco15 is offline   Reply With Quote
Aem high volume fuel rail civic si 99-00 b16 red 25-103 RSS-Bot Auctions 0 03-01-2009 10:17 PM
Aem high volume fuel rail civic si 99-00 b16 red 25-103 RSS-Bot Auctions 0 02-01-2009 11:36 PM
Aem high volume fuel rail civic si 99-00 b16 red 25-103 RSS-Bot Auctions 0 12-22-2008 12:03 AM
Aem high volume fuel rail civic si 99-00 b16 red 25-103 RSS-Bot Auctions 0 11-23-2008 10:03 PM
F/s : Aem High Volume Fuel Rail Havok Parts: For Sale/Trade/Wanted 1 06-15-2003 12:36 PM
