Ok this might sound a little weird but here is my question. I want to install some neon lights in various places of my car and I don’t want to always be looking for somewhere to tap in for power and then have to go and run a new switch and etc. So here is my little idea. Can I just run 8Ga wire straight from my battery and then connect it to a power distributor and then input all my neons into that block since all they neons only need 12v sources and the most neons I would install would be 8 also it will be clean and fused. Then from there all I would need are clean grounds and that isn’t hard. So I am asking all the wiring or electrician experts, is this a safe and good way to wire like 6-8 neons. Also if this aint a good idea or someone has a better idea or know of any sites that has good info or how- to that would greatly be appreciated. Thanks
Not sure if it would interest you, but the last time I was looking around at Autozone they had an item that was pretty cool. It worked exactly the same as you're saying except it came with a block that had a touchpad. The block was designed for most of your 12 volt accessories today (non terminated ends). Most of the stuff I run into simply has open wires (ground & positive). The Autozone deal held like 6 accessories I think (simply push the button to insert wires), and the touchpad has numbers to turn on whichever you chose. I thought it would make for a clean install. Just my opinion, hope it helps.
![]() __________________
"Better to be judged by 12 than carried by 6" |
btw dude, if you can't find that part at autozone, the way you described will work fine, as long as everything is fused properly etc- you seem to have a good grasp on wiring by the way you wrote the question- so good luck
#5 |
as a safety precaution, make sure that the combined amperages of the neons isn't more than the fuse your using and more than the amps going through the wiring from the batt- check using the meter-
| NickQ engine bay Cleanup. Full write-up. | Ryan Autry | Members' Lounge | 29 | 03-18-2005 12:09 AM |
| hey some wiring help plz | 96lxb18c1 | HYBRID -> BA-BB /CA-CD | 1 | 06-09-2004 01:01 AM |
| DPFI to MPFI Wiring HELP!! | peanut | HYBRID -> ED-EF / DA | 2 | 11-28-2003 03:20 PM |
| WIRING PROBLEM!!! | vinnie | HYBRID -> EG-EK / DC | 1 | 10-25-2003 12:57 PM |
| which wiring to use? | wannaberacer | HYBRID -> ED-EF / DA | 1 | 07-02-2003 06:18 PM |
