I have an 89 Si though I believe the trans was replaced with a DX model trans. I have an 88 HF trans I want to install and have read on a number of websites that the ticket is to use a 21 spline clutch disc that is 8 1/4" or 8 3/8" out of an Accord from '86 to '88, along with the stock CRX Si pressure plate and flywheel.
Well, just to be on the safe side, I went researching at multiple auto parts stores and did some parts ordering and have ended up with what I believe to be everything I need, a stock Si pressure plate, and I purchased 2 clutch discs, both for an 88 Accord LXi because one parts store listed 8 1/4" and the other 8 3/8" and they were inexpnesive. I haven't disassembled anything yet, because when I try to fit the disc 8 1/4" or 8 3/8" to the pressure plate, neither will seat on the pressure plate, with the 8 3/8" obviously being the worse of the two. I'm confused. Multiple websites have verified and recommended the same combo over and over. 21 spline disc with stock flywheel and pressure plate. If anyone has any suggestions or ideas they are welcomed. BTW, the smaller and OEM type disc uses brass friction material , the larger, made by Zoom, uses a fiber organic type wear material. Thanks. John |
90 and up are the only ones that use the 212mm diameter clutch - the 89 uses a 200mm diameter clutch - the 89 flywheel will not accept the larger diameter clutch - you need an 88 CRX Si clutch, which is 21 spline and 200mm diameter
ZCspeed Racing |
Thank you for the clarification. I'll order that disc and have a nice collection! Finally the correct one as well. If I ordered the 90+ flywheel and PP, I gather either of the Accord discs would fit?
John |
that is correct
ZCspeed Racing |
#5 |
I still know everything
Ride: 89 CRX HF, 96 Accord EX, 88 Dodge Daytona Shelbyz T-tops
why didn't you just get a clutch kit for a 200mm or 212mm?
Formerly the.original.kermit Back from the dead... twice I NEED PARTS!!! http://hondaswap.com/parts-sale-trade-wanted/wtb-1989-crx-parts-161172/#post1079066 Check out my progress... http://hondaswap.com/auto-multi-media/my-1989-crx-project-144941/ |
#6 |
Ride: 88 Honda Civic HB
212mm clutch disc won't fit that transmission anyways.
1988 Honda Civic STD-more mods than I want to list Terrorists have successfully attacked our imagination. RIP Jon Eban Nie, August 31, 1991 - May 7, 2006 Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006 |
#7 |
the Accord disc that he has is 212mm with 21 splines and will work with his 88 transmission - his problem is that he has an 89 flywheel which will accept only the 190mm and 200mm clutches, not the 212mm - he could get a 90 and up 212mm flywheel and pressure plate and then use the Accord disc
ZCspeed Racing |
#8 |
I did the same thing with my 89 (upgraded to 212mm), but I forgot that the 88 had the different spline
#9 | |
| clutch issues on h22 | 601vigilante | Civic and del Sol - EG and EK | 0 | 05-18-2007 02:03 PM |
| Clutch Issues........... | DelSlow89 | General Tech and Maintenance | 2 | 01-19-2007 08:49 AM |
| B16 Clutch Issues | EG6Civic83 | Civic and del Sol - EG and EK | 1 | 09-11-2006 06:38 AM |
| Clutch Issues | MaxThruster | General Tech and Maintenance | 0 | 08-08-2006 06:00 PM |
| Clutch issues | daveLafleur | Engine Building | 7 | 12-09-2003 09:21 AM |
