1991 Honda Civic Zc problems
Old 06-29-2009, 12:48 AM   #1
Rep Power: 1 intheearlyhours is on a distinguished road
Default 1991 Honda Civic Zc problems
Yo, i got a 91 hatch with a JDM ZC motor in it and here is the problem im having. My car is backfiring and running really bad and i already got new plugs and wires did the timing and everything the is involed with timing. I advanced the dizzy all the way and it fixed it for a couple days. I cant think of what it is. Valves maybe i dont know please help.
intheearlyhours is offline   Reply With Quote
Old 06-29-2009, 02:50 AM   #2
CAFROG's Avatar
Ride:  '92 Hatch si w/B16 (wannabe EG6)
Rep Power: 26 CAFROG is a splendid one to beholdCAFROG is a splendid one to beholdCAFROG is a splendid one to beholdCAFROG is a splendid one to beholdCAFROG is a splendid one to beholdCAFROG is a splendid one to behold
Any CEL's? When does it make these burps and back fires? At idle?
Give as much info as possible and make sure to add something tomorrow (reply) when more
people are on the site and it can be put to the top of the new posts
"Meow, you know how fast your were going back there?"
http://hondaswap.com/hybrid-eg-ek-dc...si-b16-286581/
CAFROG is offline   Reply With Quote
Old 06-29-2009, 11:39 AM   #3
it backfires pretty much all the time. more when i hit the gas. im not super good with cars so im not sure what alot of shit is called yet. Uhm i also made sure that the firing order was correct. 1342. i might be able to take a video of it making the noise when its sitting in a parking spot if i can get some help.
Old 06-29-2009, 11:40 AM   #4
oh and no check engine light
Old 06-29-2009, 07:26 PM   #5
pappaj's Avatar
Ride:  89 CRX SI (LS)
Rep Power: 5 pappaj is on a distinguished road
you need to double check your crank and camshaft timing.
how is the fuel mileage?
maybe your injectors are leaky
pappaj is offline   Reply With Quote
Old 06-29-2009, 10:57 PM   #6
ok ill double check the timing the fuel mileage seemed bad after i advanced the dizzy but not super bad, how to i check for leaky injectors an easy way lol.
Old 06-30-2009, 09:13 AM   #7
jlicrx's Avatar
are you sure that the spark plug wires are in the correct locations on the distributor cap? - the DOHC ZC is not the same as SOHC
SOHC:
3 4
1 2
DOHC:
1 3
2 4
like this:
ZCspeed Racing
Old 06-30-2009, 10:15 AM   #8
Yeah I'm sure the wiring is right. I actually used that picture to check a week ago. Lol
Old 06-30-2009, 11:48 AM   #9
ok i took a short video and for some reason it cut out the part when im under the hood but ill post it anyways. Uhh turn your volume up cause the mic is quite.
Qik | intheearlyhours | tsdedst
Old 07-02-2009, 01:09 PM   #10
Why does everyone give up on my threads so fast. i get like one reply and then nothing lol. Anyone know a more active forum?
Old 07-03-2009, 12:43 PM   #11
Ride:  90 crx w/zc dohc
Rep Power: 8 Fernpatch has a spectacular aura aboutFernpatch has a spectacular aura aboutFernpatch has a spectacular aura about
myspace
what distributor are you running? Have you moved the cam position sensor at all? I had a problem like that about a year ago and it was an electrical problem with a splice under the intake manifold. If I can remember more details i will post again later.
What I write is my own opinion based on what I have done. Your own results may vary...
"Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you." --Anonymous
Fernpatch is offline   Reply With Quote
honda b18 computer problems fatfives General Tech and Maintenance 2 12-06-2008 01:01 PM
Honda Accord problems 240king General Tech and Maintenance 2 06-16-2008 06:16 PM
B18B1 problems tranny problems... Clutch maybe? office888 HYBRID -> ED-EF / DA 4 07-26-2006 09:02 AM
HONDA IDLE PROBLEMS 92-95 CIVIC FamilyD General Tech and Maintenance 0 05-14-2004 11:07 PM
Engine Problems with 88 honda accord mwasnp General Tech and Maintenance 1 09-24-2003 05:13 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
