88 civic STD HB Turbo'in it ?
Old 11-17-2006, 02:04 PM   #1
2 SLOW CREW
fasterimage's Avatar
Ride:  88 Hatch and a harley
Rep Power: 8 fasterimage is on a distinguished road
Send a message via AIM to fasterimage
Default 88 civic STD HB Turbo'in it ?
I am turbo'in my 1988 Honda Civic HB STD D15 stock motor with a 4spd tranny! Well guys I cant afford a motor swap just yet and a friend of mine had a RB5 Vj11 left over from his probe and a JRC front mount.....we started messing around with the idea and got to work on it....got all the pipes mandrel bent and everything in place! Started it one day and took it for a drive! Everything worked well and we made two pounds of boost on the stock wategated turbo! Just added a MBC today and turned the boost upto 4lbs and everything still worked great! Decided we would go a bit more and turned to 7lbs of boost! I am running a stock ECU and no fuel management! I know thats bad...but a custom fuel management is in the works with Saab Cold start injectors and a device we made to turn them on! aside from that....the problem I am having is blowing the Charge pipes off! even when we clamp the crap out of them they blow off.....but not while on the throttle! we can boost and run fine....minus like a miss from lack of fuel.....but the minute I release throttle they blow off. I cant quiet figure out why there blowing off when i let off and not while its under load? I am running a 1g DSM BOV and I think that that may be the problem that it isnt releasing? could i be rite? please help or throw in some input? thanx Chris*
2 Slow Crew Racing
88 Civic Hatch- TURBO H22 swap
fasterimage is offline   Reply With Quote
Old 11-17-2006, 02:44 PM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Yeah- sounds like your BOV isn't working.
Old 11-17-2006, 02:53 PM   #3
2 SLOW CREW
yeah thats kinda what i was figurin it out to be. Is there anyway to test it?
2 Slow Crew Racing
Old 11-18-2006, 12:38 PM   #4
Calesta's Avatar
Ride:  2003 S2000
Just run a pressure differential across the BOV using something to suck on the feed line, then see if the valve opens.
Old 11-18-2006, 03:44 PM   #5
2 SLOW CREW
No idea what your talkin about there.....but if u mean u dont think its getting enough vaccum to open....i think i may need to change the line for vaccum on the BOV instead of where its tapped into now...and move it closer to the manifold and not the turbo!
2 Slow Crew Racing
Old 11-18-2006, 04:53 PM   #6
Calesta's Avatar
Ride:  2003 S2000
Yeah- run the vacuum line to the intake manifold. Where is it tapped in right now?
Old 11-18-2006, 05:25 PM   #7
2 SLOW CREW
on a vaccum line close to the turbo
2 Slow Crew Racing
Old 11-18-2006, 08:40 PM   #8
Calesta's Avatar
Ride:  2003 S2000
Ok- that still doesn't tell me anything. Where is that vacuum line getting vacuum from?
Old 11-18-2006, 11:59 PM   #9
2 SLOW CREW
i just rechecked and I have it tapped into the Boost controller line from the wastegate.
2 Slow Crew Racing
Old 11-19-2006, 12:49 AM   #10
Calesta's Avatar
Ride:  2003 S2000
Try running it straight to the intake manifold.
Old 11-19-2006, 01:10 AM   #11
2 SLOW CREW
ok....i'll change the line tomorrow...thanks alot!
2 Slow Crew Racing
Old 11-19-2006, 08:24 PM   #12
Byaaah!
byebyebaby's Avatar
Ride:  91 Civic hatch
Rep Power: 8 byebyebaby is on a distinguished road
Send a message via AIM to byebyebaby
7psi on virign ecu?wow, my 91 hatch w/ pm6 got pissed around 2psi
The little engine that could.
byebyebaby is offline   Reply With Quote
Old 11-19-2006, 08:40 PM   #13
2 SLOW CREW
well like I said....it sputteres and is stubborn....but were workin on a custom way to get it more fuel!
2 Slow Crew Racing
Old 11-19-2006, 10:38 PM   #14
Byaaah!
byebyebaby's Avatar
Exclamation
it sputters and acts like a bitch because your map sensor is getting pissed off.good way to kill your ride.
Old 11-19-2006, 10:40 PM   #15
2 SLOW CREW
well thanx for pointing out the obvious! I prolly could have figured that out on my own....I stated above im workin on it
2 Slow Crew Racing
Old 11-19-2006, 11:14 PM   #16
Byaaah!
byebyebaby's Avatar
ok well run it as hard as you like, im sure ill be seeing a post from you looking for cheap motors
Old 11-19-2006, 11:25 PM   #17
2 SLOW CREW
hard as I like? I dont drive the car....it sits in my garage....the farthest it goes is to be turned on and pushed out of the driveway....only one time have we driven it down the road....for maybe a minute and that was to make sure everything else was workin properly! I do thank you for your concern tho!
2 Slow Crew Racing
Old 11-20-2006, 05:50 PM   #18
2 SLOW CREW
I'm not sure, this 88 civic has a MAP does it? cuz when we get it extra fuel it runs fine.....it only sputters when it leans way out? I dont think my ECU is even being bothered by the 7 psi of boost???? im not throwing a code or nothing? what do u think?
2 Slow Crew Racing
Old 11-20-2006, 10:46 PM   #19
Calesta's Avatar
Ride:  2003 S2000
Yes, it's MAP, and yes, you'll want some kind of engine management to run the boost and to also keep the MAP sensor from seeing anything but vacuum.
ALL CIVIC PARTS MUST GO ddubz712 Parts: For Sale/Trade/Wanted 12 11-10-2006 12:29 PM
1992 civic spindles/ 1999 civic Si spindles same? lohonda HYBRID -> EG-EK / DC 3 01-11-2004 04:15 AM
Anyone here? 2000Si Members' Lounge 14 12-09-2003 11:55 AM
All This Reference Material, And No Cel Code Chart Slo86GT Members' Lounge 5 06-13-2003 10:31 AM
Chassis Code VSMB16A2 General Tech and Maintenance 10 01-22-2003 05:32 PM
