Its Da Mad Hatter
Ride: acura integra
88 crx hf which is obd0, i am gonna drop a b18c in it which i guess is obd1, but i have a obd2 ecu is that a problem, please dont tell me to search, i have everything is from obd0 to 1 or 2, nothing about using 1 of each please help, and after all my research im sure this is right,
93 teg axles, gonna have to alter linkage, mounts (waiting on reply to order) gonna have to wire the dizzy connector over, and ecu conversion(can i hard wire this over i cant find a diagram for it), im also in need or header and downpipe(stock or not dont care) |
I made the millionth post
Ride: 03 350z, 08 135i, 02 Excursion, 91 CRX Si, 91 Galant VR4, 86 CRX Si
A B18C1 can be either obd1 or 2....find out which one you have 1st.
then you can go the easy route (if you have some spare $$) and just buy a couple jumper harness' they make a Vtec harness for your HF and you'll need the OBD (from obd0 to obd1 or 2) jumper as well. Hasport and Rywire make them both. __________________
Hold it fellas. I'm afraid you're just too darn loud. Next please. BRING THE NEXT GROUP PLEASE. |
Its Da Mad Hatter
Ride: acura integra
i know they make b18 both obd 1 and two what i mean is the motor is 1 and the ecu is two, now is that a problem i know all about the jumper harness and that just will the two work together
it *can* work, but not with a jumper
you've either got to re-wire the pinouts yourself or grab an obd1 ECU __________________
#5 |
Its Da Mad Hatter
Ride: acura integra
thats what i thought i was just making sure because i couldnt find anything out about that anywhere else, what is the difference between the two obd1 and 2, just o2 sensors and emissions pretty much right so pretty much im probly gonna be guarenteed a check engine light, i might just see if i can get the jumper wire, and trade for a obd1 now that jumper eliminates me having to chang any wires at the ecu right ill just have to wire the vtec and pressure switch. . . . . . .
#6 |
obd1 and 2 are very different, heres the pinouts on the ECU's:
http://hondaswap.com/reference-materials/ecu-pinouts-28667/ the easiest thing to do would be sell the obd2 ECU, and buy an obd1 ECU and obd0 to obd1 jumper harness...then you just have to run the Vtec wires and secondaries (or you can buy a plug n play harness for that as well) __________________
#7 |
Its Da Mad Hatter
Ride: acura integra
thats what i assumed just trying to get someone else to agree just to make sure, ok now another think i keep finding stuff about having to change the injectors out i dont know what thats all about i got gsr and the dizzy is obviously from junk yard it has b16a1 on it but i dont know what else they did it used to be in a 91 hatch i believe so i have there wire harness to i havnt looked at the main connectors but i think they might be different so...
#8 | |
ZCspeed Racing |
#9 |
Its Da Mad Hatter
Ride: acura integra
thanks you have defently given a great amount of knowlegde ok well im waiting on harness and stuff but if i run into some probs i ask you if you dont mind thanks
| Idling Problem after B18C1 swap into 96 EK | racersky | HYBRID -> EG-EK / DC | 2 | 01-23-2006 09:38 PM |
| Anyone in RI/MA help me with a b18c1 swap tomorrow | xxxmikenicexxx | General Tech and Maintenance | 0 | 05-16-2005 02:55 PM |
| 90-93 Integra B18C1 swap | THE TECH | HYBRID -> ED-EF / DA | 21 | 12-21-2003 03:40 PM |
| B18C1 Civic Eg swap help | Slammed90Lude | HYBRID -> EG-EK / DC | 3 | 10-27-2003 09:59 PM |
| Swap B18c1 Into 90 Crx Dx | ED8RACER90 | HYBRID -> EG-EK / DC | 3 | 03-06-2003 11:33 PM |
