1990 Civic Si rear disc swap
Old 07-06-2008, 12:05 AM   #1
Drives Like Gramps...
bwaynep's Avatar
Ride:  1990 Honda Civic Si, low, loud, slow(ish), old, and dirty...
Rep Power: 5 bwaynep is on a distinguished road
myspace
Question 1990 Civic Si rear disc swap
I've searched ... and most of what I've seen has to do with a rear disc swap for a Crx. I just picked up the full rear trailing arm and hubs from a Crx Si. I know I'll need new lines but I'm unsure as to which model they should come from, DA (2 or 4 door?) or Crx Si? I'm planning on getting a DA master cylinder and booster because my stock one is starting to go out.
Am I missing anything?
Thanks for your input, HondaSwap is the spot!
bwaynep is offline   Reply With Quote
Old 07-06-2008, 01:23 AM   #2
I'll be back...
B16RacerN2NR's Avatar
Ride:  06 Mazda 5, 91 Civic DX
Rep Power: 156 B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
OK, i'm assuming this is going on an Si hatch so...
Get the lines for a 91 CRX Si (but I do think the lines for a DA teg are the exact same part number) Also, did you get the e-brake cables? You'll need the cables from a DA teg, 2 door. The four doors ones are too long and the CRX ones are too short.
Also, unless your booster is in need of being changed, I suggest leaving the stock booster on and just run the 15/16 master cylinder from a 91 Civic EX. It bolts directly to your stock booster and the spots for the fluid lines are in the exact same position as the master on your car right now. But if you really need the booster to be changed also, then obviously it would be worth going for the teg master and booster.
As a matter of fact, my cousin has a ITR booster w/ master cylinder for sale. If you're interested, send me a PM. I'm sure he'll let it go for pretty cheap. Good Luck
Real Eyes Realize Real Lies
B16RacerN2NR is offline   Reply With Quote
Old 07-06-2008, 01:57 AM   #3
bwaynep's Avatar
myspace
Thanks for the quick response. I'll shoot you a pm if I decide to go with the Integra booster/MC.
Old 07-06-2008, 02:12 AM   #4
I'll be back...
No problem... Also, get the 40/40 proportioning valve from a DA Teg. Make sure it's non-abs. 2 door or 4 door, it doesn't matter...
rear disc swap Triton83 Civic and del Sol - EG and EK 1 09-17-2007 10:20 PM
89 Civic Rear disc swap chevypartsgetter Wheels / Suspension / Tires / Brakes 1 01-06-2007 04:30 PM
WTB rear disc swap for 00 ek Nix Parts: For Sale/Trade/Wanted 0 08-21-2006 12:39 AM
F/S: 92-95 Civic rear disc swap civic92jak Parts: For Sale/Trade/Wanted 3 05-05-2005 01:57 PM
2001 honda civic lx rear drum to disc swap ?? cilvicman Wheels / Suspension / Tires / Brakes 2 08-08-2003 12:24 AM
