89 civic/92civic
Old 12-01-2006, 09:15 AM   #1
Rep Power: 0 hckleberry is on a distinguished road
Send a message via AIM to hckleberry Send a message via MSN to hckleberry Send a message via Yahoo to hckleberry
Default 89 civic/92civic
i own an 89 civic with a 1.5 and a 92 civic with a 1.5. will the engine in the 89 fit into the 92 or does the transmission not line up properly? 89 wrecked rear enad and 92 hole in block, both are automatic, thnx
hckleberry is offline   Reply With Quote
Old 12-01-2006, 11:52 AM   #2
Rep Power: 7 Walshie is on a distinguished road
well with the 5-speed it lines up dunno about the auto, shift points and ratios will be off..
Walshie is offline   Reply With Quote
Old 12-01-2006, 12:19 PM   #3
Default head
i was told that they both have the same head gasket so if the 92 only needed a bottom end could i use the same head and intake, sensors and all?
Old 12-01-2006, 12:33 PM   #4
Your 89 civic is OBD-0 and the 92^ in OBD-1 the head sensors will line up its just the intake mani. the only way I can see you doing it is useing the 89 head and the 92 intake manifold and the 89 block I assume? and using the same 92 tarnny hopefully it will bld on.
